Question about Vehicle Parts & Accessories
98 ford Windstar replace starter
I put in a new starter it still does not start it clangs does not turn on lights work could it be stuck to the flywheel? should I remove again and check flywheel teeth?
  • 2,210 Answers
More to the point I would check the starter has the correct number of teeth. Trouble is, if you have repeatedly tried to start it, you could have ruined the starter ring gear.
Posted on Jul 30, 2014
2001 ford windstar won't start
does it have the halo around the ignition switch for anti theft? ive seen a lot of those fail and need replaced. on a side note be careful jumping the start on those vans,if the ecm doesnt start it sometimes it wont shut it off either. could be the resistor in the key too.
Jul 06, 2014 | 2001 Ford Windstar
MY 98 FORD WINDSTAR VAN HAD RUN STOPED HER WENT IN STORE GOT OUT WENT TO TURN HER OVER NOTHING WAS WORKING NO LIGHTS ETC, LET HER SIT A BITE THEN TRYED AGIN HAD LIGHTSTHE STARTER TURNED THEN DIED TRY
Have a load test done on the battery to check for dead cell as what you describe fits that problem profile. New is a relative term as either brand new or new to you (second hand)
Nov 20, 2013 | 1998 Ford Windstar
Loud noise coming from my engine on my van 98 ford windstar 3.8L
Maybe it,s Cracked or Broke in ther picture say,s Lot,s or the Harmonic Balancer is Loose too or Broke Get back too Me On This Please
Apr 07, 2013 | 1998 Ford Windstar
Have a 99 ford windstar that wont turn over. New battery, new starter, new alternator. The lights work, door dings it just wont turn over. any ideas?
Is gear stick in park, try starting by earthing starter, then you can trace fault, key start might be problem
Apr 05, 2013 | 1999 Ford Windstar
I have a 98 Ford Windstar and replaced the starter. But now when I try to hook up the positive cable on the battery the starter starts working without using the key. what is the problem?
The small wires on the starter are connected wrong, or the large wire is touching the small post.
Look closely at the solenoid on the starter and make certain that you've wired the large wire to the right place and that everything is connected properly.
If necessary, look at a shop manual to see the proper wiring of the starter.
Feb 19, 2011 | 1998 Ford Windstar
Van wont start
Just maybe the battery and alt were good. You did test them,before replacing didn't you? How about the starter solenoid,starter or ground connections or cables with too much resistance. Do a voltage drop test, on all grounds, you can get to.
Feb 19, 2010 | 2003 Ford Windstar
98 ford windstar has clicking noise under dash and won't start
The clicking noise is most likly the starter solinoid cycling in and out. This is due to low battery voltage. charge the battery, then have the battery and charging system tested. Some auto supply stores will do this for free for you in the hopes of selling parts
good luck
Feb 09, 2009 | 2000 Ford Windstar
Starter issues with 98 Ford Windstar (3.8)
one problem that the 98 winstars ( 3,8L ) are prone to is the transmission range sensor. they are badly located and not well sealed. As a result corosion...
The starter solenoid wire ( red/ light blue ) runs throught the range sensor before reaching the ignition switch.
Try shifting back and forth between Park and L1 rapedly at least 5, 6 times and then try starting in Neutral.
If it starts the TRS is easy to replace and accesible.
( The TRS is also responsible for the transmission going into irradical kick down mode )
Dec 30, 2008 | 1998 Ford Windstar
Vehicle Parts & Accessories Logo
46 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
