Question about Grace Digital IR2000 Wireless Internet Radio with Remote and Aux Input, GDI-IR2000,GDI-IR2000,IR-2000
Ow do you fix radio that will not power up
Will not turn on - lights up but none of the switches work and the shift light stays on. The screen has bars but no information.
My heater will not work plus my dash lights stay on even when the car is turned off
Reasons Your Car Won't Heat ' Heater Stopped Working ...
www.autobytel.com > MyGarage® > Car Ownership Tips
The only cure here is to replace the heater core. To prevent the problem from reoccurring, the cooling system should be flushed and refilled with a fresh 50/50 ...
Car Heater Not Working - Troubleshooting Repair Tips ...
? 4:05
https://www.youtube.com/watch?v=aCkVjiPZA4o
Oct 1, 2013 - Uploaded by WiseAutoTools
When a car heater doesn't work, the most common cause is low coolant. When troubleshooting to try and ...
How to Fix a Car with No Heat (Easy) - YouTube
? 10:56
https://www.youtube.com/watch?v=-XjXTVJhFLM
Nov 21, 2014 - Uploaded by ChrisFix
No heat in your car? Car not blowing hot air? This video will show you how to fix your car's heater whether ...
Dash Lights May Stay on Due to Malfunction in Ignition Switchrepairpal.com > Problems > Volvo > 850the dash lights stay on after I turn the car off, Volvo repair can't find probl ... We recently replaced the ignition switch (1996 Volvo 850) and the car starts ...Dashboard lights going berserk...even when car is off - Car ...community.cartalk.com/.../dashboard-lights-going-berserk-even-when-c...Feb 11, 2013 - Dashboard lights going berserk...even when car is off. di k .... electrical systems the power to the cluster is turned OFF with the ignition switch. ... However, the abs light is one of the lights that stays faintly lit with car on or off.Radio and dashlights remains ON when car is OFF - 2014 ...jeepcherokeeclub.com/.../16673-radio-dashlights-remains-when-car-off....Jan 15, 2014 - 10 posts - ‎5 authorsRadio and dashlights shuts off properly when the car is OFF. .... door handle evenwithout key with me. just stay on for a m inute. notice it when i ...Dash lights won't turn off. - TDIClub Forumsforums.tdiclub.com > VW TDI Discussion Areas > TDI 101Jun 1, 2004 - I started the car, then noticed the dash lights were on before I turned on... I fiddled with the switch--even unplugging the standard NA light switch the dash lights .... If they stay the same, is it the normal brightness or dimmer?
Jan 10, 2016 | Cars & Trucks
I have a 2000 dodge grand caravan. My instrument panel lights stopped working but the gauges work and the radio works. The milage and shift letters light up just none of temp,tach,spedo and fuel gauge...
I would test your fuses but if that is not your problem your dash light dimmer switch may have gone bad. or is turned down all the way if this was helpful please leave good feed back
Jan 20, 2015 | 2000 Dodge Grand Caravan
1999 Chevy Blazer. When ignition is turned off none of the accessories stay on anymore.
GM has the RAP system, Retained Accessory Power, locate a wiring diagram, believe there is a relay...
Oct 28, 2014 | 1999 Chevrolet Blazer
I have a GE Monogram Wine Chiller ZDW24A RBB. Everything works fine, but today the light stopped turning off when I shut the door. I checked the sensor on the bottom and it seemed to be in order. H
On the right of the thermostat on the grill below the door is a rocker switch, turn it off as this is a light switch not a power to unit. Its just the switch was turned on during your cleaning process. Good Luck
Oct 14, 2014 | Furniture
2004 olds alero 3400 eng.turn on key and all warning lights and gauges come up,then all goes off after 3 seconds,starter will not work,can start by jumping across starter and runs fine and shifts fine
Check for power at the switch wire when someone turns the key to start. I would say there is a break in the circuit of the thin wire between the starter & the ignition switch
Oct 03, 2012 | 2004 Oldsmobile Alero
Black screen
There is a post by Stivo on this board that has helped many fix this type of problem. There are two capacitors on the power supply board that go bad and if replaced can fix this problem . The parts can be purchased at your local Radio Shack for about five dollars or less. I just did it today and it worked!!!
May 21, 2010 | Polaroid FLM-3734B 37 in. LCD HDTV
Technika fm/digital frozen
Possible shorted power supply capacitor or bad diode.
Rod
Apr 20, 2010 | Audio Players & Recorders
I have a 1997 Jeep Cherokee. My issue is with the interior instrument lights, none of them work. I checked ALL fuses inside and out of the vehicle and all tested GOOD. Guages work and Radio display works...
It is the headlight switch, very common problem on jeeps, my 96 grand cherokee dose the same but most times the lights will flicker. Try spraying a small amount of WD-40 in to the panel dimmer switch and then move it around and kind of jiggle it around.
Feb 05, 2010 | 1997 Jeep Cherokee
Battery is fine, no dash lights come on car won't start.
check fuses for dash lights if you use a12 volt tester turn on runnig lights and check dash lite fuse for power the radio maybe on same curcit/
Sep 16, 2009 | 2002 Chrysler Sebring
Dashboard lights
check the wiring cable and the internal signal cable
Jan 10, 2009 | 1996 Nissan Sentra
Grace Digital IR2000 Wireless Internet Radio with Remote and Aux Input, GDI-IR2000,GDI-IR2000,IR-2000 Logo
Top Grace Digital Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Grace Digital Audio Player and Recorder Expert? Answer questions, earn points and help others
