Question about Toshiba DKT2020SD Phone
I would like to know how to permanently mute the ringer.
  • blueextc3221
    blueextc3221 May 11, 2010
    Looks like disassembly and physically cutting the speaker is the only way. Here is your Manual if you care to look through it.... CLICK HERE
    Problem Solver:
  • 11 Answers
The ringing for this system has to be changed in the system programming. This is usually done by your vendor.
Posted on Jun 27, 2009
How do I turn the ringer on, on the handset?
Press program/mute button to confirm and you may program the following items: Set Language, Handset Name, Ringer Tone, Ringer Volume, Message Alert, Ring To Answer, Security Code, VIP Melody, Key Tone, Audio Predial, Vibrate Ringer, Area Code, Tone/Pulse, Registration, Deregistration and Default Setting.
Ringer Volume
From the Handset Setup Menu:1. Press the caller ID-volume ( 6 or 5) button to scroll to the RINGER VOLUME sub-menu.
2. Press program/mute button to enter the menu. SET RINGER 1HI 2LOW 3OFF shows in the display.
3. Use the touch tone pad on the handset to select 1, 2or 3, or use the caller ID-volume ( 6 or 5) button to scroll to your selection. HI is the default setting.
4. Press the program/mute button to save your selection. You will hear a confirmation tone and the new volume setting shows in the display.
NOTE: If you turn the ringer OFF, the ringer off icon shows in the display.
May 27, 2016 | Uniden Cordless Phone
Somehow the ringer got turned off. Can't figure
Adjusting the Ringer, Earpiece and Speaker Volume
Adjusting the Ringer Volume
You can choose from four ringer volume settings (off, low, medium, and high) separately on each handset or the base.
With the phone in standby, press or on the handset or VOLUME or VOLUME on the base. The handset or base sounds the ringer at that level.
Use on the handset or VOLUME on the base to make the ringer volume louder. Use on the handset or VOLUME on the base to make it softer or turn it completely off.
When you hear the ringer volume level you want to use, stop pressing keys.
The handset or base will use the new ringer volume starting with the next incoming call.
Note: If you set the ringer volume to Off, the handset or base won't ring. Other handsets or base will ring according
to their individual settings.
Muting the Ringer (One call only)
While the phone is ringing, press /Mute or END on the handset or on the base to mute the ringer
Sep 12, 2011 | Uniden Lands Phones
Why wont my ringer sound on my iphone
There is a switch right above the volume buttons on the left that is used to mute the ringer. Flip the switch up (towards the screen) to disable mute of the ringer.
Aug 27, 2011 | Apple iPhone4 4G iPhone 4
Uniden Model EX 14560 Ringer off How to put ringer on
Here some solutions for your problem + a link to the user manual.
**Selecting the Ring Tone and Volume
Your phone has five different ringer tone/volume combinations you can choose from.
To select the ringer:
1) With the phone in standby, press [vol/ / ] or [vol/ / ].
2) The phone will sound the different ring tones at different volumes. To turn the ringer
off, select RINGER OFF.
3) When the phone sounds the ring tone and volume you wish to use, press [end].
**Temporarily Mute Ringer
If the handset is off the base while an incoming call is ringing, simply press [end] to mute
the incoming ring. The ringer will sound with the next incoming call.
Note: You can only mute the handset ringer if the handset is off the base when the phone starts
ringing.
Adjusting the Earpiece.
**Here is also a link to the phone manual http://www.uniden.com/pdf/EXI4561om.pdf
May 18, 2011 | Uniden Cordless Phone
My phone ringer is off and I don't know how to turnit on
You may follow the steps below.
2. Press mute/program button to enter the menu. SET RINGER 1HI 2LO 3OFF shows in the display.
3. Use the touch tone pad on the handset to select 1, 2 or 3, or use the caller ID-volume
4. Press the mute/program button to save your selection. You will hear a confirmation tone and the new volume setting shows in the display.
May 12, 2011 | GE Lands Phones
How do I shut off the ringer on HP Photosmart Premier C309
Press the Setup button, go to Basic Fax Setup, scroll down to Fax Sound Volume, select Soft, Loud or Off. On ours, "Soft" is way too loud.
Dec 01, 2009 | HP Photosmart Premium C309A All-In-One...
My handset ringers are ''off''. How do I turn them on again? Uniden TRU4985
Hi there try this,
When the phone is in the standby mode, press menu/mute.
2) Press select/ch.
3) Press + or - to move the pointer through the ringer
settings (Ringer Off, Ringer Low, or Ringer High).
You will hear a ringer or melody at the selected volume.
4) Press select/ch, you will hear a confirmation tone.
Ringer Mute (temporarily)
You can temporarily mute the ringer tone. When the handset is off the base and the
phone is ringing, press end. The ringer tone will return to the previous setting starting
[ 20 ] BASICS
• If you select “Ringer
Off”, “Ringer Off”
appears on the display
when you make or
receive calls, or
charge the handset.
Ringer Volume Setup
1) When the phone is in the standby mode, press menu/mute.
2) Press - to move the pointer to “Ringer Tones”, then
press select/ch.
You can choose from 6 ringers or 4 melodies:
- Ringer [Flicker, Clatter, Leap Frog, Ping Ball, Reminder,
Soft Alert]
- Melodies [Beethovens9, For Elise (Elise), Merry Christmas
(Merry-Xmas), Home Sweet Home (Hm Swt Hm)]
3) Press + or - to move the pointer. You will hear the ringer or
the melody as you scroll through the options.
4) Press select/ch and you will hear a confirmation tone.
Ringer Tone Setting
• If
Sep 27, 2009 | Lands Phones
2300 nokia ringer problem
sir my mobile nokia 2300 not ringing
Jul 14, 2009 | Nokia 2300 Cellular Phone
Toshiba DKT2020SD Phone Logo
122 people viewed this question
Top Toshiba Lands Phones Experts
Oloyede Monsuru
Marvin
Marvin
Are you a Toshiba Lands Phone Expert? Answer questions, earn points and help others
