Question about Epson Stylus C86 InkJet Printer
On Epson C86 only the black and blue will print, even after clean
The ink cartridges are new. Nozzles are clean. Any ideas?
    Sergeant:
    Champion:
  • Epson Expert
  • 387 Answers
Remove the cartridges and check to see if the ink supply port [on the bottom] are pierced. If they are then the cartridges are old, empty, dried out or faulty. Get a CISS for your printer. It will save you TONS of MONEY, never change a cartridge again and it will pay for itself in a month.
http://www.inkproducts.com/ink-store/
Posted on Jun 23, 2009
Test page shows there is ink, but when I attempt to print a document it is barely the ink is not dark at all
It sounds like the print head nozzles are clogged. Check your online user's manual (if it is not on the install disk that came with your printer) for the cleaning procedures. Here's a link if you can't find it: http://files.support.epson.com/pdf/xp400_/xp400_qr.pdf
go to the section, "Checking the print head nozzles"
Nov 23, 2013 | Epson Stylus C86 InkJet Printer
I replaced all of the cartridges with Epson, but the black won't print. After some nozzle checks, black is getting low and STILL no black printing occurring... what going on? Now the other colors are...
Nozzle cleaning uses a lot of ink, that's probably why the other ink cartridges are registering low on ink. Are you using refilled cartridges or brand new? Also, have you had the cartridges for awhile? I've found that the nozzles can become clogged either from not using the printer for awhile or because it's a recycled cartridge that didn't have the nozzles cleaned before it was refilled. When that happens, unfortunately, sometimes it takes a lot of cleaning cycles before the printing comes back. Let me know more about the cartridges you have.
Mar 03, 2011 | Epson Stylus CX7400 AllinOne InkJet...
I've just replaced the black ink cartridge for my Epson Stylus TX100, ink level is ok as the indicator shows. But i get blank prints for black, other colors are fine. What's wrong with the black ink...
There is nothing wrong with the black ink. Just run the head cleaning for better printing.
1. Go to printer and faxes
2. Right click your printer ( Epson Stylus Multifunction Printer/ Copier/ Scanner InkJet)
3. Click printing preferences
4. Click Maintenance Tab
5. Click Head Cleaning
6. Run head cleaning for 5 times then try printing.
Nov 15, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Only black and blue will print on test page; yellow and magenta does not. Ink was just replaced.
Did yellow and magenta print OK before the previous cartridges ran out? If so, it looks like your new cartridges are not working properly. Try another yellow and magenta cartridge - you can re-use the previous cartridges if they turn out not to be faulty. If new cartridges don't solve the problem, you can try soaking the print head, in case you have nozzles blocked with dried ink for some reason.
Turn the printer on, and as soon as the print head moves out of its parking position, pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head by hand fully into its parking position so that the cup full of fluid comes up over the print head. Do not turn the printer on at any stage in this process. Leave this for at least 24 hours, then turn the printer on and try a head clean/nozzle check again. If you get any magenta/yellow ink on the nozzle check, then there is hope! Repeat the head clean/nozzle check process 2 or 3 times, but not more. Leave for 24 hours for any air bubbles to disperse. If nothing, repeat the soak process once more. If still nothing, post a new comment detailing what you have done and the results.
May 04, 2009 | Epson Stylus C86 InkJet Printer
Nozzle Clogging & Black Cartridge Leaking
Hi e-margaret. There's a bit of confusion here. Horizontal banding is due to LACK of ink flow to the paper. "Splodging" is due to too much. The former can be due to blocked/faulty print head nozzles or a faulty/empty-ish cartridge, or some less common problem like the waste ink pipe blocked. The latter is usually due to a leaking cartridge.
The first job is to mop up ink slopping around under the print head. Cut some strips of kitchen towel and fold them into 3 layers so you have a strip about 2 cm wide. Place them on the print head track. Turn on the printer, and as soon as the print head moves, pull out the power cord from the back of the printer. Now you should be able to move the print head carefully by hand too and fro over the towels. Repeat this with clean towel strips until most of the surplus ink is cleaned up. Remove the towel strips, replug in the power chord and switch the printer back on. Do a head clean cycle and nozzle check 3 or 4 times. If the nozzle check output looks OK, try a test print of a text document
If things are still not OK, report back on what happens in a new comment. If my instructions are not clear enough, please post a new comment asking for clarification.
Apr 22, 2009 | Epson Stylus C86 InkJet Printer
Printout
HI-
Run head cleaning cycles several times by pressing and holding down the ink button. it will make a noise as it attempts to clean the nozzles of your printer.
Hope this helps
Oct 29, 2008 | Epson Stylus C86 InkJet Printer
Epson Stylus C86 Printer Ink Refill
The chip that is located on the cartridge has to be reset also. You can take it to a ink cartridge replacement store. They will reset the chip when they refill the ink, however, Epson doesn't recommend this of course. It is cheaper this way.
Aug 15, 2008 | Epson Stylus C86 InkJet Printer
Printer will not print
Ren, Does the printer show the cartridges have been changed? If the printer doesn't recognize the new cartridges, turn off the computer and unhook the printer, unplug the printer from the computer and electric. Turn on the computer so it boots without the printer hooked up,(2x) then shut down again. Rehook the printer and plug it in then reboot the system. http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=41661&prodoid=46048263&infoType=Downloads&platform=All You can also find updated drivers from epson from here. Good Luck, Tim
Mar 06, 2007 | Epson Stylus C86 InkJet Printer
Not printing
The printer determines the amount of ink left in the cartridge by counting the number of ink "shots" when printing, head cleaning etc. This information is stored in the "chip" on the cartridge. Thus, it is not an actual measurement of the ink left, but an estimate calculated by subtracting the total shots from the original full ink quantity. This estimate can sometimes be grossly in error, usually due to a cartridge replacement not being carried out correctly. However, for all four cartridges to be suddenly out of ink is odd. The cheapest way to check this out is to buy a chip resetter on e-bay (currently one for sale at £3.25). Reset all your cartridges to "full", and see if the printer will now recognise them as full. If so, you can buy a new set OK. If the printer still says the cartridges are empty, post a new comment to this effect and we can provide further help.
Nov 17, 2006 | Epson Stylus C86 InkJet Printer
Epson Stylus C86 InkJet Printer Logo
131 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
