Question about Genesis Onyx 29" Cruiser Bicycle
How do i find a rear coaster hub my bearing race broke
How do you remove a rear hub on a 04 kia sedona?
Call Kia with your VIN to make sure yours wasn't affected by the recall. You may be able to have that rear bearing replaced for free at Kia.
HUBCAP & OUTER BEARING REPLACEMENT PROCEDURE: 1. Remove the two (2) cross-tip locating screws on the brake drum.
2. Remove the brake drum.
3. Remove cotter pin and cover set.
4. Remove nut, claw washer, outer bearing and hub assembly.
5. Inspect inner bearing area in both hubs for any sign of moisture, corrosion, grease discoloration or contamination. If "yes" discard entire hub and replace with new assembly. If "no" proceed with outer bearing replacement below: 6. Carefully remove the outer bearing race from the hub. If the hub assembly is damaged then replace the hub assembly as a complete unit. (If inner seal is damaged while removing the outer race replace with new seal.)
7. Clean all contaminated grease from outer bearing cavity of the hub.
8. Install a new outer race into the hub using an appropriate race installation tool.
9. Apply grease MS511-33 WBG2 or equivalent to the hub assembly and the new bearing(s) especially to the shaded areas.
10. Install hub assembly, new pre-greased outer bearing and new claw washer on spindle. (Or alternatively, install entire new hub assembly, as supplied). Ensure bearings are properly seated then tighten hub/spindle nut, torque nut to 20-25 lb-ft (27-33 Nm.) Verify hub spins freely without signs of binding or excessive play.
11. Install new cover set and cotter pin; never reuse the old cotter pin.
12. Install new hub cap with Loctite # 5910(TM) or equivalent sealant to prevent moisture intrusion.
13. Install the rear brake drum using tapered locating screws.
14. Install rear wheels and torque lug nuts to proper specification. (65-79 lb-ft) (88-108 Nm, 9-11 kgm)
15. Lower vehicle.
Dec 30, 2014 | Cars & Trucks
Aseemble a coaster brake on a bicycle
Ken, Check the attached links,instruction and guides on removal and install coaster brake. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Coaster Hub Overhaul Pedal Brake Hub
How To Install Cog On Coaster Brake Hub
Bicycle Coaster Brake Repair and Service
Oct 01, 2014 | Husky 26"" x 2.125 Industrial Chrome...
Assemble rear axle for a bycle
There are several different varieties of rear coaster brake hubs. The most common is a "Shimano". The easiest way to tell you how to reassemble is by referring you to either Utube, put "shimano coaster brake in search box or go to SheltonBrown.com. Again enter the shimano in the search.
Sep 18, 2014 | Coaster Brake Hub Kit Chrome Bicycle Bike
I have a ford focus se 2001 and the two rear wheel barrings keep going bad! We replace them and they go bad every four months! The car has brand new tires and they continue to go out! Any ideas????
If this does not have sealed bearings then you have the old style bearing. The old style bearings are 2 parts, the cone and the race. If you only replace the cone, it will quickly fail because a race that is scored up is abrasive.
If the bearing race has not been properly installed it will be lopsided in the seat of the hub. There is also a process for installing the race, never, ever draw the race into the hub using the old or new bearing. You will scar, flatten, or bend both parts.
There is a process for packing the bearing with grease, and there is a front and back to the seal for the hub for these old style units.
Now if the bearing is a third style, a sealed trailer hub style that bolts onto the axle shaft, this style acts both as the spindle and a permanent bearing. Some Manufactuers go this route for simplicity, but some chose to have a removeable sealed bearing as yet another combination.
Do not understand if you are saying just the bearings go bad or the tires go bad too. Usually bad bearings cause the tires to go bad, not the other way around.
Sometimes you have problems with the rear Emergency brake pads, some need to be loosened and readjusted when the brakes are taken off to get at the hub.
Please rate my info.
Jan 27, 2013 | Cars & Trucks
Procedure for replacing rear whl brgs on a 2003 escape awd
4-Wheel Drive
  1. Before servicing the vehicle, refer to the Precautions Section.
  2. Remove or disconnect the following:
    • Negative battery cable
    • Rear wheel
    • Rear brake shoes
    • Rear halfshaft nut and loosen the halfshaft from the hub
    • Wheel hub and place it in a vise
    • Inner wheel bearing race from the hub
    • Antilock Brake System (ABS) sensor bracket and move the sensor aside, if equipped
    • Parking brake cable from the steering knuckle
    • Brake line from the wheel cylinder and support the knuckle
    • Lower shock absorber nut
    • Lower ball joint by holding the ball joint stud
    • Upper ball joint
    • Coil spring while noting the location of the insulator
    • Steering knuckle cam
    • Steering knuckle
    • Snapring and press out the outer wheel bearing race from the knuckle
      Rear hub and bearing
      Click to Enlarge
To install:
  1. Install or connect the following:
    • New wheel bearing into the steering knuckle
    • Snapring to the knuckle
    • Wheel hub
    • Steering knuckle cam and hand tighten the bolt
    • Coil spring
    • Shock absorber lower nut. Torque the nut to 85 ft. lbs. (115 Nm) for 2002-04 models; 129 ft. lbs. (175 Nm).
    • Upper ball joint. Torque the nut to 76 ft. lbs. (103 Nm).
    • Lower ball joint. Torque the nut to 76 ft. lbs. (103 Nm). Align the steering knuckle cam and torque the bolt to 85 ft. lbs. (115 Nm).
    • Brake line to the wheel cylinder. Torque the brake line bracket bolt to 15 ft. lbs. (20 Nm) and the brake line fastener to 11 ft. lbs. (15 Nm).
    • Parking brake cable to the backing plate. Torque the bolt to 16 ft. lbs. (22 Nm).
    • ABS sensor bracket. Torque the bolt to 80 inch lbs. (9 Nm), if equipped
    • Halfshaft nut. Torque the nut to 214 ft. lbs. (290 Nm).
    • Brake shoes
    • Rear wheel
  2. Fill and bleed the brake system.
  3. Check and adjust the wheel alignment as needed.
2-Wheel Drive
    • Rear wheel
    • Rear brake drum
    • Wheel hub nut
    • Wheel hub
    • Snapring
    • Wheel bearing outer race from the knuckle
      Rear hub removal
      Inner wheel bearing removal-rear hub/bearing
      Rear wheel bearing removal-2wd
      Rear wheel bearing removal-4wd
To install:
  • Wheel bearing in to the knuckle
  • Snapring
  • Wheel hub into the wheel bearing
  • Wheel hub nut. Torque the nut to 214 ft. lbs. (290 Nm).
  • Brake drum
  • Rear wheel
    Rear wheel bearing installation
    hope this helps if so send testimonial comment or even any other questions you have
Jan 16, 2011 | Ford Escape Cars & Trucks
How to replace rear wheel bearing on 2003 hyandia sonata
Hub & Bearing Removal & Installation To Remove:
  1. Release parking brake.
  2. Remove rear wheel assembly.
  3. Remove rear wheel speed sensor from carrier.
  4. Dismount brake caliper and support with mechanic's wire.
  5. Remove brake disc.
  6. Remove 4 axle hub mounting bolts. Special tool 09432-11000 (Typical) hyundai-08-00-6021.gif
  7. Using tool 09432-11000 (or suitable gear puller), remove tone wheel.
  8. Remove carrier.
  9. Remove stakes and remove flange nut.
  10. Support bearing outer race flange and press rear axle hub out.
  11. Using tool 09432-11000 (or suitable puller), remove inner race from axle hub.
To Install:
  1. Apply thin coat of grease to bearing contact surface and hub.
  2. Using and appropriate tool, press bearing into hub. CAUTION
    Do not press against outer race of wheel bearing.
  3. Install flange nut and stake nut until it meets concave portion of spindle.
  4. Install carrier.
  5. Use an appropriate tool to press tone wheel.
  6. Install hub/bearing assembly with rounded portion of outer race facing up.
  7. Install 4 hub/bearing assembly bolts and rotate hub to seat bearing.
  8. Measure wheel bearing starting torque with a spring balance or equivalent device.
    • Starting torque should measure 15.9 in lb (1.8 Nm) or less
  9. Install brake disc.
  10. Mount brake caliper.
  11. Install rear wheel speed sensor to carrier.
  12. Install rear wheel assembly.
Oct 28, 2010 | 2001 Hyundai Sonata
Loose rear wheel, believe it is the bearing. How do I repair it?
drum brakes you remove rear wheel- speed sensor-grease cap-flange nut-outer bearing-brake drum-inner grease seal-inner bearing-drive the bearing races out of the drum hub.to install -install the inner and outer bearing races.apply grease to the bearings and hub cavity.then you install the inner bearing -inner grease seal-brake drum-outer bearing-flange nut torque it to 159 to 192 ft lbs. THE REAR DISC BRAKE WHEEL BEARINGS-you have to remove rear wheel -wheel speed sensor-brake caliper and rotor-rear axle hub bolts-tone the wheel with tool 09445-21000-carrier assembly-nut after unstaking it-press out the rear axle hub-remove the bearing inner race with tool 09445-21000-remove the bushings from the carrier with tools 09453-33000b and 09545-21100.to install -press in the bushings to the carrier with tools 09453-33000b and 09545-21100- press in the bearings to the hub with tool 09221-21000.tighten the flange nut to meet the concave portion of the spindle-press in the tone wheel with tool 09221-21000-torque the nut to 191 ft lbs -install the hub and bearing assembly to the backing plate and torque the bolts to 88 ft lbs-install the brake caliper and rotor.install the wheel speed sensor if equipped.install the rear wheel.TO BUY THE TOOLS TO DO THE JOB.LOOK UP KENT MOORE TOOLS ON INTERNET.
May 30, 2009 | 1999 Hyundai Sonata
We are trying to replace my rear wheel bearing. Can anyone give any ideas how to get it apart?
here is how to replace it on a 2 wheel drive please do not forget to rate and comment about your experience today. 2-Wheel Drive
    • Rear wheel
    • Rear brake drum
    • Wheel hub nut
    • Wheel hub
    • Snapring
To install:
    • Snapring
    • Brake drum
    • Rear wheel
Apr 11, 2009 | 2005 Ford Escape
Noisy front wheel bearing
It is possible but i do reccomend changing the bearing races in the hub when you do it to prevent any premature wear on your new bearings. A new hub/rotor assembly will come with new races installed if that makes it any easier.
Dec 12, 2008 | 1998 Chevrolet C1500
Replacing rear wheel bearings on 1999 hyundai sonata
  1. for drum brakes with sealed hub(all one piece) remove lug nuts and wheel.
  2. spray penetrating oil around studs if there is a big phillips head screw visible remove it with impact driver/if not use big ballpeen hammer ,tap on flat of drum near studs(becareful not to hit them) until drum loosens(your creating a shockwave to loosen rust)
  3. once drum is off there are 4-bolts coming in from behind backing plate, remove them then hub should be able to be removed w/a little persuation from hammer.
with out sealed hub ,
  1. remove wheel
  2. remove dust cap,cotterpin,star washer(if equipped) do not re use cotter pin
  3. remove nut then washer, wiggle brake drum and front bearing will come out.
  4. put nut on shaft tighten 2-3 turns grab drum by sides and pull towards you this should remove drum leaving inner bearing/seal on shaft
  5. to replace reverse procedure making sure to pack new bearings w/grease(take drum and use long punch to remove bearing races, use race/seal installer to install new races
with disk brakes
  1. remove wheel
  2. remove caliper/bracket
  3. remove rotor
  4. remove 4-bolts from behind,tap old hub out
  5. reverse procedure
Jul 19, 2008 | 1999 Hyundai Sonata
Genesis Onyx 29" Cruiser Bicycle Logo
54 people viewed this question
Top Genesis Cycling Experts
robert
ray gallant
dante
Are you a Genesis Cycling Expert? Answer questions, earn points and help others
