Question about Kenwood Car Audio & Video
How can i get kenwood manual for KL999x speakers
Need wiring diagram for Kenwood KDC-X679 CD receiver for my 1997 Chevy truck
The manual for the Kenwood Excelon KDC-X679 has the wiring diagram for the connections to the car/truck on page 33. Crutchfield has the manual on the product page: http://www.crutchfield.com/S-FpCU7SY0yQm/p_113KDCX679/Kenwood-Excelon-KDC-X679.html . (Click on the Details tab.) The direct link to the manual is http://pdf.crutchfieldonline.com/ImageBank/v20050828082600/Manuals/113/113KDCX679.PDF .
Kenwood also has the manual on their support page: http://manual.kenwood.com/en_contents/search/ . Just enter the model number. On this site, you can find the manual is several languages. The direct link to the English version of the manual is http://manual.kenwood.com/files/B64-2764-00.pdf .
I hope this helps.
Jan 30, 2016 | Kenwood Car Audio & Video
Hooking up kenwood cd player in a 2000 silverado but the wires aren't labeled coming out of the cd player. Pls help
If you use a wire harness adapter, you just have to match the colors from the Kenwood plug to the wires in the adapter. No guesswork.
Kenwood uses the CEA standard for car audio wiring:
Yellow: 12VDC constant power
Red: 12VDC key-switched power
Black: Ground
Orange/White: Illumination
Blue/White: Remote output for amp turn-on
Blue: Power antenna activation
White: Left front speaker (+)
Gray: Right front speaker (+)
Green: Left rear speaker (+)
Violet: Right rear speaker (+)
Each wire with a black stripe is a negative speaker output.
You can download owners' manuals from Kenwood's web site.
Jul 16, 2015 | Kenwood Car Audio & Video
Wiring speakers
look into the manual.
http://manual.kenwood.com/files/521ea614af4ac.pdf
if u want to use your factory speaker wiring you will need to run speaker wires back to the head unit usually where all the speakers are connected.
Sep 29, 2013 | Kenwood X700-5
I have a Kenwood vr-405 and for the most part it works. I have been noticing that one front speaker is quite a bit louder than any other speaker. I have tried to adjust it many times and it seems like...
Maybe you should first isolate the problem to the receiver or the speaker by swapping the front speakers with each other to see if the loudness stays with the channel of the speaker.
Or, the acoustics of the room just make that speaker seem louder at the listening position. Try taming it with the adjustments provided in the receiver.
The manual can be found at http://www.retrevo.com/s/Kenwood-VR-405-Receivers-review-manual/id/480ag202/t/1-2/
Aug 18, 2010 | Kenwood VR-405 Receiver
How to Fade individual speakers on the Kenwood
Hi.
Use the audio control settings. Here an extract from manual:
Here the full manual:KDC-4020 KDC-3020 KDC-2020 KDC-1020 KDC-1020S.
Regards.
Ginko.
Jun 07, 2010 | Kenwood KDC-2025 CD Player
Radio
Hello george_nutti,
The model number you posted is for a center channel speaker which has no controls, and not knowing the exact model number it's difficult to be specific.
Some Kenwood KDC models allow you to select one of 3 "tuning modes", 1) AUTO1 - Automatic search for stations; 2) AUTO2 - Search Preset stations; 3) MANUAL - Normal manual tuning control. If your Kenwood is one of these models, you need to set the tuning mode to MANUAL. For Kenwood Excelon HD receivers, direct access tuning is done by using the included remote. 1) Press DIRECT button on the remote; 2) Press number buttons to enter desired channel number; 3) Press DIRECT button again to exit direct tuning.
Hope this helps.
Sep 08, 2009 | Kenwood KSC-310CCS Center Channel Speaker...
Car Audio & Video Logo
32 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
