Question about ASUS Computers & Internet
How do I close a tile? I opened the asas tech support one and now it says its running all the time,
How to export log from CISCOASA?like other cisco device logging 1.1.1.1 i want similar kind command in CISCO ASA
ASA's log is usualy stored localy on ASA itself, so easiest way to export that log is to go with telnet/ssh/console on it, do a command : show logging and copy/paste output into a new file.
but beware - this log is really short and as soon as ASA is rebooted - it's gone.
you could set asa to log to a syslog server (free on linux/freebsd or for windows use KIWI app).
that way all ASA log output is stored on pc/server running your syslog server.
Jan 03, 2011 | Cisco ASA 5510 Firewall
I purchased the new Ridgid tile saw named " The Beast". Initially it looked like a great saw buy after cutting a few ceramic tiles I began to notice that it cuts with a slight curve. I could not find any...
Its either the speed of the blade ( mine came with its speed at half rate), or its the crappy blade they give you with the saw. If a cut is bowing your blade is having a tough time with material. This often happens with tough porcelain tiles and not using a porcelain blade.
Oct 01, 2010 | Ridgid 10"Wet Tile Saw with Laser and...
Low flow how do I fix this
Most likely you either have air in the system or a blockage
A blockage can occur at the front of the motor from skimming or direct suction
you would be surprised what sneaks through the pre filter screens
Undo the hose in front of the motor first
there is a plastic housing screen that usually gets clogged
If it is air drain the hoses and the filter cartridge housing
now blast out your cartridge with a strong garden hose
Put it all back together
now open all bleeders except the one on the bottom of the cartridge housing
open dishcharge hose side first
when water starts coming out of the bleeders then open the inlet hose
Turn on pump for 30 seconds and then close the bleeders this should do it
Aug 17, 2010 | Intex Automatic Salt Water System for ...
I have ASA 7.2 running on 5505. I like to upgrade the firmware with ASA 8.2.1 How I can do this? Please let me know ASAP
gostaria de receber o manual de instruçao do aparelho telefonico intelbras id ns ep0811190257
Mar 17, 2010 | Cisco ASA 5505 Firewall
Product description of olympus XA1 Camera with Elec.Flash A9M
To open the camera, you need to close the lens, then with the rewind mechanism, flip open the handle and lift the whole rewind mechanism and the handle and it will open the back of the camera. I hope this helps.
Oct 11, 2008 | Photography
How to use Tile Saw
To cut a tile using a wet tile saw, measure the exact space in which the tile will fit. Cuts are usually along a perimeter, in a corner, or around an electrical outlet. Mark the line on the full-sized tile in grease pencil. Most saws will accommodate tiles up to 12 inches (30 cm) in size, but oversized saws can be rented for huge floor tiles. Wearing safety glasses, place the tile on the moveable platform, and line up the mark with the edge of the saw. With the motor running, slide the platform toward the blade with an even but gentle pressure. Since you are grinding the tile apart, ensure that the water have sufficient time to cool everything.
Aug 27, 2008 | Dewalt DW8308 60-Grit. 4 1/2" Blue...
Upgrade firmware on a cisco ASA 5500 firewall
This is for the pixes, I haven't upgraded an asa yet...should be close or the same
* find latest version of code, these are usually *.bin files located on http://www.cisco.com/cgi-bin/tablebuild.pl/pix
* confirm the flash and RAM requirements of the PIX OS software versus what the PIX has (”sho ver”)
* make sure you have a backup of the old PIX OS and PDM to the tftp server (or at least confirm the software is there)
Note: You cannot back them up from the PIX, so you will need to download them and put them on the tftp server * put in a change control form
* once change controls confirms date/time do the upgrade:
wri mem*** only if you save your configs via tftp wri net conf t ca save all copy tftp://your tftp server ip/pix635.bin flash:imageskip this if you don't use pdm copy tftp://your tftp server ip/pdm-304.bin flash:pdm *** if this is a failover pair, upgrade the other pair reboot
Sep 06, 2007 | Cisco ASA 5500 Firewall
Computers & Internet Logo
56 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
