Question about Cooktops
How to remove melted plastic from glass stovetop
A plastic bag was on one of the eyes and was melted when that eye was turned on by mistake. I want to know the best way to remove this from the eye.
3 Suggested Answers
  • 82 Answers
SOURCE: melted plastic (teapot whistle) on glass cooktop
Hello. I don't know if this will work but you could try getting it as cold as you can and maybe it will come off that way. If it were me I would use my refrigerant, but I am sure you don't have that. Who knows maybe ice will work. Now that I think about it, maybe you can carefully use some sand paper being sure you don't scratch the surface.
Posted on Dec 04, 2008
DeBruce
  • 145 Answers
SOURCE: plastic spoon melted on ceran stovetop. Used a
We Use Debruce Polish on all our cooktops. Debruce also works on stainless steel and polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
Posted on Aug 24, 2009
I have a kenmore glass surface cooktop. A plastic grocery bag was put on it while it was still hot. The bag melted a left a mess on the surface. How do I get it off?
It is glass so I would take a widget razor and try to scrape it. Or try to soak it with hot water then try. I have a kenmore top and it is strong
Aug 24, 2014 | Cooktops
Plastic spoon melted on ceran stovetop. Used a
Aug 24, 2009 | Whirlpool RCS3014 Electric Cooktop
Coil element on kitchen aid model ker1201 slow to
some of the coiled eyes have two coils(elements). one of the coils can burn into at any point around the element rendering it useless while the other can still work. when you lift the glass top you will see the elements are shaped like springs. the elements metal is very britlle.it is you have to replace the entire eye to fix it. the coil most likely had a very gap in the break and acted like a short making and breaking connection until the gap was too wide then nothing. easy fix. just replace the entire eye (power UNPLUGGED!!!) match the old wires with the new part as you take the old part off. I mark them even with a sharpie. it has 3 to 5 wires on that plug into the eye unit. estimated cost for the part online is about 40 to 65 bucks.
Jun 07, 2009 | KitchenAid 30 in. KECC506R Electric...
Light sill not go off, and eye stays very hot. Must cut off at breaker
Hi, You will need to change the switch for that eye. If you give me the model#, I can help you with part#.
THanks
Vic
May 15, 2009 | Cooktops
I left cillit bang on the stainless steel hob too long and it has horrible stains on it
Use appropriate solvents to remove the plastic. If you are skilled sanding in straight lines and matching the grain in your metal use 180 grit - 240 grit blending and using your eye. You could also use scotch brite #7447 purchase at an automotive store. This pad after solvent or used with it could remove the plastic or both sand and pad.
Debruce Polish is the best our there at maintaining a pristine finish and it is eco-friendly and odorless, we use this in all our properties AND the ceramic cook tops it is safe for glass. It also removes rust... we just love it. We find DeBruce polish at debrucepolish.com.
May 09, 2009 | Thermador PSC364GDZS Gas Cooktop
Stovetop stays hot when burners are not on
Is it a glass top. If it is, glass will absorb the heat. It will cool off after some time. That is normal.
Dec 18, 2008 | Maytag 30 in. Admiral LGC1330 Gas Cooktop
Melted plastic (teapot whistle) on glass cooktop
Nov 28, 2008 | Jenn-Air JED8430 Electric Cooktop
Gas stovetop burner - continuous clicking
WHEN CLEANING YOUR BURNERS YOU HAVE PROBABLY MOVED THE IRON TOPS-READJUST AND YOU WILL FIND THE CLICKING WILL STOP.
Sep 18, 2008 | Cooktops
Plastic melted on my glass cooktop
didi you try heating the burner slightly to soften the plastic a bit before trying to scrape off, cant see any reason why that wouldnt work, using a razor blade held flat will scrape just about anything off of the glass tops!
Apr 29, 2008 | Jenn-Air JED8430 Electric Cooktop
Frigidaire glass cooktop
first try putting pans on top and see what they do you should not operate these type of eyes with nothing on them as you will burn out the sensors in the eyes if nothing is there to reflect the heat back to them if it does the same thing with pans on them then you will have to replace the elements
Feb 11, 2008 | Frigidaire PLEC30S9EC Stainless Steel...
Cooktops Logo
61 people viewed this question
Top Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
