Question about Akai LCT2721AD 27 in. LCD Television
Can someone tell me the values of the capacitors ?
On the LCT 2721AD HV board Cap
EC 18 - 19 - 20 and ec 9 ec 10 and what is a good place to ordered from ?
  • steelflatroll Jun 23, 2009
    thanks
    on Ec 9 - 10 the tops feel slighty buldged I thought I might as well replaced these while at it .. they are slighty larger in size than e 18- 20 wonder if their values are different ?
  • steelflatroll Jun 24, 2009
    now I'm confused are we up grading the EC from 220 uf to 1000 uf on ec 18 - 20 and should I go higher for EC 9 - 10
  • 110 Answers
EC18, EC19, EC20 are 1000uf/16v 105c
never had to replace EC9 and EC10 but should by the same value look at the size if the same as EC18 - EC20 I would go with the same value. It should be printed on the caps. If that did not fix your dead unit replace the power supply board and same time.
Check for the parts here:
http://www.mcmelectronics.com
# NOTE - If this info was helpful to anyone please click on yes!
Posted on Jun 23, 2009
  • 1 more comment
  • TOM2-TOM2
    TOM2-TOM2 Jun 23, 2009
    Yes they are not the same. I will have to look it up for you I will post back with there value.
  • TOM2-TOM2
    That's the unit with the black power supply board. Here are the cap values and stated in the manual:
    EC18 - 19 and 20 _______220uf/16V
    EC9 - 10 _______________ 100uf/16V
  • TOM2-TOM2
    TOM2-TOM2 Jun 25, 2009
    The manual stated 220uf/16 and 100uf/16v so put them in the last unit I fixed I think I used 1000uf/16 the power supplys may not have been the same.
About recent question.
Unfortunately, some of the "Experts" here really aren't. Everyone that answers a couple questions is listed as an "Expert" and it doesn't matter if their answers are worthless!
"The Knight" has over 64,000 questions answered, so I question his or her credibility. "The Knight" didn't even bother to warn you that a TV has hazardous voltages even when unplugged. It's usually limited to the power board, but still you should have been warned.
Your problem could have been the T Con board, but it also could be your display or another control board if yours has another. There's also a smaller chance that part of the power supply has gone bad.
Unfortunately, you'll have to get a TV repair shop to check it.
Jul 22, 2016 | Polaroid TDA-03211C 32 in. LCD HDTV
My element tv won't come on it has no indicator light
The worst offender is capacitor EC 13 (this is the location). It is located inside a heat sink shield (iron cage). The value is 25 volts at 330mf. Once the cage is removed replace these capacitors as well. EC14 & EC6, 35 volts at 100mf. EC10 &EC12, 35 volts at 470mf. EC8,EC7,EC9,at 16 volts at 1000mf. EC11,EC12 at 25 volts at 220mf. Please also resolder connection CON3. This connection will allow a good ground to the main board (also known as the signal board. Also you will have to replace diode HER304 (this is the location). This diode is mounted on a heat sink. Replace it with a NTE 576. f you cannot do this find an electronic hobbiest or a TV Shop. Take this info with you. Thanks for asking, Matt of Martins TV Repair.
Mar 31, 2016 | Element Electronics FLX-3211B 32 in. LCD...
Error code 42 I need to replace the electrolytes capacitors. Can you provide the part code
What caps where? There are capacitors on various boards on those sets. Does the code 42 tell you what board they are located on?
The values are indicated on the caps themselves and the values vary all over the place with regard to uf spec and voltage.
Sep 08, 2015 | Televison & Video
Hot tub in EC with light flashing
Ecn or Ec Message
Ecn or Ec Message
If the Ecn or Ec Message is Alternating with the Water Temperature on the Display, the Spa is Operating in the Economy Heating Mode.
If the Ecn or Ec Message is ON Solid (Not Flashing) on the Display, the Spa is Operating in the Economy Heating Mode, but there is No current water temperature because the Spa is between Filter Cycles.
Ecn or Ec is Alternating with Temp:
The Spa is Operating in the "Economy" (Ecn or Ec) Heating Mode.
The Water Temperature is Sampled Only during Programmed Filter Cycles. The Heater will Only operate and Heat up to Set Temperature during the Filter Cycles. The Water Temperature will probably drop Below Set Temperature between Filter Cycles. Other Heating Modes are Standard, Standard in Economy, and Sleep Modes.
Ecn or Ec is ON Solid (Not Flashing):
The Current Water Temperature is "Unknown" (- - - or - -) while in Economy or Sleep Mode.
Between Filter Cycles, while in the Economy or Sleep Heating Modes, the Pump has not turned ON and the Last Water Temperature is not Current. To read the Current Water Temperature, either Change to Standard Heating Mode or turn On the Heating Related Pump, and wait at least 2 Minutes.
Dec 23, 2012 | Jacuzzi Balboa R574 System for 1 2 Speed...
Need parts list for mother bd. HP Pavilion m9500y ,ms-7548 ver i.0
you are going to find those close to the atx (main power) connection
Sep 25, 2012 | HP Pavilion Computers & Internet
I have a Friden Model 130 Electronic Calculator and am interested in its current value?
Dear workmangk. I have a working EC 132. Your EC 130 was the 1st solid state calculator. My father used to sell & support them. I estimate a working model could be worth $US1000 +. I bought my non working EC 132 for around $400 some 8 years ago. They are difficult to obtain now. Best wishes, Gordon. Adelaide. Australia
Jul 21, 2011 | Computers & Internet
Where can I purchase Replacement Parts for the ZUTTO EC-DAC50?
HI,
I will advice you check ebay.com or ereplacementparts.com, these are two good places to get parts.
Dec 06, 2010 | Zojirushi ZUTTO EC-DAC50 4-Cup Coffee...
I have a Sanyo EC 23 10-Cup Rice Cooker which I bought long time ago. Never been used. The electrical cord is missing. Can I order a replacement electrical cord if this model is discontinued?
I have the electrical cable, you are looking for.
My favorite Sanyo EC-23 rice cooker's start button broke when it fell down. (I am looking for a similar cooker with OFF switch.) So, I can easily send my electrical cord for no cost (pl. pay only mailing cost $1 or $2, I need to find out).
Why I am going through this trouble? 1. I liked the cooker. I am still looking for a similar one. 2. This is the best for the environment (reusability). I like this web site for the same reason. I liked the cooker a lot and was useful for more than cooking rice. It will be nice if someone can use the parts.
I live in MA. I can go to Natick Mall, Watertown mall, cambridge Galleria in a public place next to security if you like, to pick up in person Mon-Fri between 8:30 am and 2:00 pm.
pandarisami@yahoo.com
Nov 04, 2010 | Sanyo EC-510 10-Cup Rice Cooker
Gigabyte board GA-8IK1100 - all I need is a capacitor value
Hi, got the same board here infront of me. The capacitor is 1000mf,, 6.3volt
success
Mar 25, 2009 | Gigabyte GA-8IK1100 Motherboard
Jet Pump stops after three starts of 20 minutes each and it doesnt want to start back again until the next day or after a few hours
check motor with hand after it stops for excessive heat. Thermo coupler shuts motor off if overheating, to protect windings. Bad motor bearing can cause overheating, if so should hear bearing noise when running.
Also check start capacitor, by removing and checking with ohm meter, or plug in oposite terminals of capacitor to charge. Place rubber glove on hand, and contact two oposite terminals with screwdriver should produce a small spark.
Nov 15, 2008 | Hayward EC-40 DE Pool Filter with pump
Akai LCT2721AD 27 in. LCD Television Logo
207 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
