Question about RCA Televison & Video
Why won't the controller turn the antenna?
Controller will not turn antenna on roof. It is new, was calibrated and tested before being put up now will not turn antenna t all. Model number vh126r. rotator 40k3 can we get it replaced?
4 Suggested Answers
  • 121 Answers
SOURCE: i have a leak in
i would remove it then place silicone under the and around the base.maybe make gasket for it. you can buy a special paper for this at your local parts store.
Posted on Jan 17, 2011
emissionwiz
  • 76109 Answers
SOURCE: I have an after. Market cruise control (aus cruise
I would check the pickup, it may not be adjusted properly or hooked up correctly.
Posted on Sep 20, 2012
jerry_kramer
  • 3904 Answers
SOURCE: rca vh126r rotator has stopped working
This should have a reset to it. If not then it got thrown off in the gearing and my have to be manually reset by taking it apart.
Posted on Apr 14, 2014
My swr meter will not calibrate. I put it on fwd, Key the mike, put it on ref,and it pegs the needle. why?
Antenna may have a dead short or is open, there may be water in the cable, SWR is beyond the scale of the SWR meter.
Check all connections, make sure you have the radio and the antenna well grounded. if possible disconnect both ends of the coax cable and test cable with a ohm meter for a short or open.
Test the SWR meter on a known good antenna and cable if possible.
Oct 16, 2014 | Radio Communications
I have had a Cobre 29 LTD Classic, a 29 NW LTD Classic and now a 29 LTD Chrome.It seems that the first two died because of possible bad antenna connections. I was able to calibrate the radios and adjust...
I see two possible problems. First, with a magnetic antenna it is difficult to get the proper ground for the antenna. Make sure the magnetic base is clean as well as where you place it. Second, try running your power lead DIRECTLY to the battery and not using the cigarette lighter. Hope it helps.
Tom
Feb 27, 2013 | Cobra 29 LTD CB Radio
HELLO STAN FIRST HAS THE RADIO BEEN PEAKED AND TUNED? SECOND IS THE INTERIOR LIGHT IN YOUR PICK UP RIGHT BELOW YOUR ANTENNA,IF SO YOU HAVE A PROBLEM BUT EASY FIX THE WIRING GOING TO THE LIGHT ACTS LIKE AN EXTRA ANTENNA CAUSING YOUR ANTENNA TO RESONATE TO YOUR RADIO CAUSING THE A W I LIGHT TO COME ON MOVE YOU ANTENNA BACK A LITTLE FUTHER AND SHOULD BE GOODif you want to get a bettter antenna get a willson 500 mag mount far better
Image 10.2qi motor won't turn on. control board is fine and power is on.
1) Please test the main motor, see my personal TIPS for motor help.
2) test the output board for input voltage motor, if there are NOT the board is faulty.
see the diagram and block diagram
You can RUN the software calibration for diagnostic,troubleshooting, and fix it.
Happy NEW YEAR, God bless you
Dec 31, 2012 | Image 10.2QI/10.2Ql Treadmill Walking Belt
RADIO ANTENNA LOCATION
Above the roof headliner.
Jul 26, 2017 | Audi A3 Cars & Trucks
With or without my indoor rabbit ears, cannot get any channels below 7. the people where i got the antenna told that i could connect my roof antenna to an adapter and connect it to the antenna input on the...
Hello
You heard is correct. Your roof antenna can be connected to your TV, after connecting it to a balancing coil adapter, usually called 'Balun Adapter" which converts the impedence from 300 to 75 Ohms. It can be bought for most of the electronic shops all around. Connect the antenna wire to it and then plug it to your TV antenna in socket. The stations will be very clear, and well defined. You may have to turn the roof top antenna towards the direction of the transmitting tower to get a well defined, ghost free image. OK.
Mar 27, 2011 | Televison & Video
Can I replace the antenna without removing the entire inside roof trim
I think you could answer this question, If it is a roof antenna and there are no zips in the roof trim then NO, But what you can do is disconnect that antenna lead and fit a new body antenna.
Jun 06, 2009 | Car Audio & Video
Puts out very little
output transistor gone or power turned down on front control,
May 09, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
Tb100mw9 converter did not work.
You need the audio/video cables and to put your tv on a channel with no signal (3 or 4).
Nov 21, 2008 | Sony RMT-V202 Remote Control
I bought a 32" conia tv and i cant get good reception! i have bought a amplified antenna and a hd set top box and still no good reception. my other tv's in the smae spot have had no reception issues....
well it's the same as the days of old, the antenna has a range of reception. the further the sations antenna, the lager your antenna must be. just because you bought an amplified antenna does not mean you will receive the deep fringe station. also the antenna must be UHF and VHF to receive the broadcast in digital. most of the braodcasters have gone with the UHF band because it is more stable for the bandwith of digital broadcast. the UHF band is very directional as well, so you must be pointing to the broadcasters antenna. no set top antenna will work if you are further than 15 miles of the broadcasters antenna. the roof top UHF/VHF antenna with a preamp is the way to go. I have tested every compact antenna and unless you live in the city that the broadcast generates you will get no reception with these. terks are junk, and any small amplified antenna does not work if you are in low lying areas. roof top, roof top,.....ROOF TOP!!!!!
Apr 24, 2008 | Televison & Video
Televison & Video Logo
15 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
