Question about Refrigerators
HOW TO FIX BOTTOM DOOR RACK OF kenmore mini fridge 564-9143110 ?
HOW TO REPAIR BOTTOM DOOR RACK
  • 363 Answers
SOURCE: 07kenmore elite bottom drawer gaps when fridge is closed
clean all of the freezer seals and all contact points.
Posted on Jul 22, 2009
  • 512 Answers
SOURCE: my Kenmore black mini fridge, door will not stay sealed shut
Got too much stuff in it.
Not level or is tilted forward.
Door is warped.
You keep opening it.
Am I getting close?
Posted on Sep 08, 2009
arikrom
  • 528 Answers
SOURCE: I have a kenmore top freezer refrigerator model
i had the problem my self :)
you need to take the freezer door out then the fridg door and add small ring like 1mm to the hinges of the fridg door poot all back and see if it rais the door a bit....
what i did is on the top of the freezer there is option to move the door from side to side ...the plastic that go into the freezer body its a ring with long tube.. i cut the tube and use that plastic :) good luck
Posted on Jan 03, 2010
sonicboomele
  • 1557 Answers
SOURCE: How do you change the door gasket on a kenmore
pull back the seal and you will find a stream of screws undo them all and the panal will fall off peal the old seal off and replace with new re asemble as per reverse order
best of luck
please remember to rank my reply
Posted on Dec 01, 2010
  • 1456 Answers
SOURCE: I have a side by
Hello
There are two possible reasons for this problem: a bad switch in the door or a bad water solenoid. In the door is a small switch operated when you want water. Remove the screws to get access and use a meter to see if the switch is closing(after unplugging it first). To test it just put the meter leads on either side of the switch and operate it. If it is good the reading in ohms will go to zero when the switch is pressed.
If that is good check where the water enters the refrigerator and you should see the water solenoid. Find where the electric wires enter and disconnect one side. Check continuity across the coil with the ohm meter and if it is good it should read 1-3 kilo-ohms. One thing that could have happened is also that dirt could be clogging the screen where the water enters the water solenoid. Turn water off and check it out.
Posted on Jul 06, 2011
How can I fix the door alarm in my Samsung cooltech plus fridge ?? Heelp pleaaase
Normally the door alarm chime comes o when the door is open for over 5 minutes.
Check the obstructions mainly at the bottom rack for proper door close switch operation
Aug 03, 2016 | Samsung Refrigerators
How do I defrost bottom freezer on my Kenmore French door bottom freezer
Take the bottom door off take racks out as well as the tracks of racks then use the flat head screw driver to take out fan cover then un screw back panel and take it off then you can defrost it. Won't be easy
Oct 19, 2014 | Kenmore 77552 Bottom Freezer French Door...
How do I find out the model number of my Kenmore elite Fridge
Since the freezer is icing up there could be many different problems a blockage or a problem with the defrost or timer of the unit if u greeting unit number is should be on inside of the door or back by the condenser best bet from what I see is get a tech to fix it they will find all those numbers that u need
Dec 11, 2013 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I own a KIC Fridge the problem is that the door does not closes the rubber does not grip tightly when closing. I have to sometimes lean on the fridge for 5-10 seconds for it to close and it sometimes does...
Hi did anyone get back to you on this? I have a KIC Fridge and it does the same... take out the top door shelf/rack but then you MUST unscrew the light (cause otherwise your light never goes off and your food doesn't stay cold) cause the top shelf/rack in the door switches off the light... anyway... once the top shelf is out, the door will close better.... not sure how else to fix it though...
Feb 09, 2011 | Smeg FAB32 Bottom Freezer Refrigerator
Someone is trying to sell me a kenmore elite french door fridge. only a couple years old. says everything works fine inluding compressor- except that it needs freon . is this going to be a major and...
Stay away. If it does need freon it means it has a leak somewhere in the sealed system. That can be a very expensive fix. Who diagnosed the problem? May be other issues. If your looking for used go to an appliance dealer to get at least a 30 day warranty. I would not reccomend buying anything that has not been repaired first.
Sep 04, 2010 | Kenmore 24.8 cu. ft. Trio French Door...
I have a kenmore top freezer refrigerator model 253 about 1 1/2 years old. The fridge door sticks at the bottom of the door and the bottom of the fridge inside. There are scratches on the fridge bottom...
Jan 03, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
My Kenmore black mini fridge, door will not stay sealed shut
Door is warped.
Am I getting close?
Sep 08, 2009 | Kenmore Refrigerators
KENMORE MODEL 596 BOTTOM FREEZER, FRIDGE NOT COOLING
The freezer will stay cold because a small amount of cold air will be forced through the frost but that will not be enough to make it up to the refrigerator portion. You can defrost the unit by removing the metal panel and allowing the frost to melt. Careful use of a hairdryer can speed up this process. This will likely be a temporary fix. The root cause of excessive frost can be caused by a bad door seal or a defective defrost circuit.
First check that the door seal is good by closing the door on a dollar bill at several points around the door, both on the freezer and refidgerator door. If you can pull the bill out with no resistance, the door is not making a good seal. Inspect the seal and make sure there isn't anything stopping the door from closing such as food, or a shelf not pushed in all the way.
If the door seal is good, the defrost system is likely defective. The defrost system has three main parts, the defrost heater, thermostat, and timer. None of these parts are particularly expensive, or difficult to replace you feel comfortable with repairing it yourself. If you can troubleshoot this by manually starting the defrost cycle. Let me know if you would like this procedure.
Jan 06, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
20 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
