Question about Epson TM-U675 Printer
Paper out light wont go out
Tm-u675
What should I do, to not have much paper loss?
can u try printer with standalone pc
or with another single pc
Jun 30, 2014 | Epson TM-T88IV Thermal Printer -...
How do i turn on cutter
turn off and turn on again light goes off and it prints and stop without cutting the paper...TM 220a and TM 220b should come with auto cutters You have to unscrew the metal tab under the printer, ...
Jun 24, 2011 | Epson TM-U220 Matrix Printer
Auto cutter does not cut automatically
You have to unscrew the metal tab under the printer, you will find two sets of DIP switches. upper one is DWS 1 and the lower one is DWS 2. On DWS 2 you need to have jumper #2 ON. this enables or activates the auto cutter on printers. Good luck...
Jun 08, 2009 | Epson TM-U220 Matrix Printer
Espon TM-T88III Not Feeding or Printing
Does it have a manual insert for the paper?
If it does, try putting the paper in that.
If not, or if that doesn't work, I recommend trying to reinstall the printer and drivers.
If that also doesn't solve your problem, please post back.
Apr 15, 2009 | Epson TM-T88III (C420863)
Usb connect-it problems.
Do you power off before you connect all attachment
Dec 13, 2008 | Epson TM T90 Printer
Epsom TM-U220 Error Codes
From the manual its probably one of this item.
-printer temp is too high
-cover is not properly closed
-print head is not in the correct position
-paper cutter is not in the correct position
-paper jam
Try turning off the printer, remove the power cable, turn it on again for 5 seconds to reset it. Connect back power cable, press the feed button and turn it back on. The printer should do a self test, turn it off and on again after the self test. It should make the red light go away.
Oct 27, 2008 | Epson TM-U220 Matrix Printer
Service Manual
You can get one HERE but you need to register.
Jul 09, 2008 | Epson TM-U675 Printer
TM-U220 printer is not printing anything.
do a self-test first. Perform by holding down the feed button then powering on the printer. if it prints then it is not a printer issue, but a driver or cable issue.
May 09, 2008 | Epson TM-U220 Matrix Printer
Error light on a Tm-H6000II
Whats the pattern of the blinking light? can you pls describe...
what type of interface are you using, USB, SERIAL, PARALLEL, ETHERNET?
Apr 30, 2008 | Epson TM-H60000II Thermal Printer
Epson tm-u210pd paper alignment problem
Actually, the issue that you are having is with the paper, try changing the paper and use epson.
Sep 17, 2007 | Epson TM-U220 Matrix Printer
Epson TM-U675 Printer Logo
22 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
