Question about HP Color LaserJet 2600n Printer
How do I change to default printer to print black only?
How to change default copy and print setting to black instead of color
It is different for every brand and model. Post more detailed information about your printer and someone may be able to help.
Aug 31, 2014 | Office Equipment & Supplies
Set xerox 7845 to black as default print color
You can always look for answers to your Xerox questions at www.xerox.com/support .
Default the Print Driver to Print in Black and White Only for a Microsoft Windows 7 OS:
The steps below can be used to restrict color printing through the print driver.
NOTE: This solution requires administrative permissions and may require the assistance of a System Administrator.
Open the Printers, Printers and Faxes, or Devices and Printers window. See the Related Items below for additional information.
Right-click on the printer, and then select [Properties] or [Printer Properties].
Click on the [Administration] tab.
Expand the [Configurations] section.
Enable the option for [Black and White ONLY].
Click [OK]. The driver will now have Black and White printing as the default and locked so that the option cannot be changed.
Default the Print Driver to Black and White for a Microsoft Windows OS:
Open the Printers window on the computer.
Right-click on the required printer, and then select [Properties] or [Printer Properties] depending on which operating system is being used.
Click on [Advanced], and select [Printing Defaults].
Click on the [Image Options] tab.
Under Color Correction, select [Xerox Black and White Conversion].
Select any other required driver default settings.
Click on [Apply].
Click [OK] to save the settings.
Close the window.
Default the Print Driver to Black and White for MAC OS:
Launch an application, preferably not your browser, that you can print from, e.g. Microsoft Word
  1. Select File -> Print
    1. Select Xerox Features where it says Copies \& Pages
    2. Select Color Options from the drop down labeled Paper/Output
    3. Select Black and White (Black and white printing on the Xerox 7845 costs less.)
    4. On the Presets drop down, select Save As and enter a name, e.g. "Black and White" if you print to multiple printers, check the All Printers
    5. Click OK to save this preset
Now you can test printing by clicking Ok to the print dialog.
Sep 30, 2013 | Office Equipment & Supplies
The priter goes through the motion as always for printing but a blank piece of paper comes out. I have cleaned the print head but It still does the same thing. Do you have any suggestions that I might...
If you are printing using a color (not "black cartridge only" ) driver, yes, the printer won't print because it uses a "process black" when you use a color driver.
In other words it creates black using the 3 colors, and doesn't actually touch the black cartridge.
You will need to change the default driver to one that you create.
go into control panel, hardware and sound, devices and printers (win7)
right click the officejet 6500 (not the fax driver) and click printer properties
click the advanced tab, and click printing defaults
click the fast economical printing template.
Change "print in gray scale" to Black Ink Only
Click "save as" and name the profile "black draft"
click the newly created "black draft" profile, and click APPLY and OK
This will now be your default, and it will print in black and white while the color cartridges are empty.
Jul 29, 2011 | HP Officejet 6500 Wireless All-in-One...
Change default to black printing only
here is what you will need to do to get this to work.
first while on the main copy screen change the setting from color to black like you want it.
then you will need to goto the additional functions button and under copy settings you will need scroll down to the second page.
there you will want to hit the standard setting button then click the store button, then click yes... now it will default to black copying.....
now if you want to it to print only in black you will need to go to the printer window in windows....
control panel-----printers----then select irc6800 printer
then right click on the printer icon and goto properties---- then printer perferences---- then you will need to find the color tab and set it to grayscale printing.. then click apply then ok and exit out.... now hopefully this will set your print driver to default to black and white.
sorry i don't have the drivers loaded on my computer for me to look at to tell you exactly how to change it
Apr 15, 2010 | Canon imageRUNNER C6800 Copier
How do I program the printer to only print in blck/white
Any default (or normally used) settings, can be made by changing the Printing Preferences for that specific printer.
1) Find the printer...ex: [Start]--> [Settings]--> [Printers and Faxes]...then [right-click] on the printer name/icon.
2) The pop-up menu that appears should list an option to select called, "Printing Preferences".
3) Under the [Paper/Quality] TAB, you can select "Black and White" (instead of the normally default, "Color").
4) Make sure to click OK, and that printer should (by default/ normal) print in B/W now.
--- you can change this to "Color" in Print Setup...but it is temporary for that printing job, and should revert to it's default state, afterwards.---
-Printing Preferences- is where any changes you make will become the Normally used setup.
.Hope this helps
Mar 10, 2010 | HP DeskJet 932c InkJet Printer
Changing ink default to BLACK
Not possible.
Epson uses the black cartridge mostly, but also adds color to the black printing in order to keep the color inks from drying in the print jets on the printhead.
They also make lots of money that way...
===sorry===
Sep 14, 2009 | Computers & Internet
HP L7680 prints red instead of black
Check your default ink setting if red is default then change it and make black ink default settings.
Thank You
Jul 28, 2009 | HP Officejet 5610 All-In-One InkJet...
Can I set default printing to black and white for color laser printer?
Yes. Any printer's default options can be set as desired. Open the printer's properties (Start/Control Panel/Printers/right click the printer and left click Properties), and change the setting as you wish, then click OK. Those settings should be used each time you use the print command, unless you change the settings for that particular print job.
Hope this helps, and please rate my advice, good OR bad.
Feb 05, 2008 | Office Equipment & Supplies
HP Color LaserJet 2600n Printer Logo
26 people viewed this question
Seeker5211
Seeker5211
