Question about Techno Source Kurio Kids Tablet With Android 4.0 - 7 Inch 4 Gb
Why wont my click n kids tablet charge. you plug the charger up and and it just blinks
My kocaso tablet wont turn on
Hi. I'm guessing you've had it on the charger. It can be worth checking the charge cable is correctly plugged in and transferring power. After that, with the tablet plugged into the charger, hold the power button for 10 seconds... then, click the volume up once. If it turns on, you might want to keep it charging for a while.
Sep 30, 2016 | Tablets & eReaders
Bought 2 tablets for our kids and the chargers don't work?? HELP
If they are after market chargers then they are probably not putting out the proper voltage... if they are proper chargers it could be the wall plug is reverse polarity... a 5 dollar wall plug tester which looks like a mini charger and bought at any local hardware store can tell you that with its 3 light system.... be surprised how many are wrong in a house.. if that isn't it the charger maybe shot... unlikely two different chargers are bad though... more likely a second hand pad with dead batteries... which means a trip to the repair Depot. But if they are stolen ...
Apr 06, 2016 | Tablets & eReaders
My meep tablet wont charge
try with a new charger,& cable or check charging connector in tab may be faulty
Jan 23, 2015 | Oregon Scientific MEEP Kids Tablet
My tablet wont charge what can I do I try to plug in charger but won't charge the battery even bought another charger still dont help
Most likely you are using an aftermarket charger. You may want to purchase another or buy and OEM charger.
Jul 09, 2014 | Polaroid 4.3" Internet Tablet
Kurio 7s won't charge
Is it turned on when in charger. May need to be turned off before you plug it into charger Then it should show a battery icon on screen showing it is charging ..
Jun 13, 2014 | Techno Source Kurio Kids Tablet With...
RCA tablet wont charge
Possible charger damage.
If you know someone with a charger you could use, you should first plug their charger into your unit to see if it works, if not, plug your charger into their unit.
If your unit will not charge with new charger, you may have serious damage, if the other will not charge with your charger, your charger is broken.
Jan 13, 2014 | Tablets & eReaders
Screen has began to flash on and off and wont charge
I had a similar situation with my pipo s1. After further investigation I found that the jack the charger cord plugs into went bad. My charge light wouldn't stay on unless you held the charger plug in a particular position. The jack is hardwired into one of the circuit boards and to replace the circuit board was half the cost of the whole tablet. I junked it and bought a kindle fire. Better quality and longer lasting battery.
Dec 12, 2013 | shop-fun PiPO S1 7 inch Tablet PC Android...
My kids broke my charger and now the car charger wont work cant charge through computer why
make sure the drivers are installed and it is in charge mode only on the phone
Nov 07, 2013 | Tablets & eReaders
Tablet wont charge
The charger socket has probably broken its solder connections, happens because of repeated movements straining it by using it when the charger is plugged in. Have you tried charging it through the mini usb socket?
Jun 05, 2013 | Samsung Tablets & eReaders
Motorola xoom wont charge
this is very common/same problem lots people having with their tablets, but i recently found solution for it.... try the following.
first connect ur charger to the table as you normally would do for charging, then connect the tablet to the computer through the USB wire (make sure charger and usb wire both must connected to the tablet) and it should start charging.... this seem awkward but will 100% work try it and see it urself
Feb 03, 2013 | Motorola Mobility XOOM Android Tablet
Techno Source Kurio Kids Tablet With Android 4.0 - 7 Inch 4 Gb Logo
Top Techno Source Tablets & eReaders Experts
David Payne
David Payne
Ngoro
Ngoro
ray gallant
Are you a Techno Source Tablet and eReader Expert? Answer questions, earn points and help others
