Question about Toys
Repair brakes for terex backhoe 760 - Toys
Service manual for a terex tc 550 compactor
how old it that
may have to contact Terex themselves
http://www.terex.com/construction/en/products/loaders/index.htm
not any e manual type copies
no ideas why it isnt on the Terex repair/service manual site
http://automanual.co/cars/terex-Repair-Manual.htm
May 17, 2016 | Kitchen Appliances - Others
We are trying to bleed brakes on CASE 426C Backhoe. But for some reason it is not working. What can I do to get it right?
Probably blew the master cylinder when you lost the brakes.
When an older vehicle's pedal goes ALL the way to the floorboards,the master cylinder "sees" crud at the end it never touched B-4.The seals have been damaged. Possible to get a kit to fix it but don't. Get a rbld. master and start over. Done.
Nov 11, 2014 | Toys
Can't swing the backhoe arm left or right with the controls
The travel lock is either in place keeping it from moving in transport or there is something wrong with the hydraulics. Look for a push button release. The other thing is the stabilizers have to be engaged
Jul 21, 2014 | Jcb Bruder JCB Loader Backhoe
I have a jcb 214s will operate forward&reverse in any gear for approx. 20 minutes then seizes up and won't go either direction. Replaced layshaft-mainshaft valve and solenoids, replaced 4 wd valve and...
Old.
This forum states they are crap
http://www.heavyequipmentforums.com/showthread.php?540-jcb-214s-owners-opions
You should try asking there for more help.
Oct 28, 2013 | Jcb Bruder JCB Loader Backhoe
Backhoe hydraulic cylinder repair
Get a kit and rebuild cyl.
Aug 28, 2012 | Ford 555 backhoe
I need to know where the bleeding screw for brakes on jcb214e backhoe
most of those type of equipment have inboard brakes in the axle tubes of the rear gear assembly i.e. follow your brake lines from the master cylinder to the rear axle assembly,the lines usually go in and to a caliper and another line comes out to a bleeder tip nipple ,some models are actually inside the axle tubes them selves requiring disassembly of the wheels ,axle tubes etc. until you get to the inboard rotors and calipers ,major work for such a minute ordeal this is done to keep the system protected believe it or not,i would obtain yourself a model repair manual if i were you or you could also go to jcb and ask them for a photo copy of the entire brake hydraulic system
Feb 28, 2012 | Jcb Bruder JCB Loader Backhoe
Jsb will go forward and back for few seconds and then dont want to go forward and back
there will be oil leak or malfunctioning in the front & reverse gear ratio..its better to get ir repaired by a Mechanic
Thanks for rating Good luck
Jan 18, 2011 | Jcb Bruder JCB Loader Backhoe
Radiator water in oil of my John Deere 310A backhoe. What steps do I take to repair.
You have either a blown head gasket, cracked block or craacked head. Major work ahead. Hopefully, the water didn't mess up your main bearings.
Sep 01, 2009 | John Deere Kids Tractor Loader & Backhoe...
Transmission on Backhoe
I think you need Check your Transmission Pressuer of your machine. After That Change Recormanded Transmission Oil & Right Quntity. Transmission Pressure Should be 10-12 bar.
Jun 14, 2009 | Bruder Jcb 4CX Loader
Toys Logo
75 people viewed this question
Top Toys Experts
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
