Question about LG LSC091PMA Split System Air Conditioner
HOW TO REMOVE FRONT PANEL TO CLEAN MY FILTERS ?
I have to clen my fiters my AC is not coolling the room...?
  • 31 Answers
Is the problem not enough air or strong air flow that is warm? It may be much more than the filter. look at the air handler (fan unit). the filter should be at the end where the air enters the unit.
Posted on May 16, 2014
I need to now how clen a filter on my rp2100 digital
rp2100 is a pool heater by raypak it has no filter. you need to clean the filter whatever type it may be. sand/de filters can be taken apart and the medium takin out and replaced, while cartridge can be taken out and sprayed with a hose and put back.
Sep 28, 2015 | Pool & Spa
GE PTAC 5500 series cooling and then blowing hot
Cooling gas is missing. Call some AC service in near to fill it, ask more of them for price. Do not switch it on until you solve this to prevent higher damage.
Aug 28, 2014 | Heating & Cooling
How to clean and service the voltas vertis platina split ac?
The filter is behind the front panel on the indoor unit. Look for a thumb or finger grip at each side of the panel and lift the bottom of the panel out and up. The filters should be seen as soon as you lift the panel. The filters will slide out. Wash them under running water by hand. Don't scrub , vacuum or brush them. They are quiet fragile and any harsh scrubbing will damage them. Cheers.
Mar 27, 2014 | LG L1204R Air Conditioner
I was given a Haier ac. I installed the ac. It was running fine. I left the air on today and it was 94 degrees outside. The ac was on all day. I notice it was getting warmer in my room not cooler. I...
clean the filters and clean the condesor coil. You have an air flow problem or it may be low on charge which I doubt because these units are critically charged units. I would clean the coils and filters first.
Jun 21, 2010 | Haier Mechanical Air Conditioner HWF05XC7
The ac is dripping inside the room
Hello.
You need to clean out the drain pan.Also unit shold be tilted back a little so water will run outside.
Remove the front grill and using an old tooth brush clean out the bottom pan where water is laying.Also be sure the drian hole outside the unit is clear.
May 27, 2010 | Panasonic CW-C100AU Air Conditioner
How to clean the filters in split airconditioners
Check on top of the indoor unit. On some models, the filter will slide out from there without having to open the cabinet. On others you will need to pull on the top front and the panel will swing down (it will be hinged) and the filter will be behind that panel.
Mar 24, 2010 | Heating & Cooling
How do you clean the air filter?
Hi, in most small A.C, remove filter, either from side or bottom, and you wash with water until clean, you could use a little detergent, let it drain for a while, then put back. you can also replace them after a while, check your appliance store for new filters. good luck
Aug 03, 2009 | Fedders A6Q10F2B Q Chassis Room Air...
Samsung frontloading washer won't dispense fabric softner
clean filters in washer inlets on back of washer. take off hoses and look up inside of inlet, pull out the filters by pulling stright out on them. then fush backwards to get sand or whatever out of fiter
Dec 30, 2008 | Samsung WF337AA Front Load Washer
Washer is set to normal 40 mins runs to last two min than I get F
3 screws a;lone the very bottom of the front panel will remove the panel allowing ou access to the pump anbd clen out area, screws are a TORX 15 size
Dec 07, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Ac doesnt cooling a room.how much cost to repair?
Hello ufor23
Welcome
You said, your Ac doesn't cooling a room.how much cost to repair?
I need more info to advise you correctly!
What is the:
Model number and Year or age of your AC unit
Waiting for your response,
Huuum
Oct 12, 2008 | Heating & Cooling
LG LSC091PMA Split System Air Conditioner Logo
60 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
