Question about D-Link RangeBooster G WBR-2310 Wireless Router (WBR2310)
We just bought the d-lin wbr-2310....
We have two computer and they are only about 12 feet apart (from one bedroom to the other). The internet works fine on the comptuer where the d-link is set up, but for some reason it is not reaching to the other computer. There is only 1 bar and it's a very weak connection. Is there a certain "setting" we need to change in order to fix this problem?
Thank you.
Re: We just bought the d-lin wbr-2310....
I had this problem and it was a switch on the front of my laptop that disables wireless. I turned it off by mistake.
Posted on Dec 09, 2007
  • 193 Answers
There is no any other special settings if u keep the laptop very far it will not receive the signals >try this login to ur router and change the wireless channels use 1>or 11>it may help to improve the signal strength>and check with antena on the router weather its straight>rate me solved if its help full
Posted on Nov 04, 2007
0 characters
3 Points
Will the WBR-2310 work with my wireless internet service. I don't have DSL or Cable or Satellite. I have a wireless service from a local provider.
YES but you need a computer which will bypass your internet service from computer to router and then any wireless computer or any WAN enable device will access internet.
Share your wireless internet to Ethernet and connect with cable to router. WAN is now working.
But remember to configure your WLAN Router.
Dec 25, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
I need to download the installation cd
You do not need to install any software in order for a router to opperate.
Jul 22, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
Driver for intallation of Router D-Link WBR 2310
You can also check:
Met vriendelijke groet,
Alexander van Dijl
Tel: 06 45 430 985 Email:
Jul 05, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
Wbr-2310 error 112
Check your physical connection first. From the modem, it should be connected to the router's Internet port, then your computer must be connected to port 1 on the back of the router. Then do a power cycle, no need to run the setup CD. If it doesn't work, you need to manually configure the router. You may need assistance from D-Link tech support. Call their toll free number
Jun 20, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
I want to lower my security setting because I keep getting bumped off the internet. I bought the WBR 2310. will this help the problem? How do I do this.
by what you say, I don't think you configured the router. if you didn't configure the router then you need to take a look at the browser security setting. than may be preventing you from seeing the web page.
The WBR 2310 router configuration is complicated for home user.
Feb 01, 2009 | D-Link DI 514 Wireless Router (DI-514)
D-Link WBR 2310 works for laptop but not desktop with Windows ME!
Is your Desktop computer using a wireless connection? if not try placing the ethernet cord to the other ports and try accesss the Internet again.
Try also chekcing the two headed computer in your lower right screen if they have an X mark on it. make sure the two headed computer is enable.
Dec 10, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
D-link WBR-2310 Stop working
Sounds like a defective modem/modem failure if, it does not reset or if you take all of the other wires out and just leave the power in and none of the other lights go off then that is definitely a defective mode, I suggest either returning the modem to where you purchased it from or calling D link it should be covered under there warranty for replacement.
Nov 14, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
Wbr-2310 d-link
Follow these steps:
1.Type in Internet Explorer.
2.You might have to put Admin password to access the router which is usually admin and password field blank.
3.Go to wireless setting and change the password.
Dec 23, 2007 | D-Link RangeBooster G WBR-2310 Wireless...
D-Link RangeBooster G  WBR-2310 Wireless Router (WBR2310) Logo
97 people viewed this question
Top D-Link Routers Experts
 C. Dante
C. Dante
Are you a D-Link Router Expert? Answer questions, earn points and help others
