Question about Whirlpool Calypso GVW9959K Top Load Washer
Washer makes a humming sound and spins and stops.. The machine is only 4 years old. some times it works just fine and other times it wont go at all
  • 111 Answers
Check the start capacitor
Posted on Jun 23, 2009
My frigidaire LTF6700FSO will not spin
Your symptom sounds like a jammed drain pump. Was it spinning and then stopped before the spin cycle should have ended or did it not begin spinning when it should have?
Jan 17, 2013 | Frigidaire ATF6000ES Front Load Washer
My Whirlpool Ultimate Care II LSB6300PW0 is about 6.5 years old. In the middle of a wash it started making a very loud humming noise. The machine wont agitate or spin. It still fills and drains the water...
Renee,
This might be too late for you but hope it helps!
I was able to fix a similar problem with the same model washer of a similar age so see if any of the following helps you.
Our washer died during a rinse/spin cycle and started making a horrific spinning/clicking sound when it was supposed to be agitating or spinning. It filled and drained like normal, and the horrific noise stopped when the lid was lifted.
Because of those two facts, I discovered it was likely the direct drive coupling, which connects the washer's motor to the transmission.
Turns out, that horrific sound was indeed the sound of one of the couplings spinning uselessly after it broke.
After some internet research, I discovered it was a simple matter of getting and installing the new coupling, which was very easy to do with a little professional help via YouTube:
Also, here is the website of a parts supplier with great schematics and great prices that I bought the part from.
Dec 22, 2010 | Whirlpool LSB6300PW Top Load Washer
GE Top Loader 10 years old. won't drain
Timer is faulty and should be replaced.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 10, 2009 | GE WBSR3140DW Top Load Washer
Washer motor hums....
have you tried the timer switch?
Jun 19, 2009 | Whirlpool LSR7333 Top Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
GE commercial washer wont spin or drain
If your washing machine is 20+ appliance years old, it's probably due for replacement.
Jul 15, 2017 | GE WNRD2050DWC 3.5 Cu. Ft. Commercial...
Washer won't spin
press in clips each corner with putty knife and lift top remove screws bottom front panel slide panel down and off ..locate pump. turn washer to spin and switch on if faint hum felt at pump more than likely plugged with something if pump is running fine ck for something in drain lines..most washers i would say lid switch but on those i believe if switch was bad wouldn't aditate either ck by raising lid ..if agitates with lid raised ck lid switch if not switch ok
Sep 13, 2008 | Westinghouse WWS833ES Super Capacity Top...
Kenmore washer 80 series 4 years old
my washing machine is not rinsing and spinning
Jan 20, 2008 | Kenmore 24032\24036 Top Load Washer
Grinding Sound
Sounds like the brakes have become noisy, just like in an automobile if they glaze over they start to squeak. This really wont hurt the machine but if you dissasemble the machine (or pay a professional at the most 1.5 hr labor since your washer is the best design and fairly simple to repair) and clean the brakes (basket drive assy) and the drum (part of the tub support)
Oct 15, 2007 | Roper RAS8445KQ Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
148 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
