Question about Huawei Cell Phones
BARRING CODE BT2000 - Huawei Cell Phones
How to unblock barring password, for nokia E7
You shuld go to your provaider and change new sim card with your number then you can make new code . no other way for that the code its block into the network wen you change the sim you will have new sim serial then the network will accept your new baring code.
Read more: Call barring password reset / barring password locked state in NOKIA E5? - Nokia 6303 Call Barring Password. 6303 Call Barring Password & Code :: Ask Me Fast at http://www.askmefast.com/Call_barring_password_reset__barring_password_locked_state_in_NOKIA_E5-qna4345257.html#q4175136
Sep 01, 2015 | Nokia Cell Phones
How to unblock barring password for nokia 5310
Call Barring - Enables you to restrict or bar certain or all types of calls to and from your mobile phone, i.e. outgoing calls, outgoing international calls, incoming calls. Barring is activated with a personal code.
Call barring is a mobile phone feature that allows the user to set certain prohibitions on incoming or outgoing calls. This is an effective means to prevent the phone being used to make expensive international or premium rate calls, particularly when the phone is to be used by people other than the subscriber.
Many companies that provide handsets for business use now employ call barring as a security measure, to control their use and restrict calls to pre-approved numbers. The user's personal code must be used to activate this feature.
How do I get it?
Contact your local Service Provider. You will need a four digit barring code. Initially this will be 0000. You should create a personal barring code for security. Please consult your cellphone's instruction manual.
What does it cost?
This service is free.
Also you can deactivate it from your cell phone..
Different cell phones have different setting functions,
You can try these out. It's the general way to deactivate call barring (NOKIA) .
Follow the below instruction:
Go to Menu,
Enter settings,
Scroll to Security,
You will see call barring on that list,
Click on it,and scroll to last option and you will see cancel call barring.
Your cell phone might not be the same with these functions,but the procedure are aways the same..
Good luck.
Jul 18, 2011 | Nokia Cell Phones
Call barring password for Nokia 2730
Hi,call barring - Enables you to restrict or bar certain or all types of calls to and from your mobile phone, i.e. outgoing calls, outgoing international calls, incoming calls. Barring is activated with a personal code.
How do I get it?
What does it cost?
Go to Menu,
Enter settings,
Scroll to Security,
Good luck.
To remove call barring activation
How do I get it?
What does it cost?
Go to Menu,
Enter settings,
Scroll to Security,
Good luck.
May 28, 2011 | Nokia Handsfree For 6020, 6101, 6102...
My nokia phone can neither call nor receive acall,,its barring codes are blocked
I am sure this solution will help you, Just follow the steps.
1- Go into the settings and find the option of call barring usually its in call settings option. 2- Then you find the option of deactivate barring on all outgoing & incoming calls select yes and if it ask you any code or password then its 0000 by default or your sim pin code if you haven't changed. 3- After deactivating barring of incoming and outgoing calls, your phone can make and receive calls.
May 22, 2011 | Cell Phones
I don't know what is the password of call barring belongs my cell phone SGH-L760
hi,
Before you can activate these barring services you will need a barring code from your service provider. Call Barring can not be activated if Call Forwarding diverts are already in use.
To Activate: * 330 * BARRING CODE # [SEND]
To Cancel: # 330 * BARRING CODE # [SEND]
To Check: * # 330 # [SEND]
All Outgoing Calls
To Activate: * 333 * BARRING CODE # [SEND]
To Cancel: # 333 * BARRING CODE # [SEND]
To Check: * # 333 # [SEND]
All Incoming Calls
To Activate: * 353 * BARRING CODE # [SEND]
To Cancel: # 353 * BARRING CODE # [SEND]
To Check: * # 353 # [SEND]
All Outgoing Calls
To Activate: * 33 * BARRING CODE# [SEND]
To Cancel: # 33 * BARRING CODE # [SEND]
To Check: * # 33 # [SEND]
All Outgoing International Calls
To Activate: * 331 * BARRING CODE# [SEND]
To Cancel: # 331 * BARRING CODE # [SEND]
To Check: * # 331 # [SEND]
All Outgoing International Calls Except To Home Country
To Activate: * 332 * BARRING CODE# [SEND]
To Cancel: # 332 * BARRING CODE # [SEND]
To Check: * # 332 # [SEND]
All Incoming Calls
To Activate: * 35 * BARRING CODE # [SEND]
To Cancel: # 35 * BARRING CODE # [SEND]
To Check: * # 35 # [SEND]
All Incoming Calls When Outside Home Country
To Activate: * 351 * BARRING CODE # [SEND]
To Cancel: # 351 * BARRING CODE # [SEND]
To Check: * # 351 # [SEND]
Canceling All Call Barring # 330 * BARRING CODE # [SEND]
i hope it will help you...
Apr 13, 2011 | Cell Phones
I have a nokia 2730c, my number is currently barred, do you know what the code for cancelling the barring? Thank You
hi,
All Outgoing Calls
All Incoming Calls
All Outgoing Calls
All Incoming Calls
Apr 13, 2011 | Nokia 2730 Cell Phone
I want to knw hw i cn use my nokia 2700c security setting like wt is barring code and pin codes (and plz gives this two default codes )
PIN code is for simcard security the default is 12345...But if what you say is Locked code ,its the security of phone the default is 12345 ...about Barring code ,here is some tips...
All Outgoing Calls
All Incoming Calls
All Outgoing Calls
All Incoming Calls
Apr 13, 2011 | Nokia Classic 2700 Cell Phone
Call barring
Call barring code is operator dependent code and not cell depepndent code..
This code works with PIN2 code, and it works only if your network supports, IF your network doesnt support call barring service cont use this PIN2 code, beacuse once you lock PIN2 by giving wrong number, it cnt be unlocked again
Default PIN2 is 12345, you can sheck the mnaual came with your service or call your operator tech support
Rate this solution
RNJVINODKUMAR
Sep 25, 2009 | Nokia 1650 Cell Phone
Im a looking a call barring code for a Nokia 6300
Hi michelle,
Call barring code is operator dependent, You have to call your operator and get it......
THis is not phone dependent... To enable barring you have get the PIN2 code from the operator and set the call barring code,,,,,
THis is a 4 digit code similar to the PIN code....
NOTE: Some network doesnt support call barring service, so you call you operator to know whether this facilit is supported for you....
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
Jul 07, 2009 | Nokia 6300 Cellular Phone
Cell Phones Logo
15 people viewed this question
Top Huawei Cell Phones Experts
Computer Repairing
Computer Repairing
honeybun1986
john h
Are you a Huawei Cell Phone Expert? Answer questions, earn points and help others
