Question about Panasonic MC-V5716 Upright Vacuum
Not enough suction for Panasonic MC-V5716 upright
Motor protector is admitting loud noise as if blocked -motor runs -roller and belt all run fine. Has suction but not enough hose gets clogged or even short hose gets clogged-do I need to change the motor protector
  • jemrey Dec 25, 2007
    I've got the same problem with my Mc-v5706. Nothing seems to be wrong - replaced belt, bag, changed secondary filter. Driving me crazy.
    President:
  • 1,673 Answers
Probably not the motor protector, its function is shut off the motor if it overheats. Most likely you have a clog or partial clog in the inlet down by the brush roll, or it is in the hose. But if the motor is running, and suction is low, with no clogs, then maybe the motor is running at a slower speed and will have to be replaced.
Posted on Feb 13, 2008
No suction
I presume the motor is running, take the front brush roller off and check the fan is still intact. Possibly broken fan.
Mar 30, 2014 | Kirby Ultimate G Bagged Upright Vacuum
Panasonic ecomax carpet bar won't drive
The first thing to check is make sure the belt is not broken or stretched. It is possible that a vacuum cleaner may need a new belt even if you just bought it. It may have been a year or more since it was assembled and had the belt installed. It may have spent some time in a warehouse and on the store shelf before making it to your home so the first thing to check is always the belt. If it has a stretch belt they must be stretched to almost twice their original length when installed on your vacuum and they lose elasticity. The rule of thumb in the vacuum industry is belts should be changed every three months for proper agitation. If the belt is not broken or stretched check to see if there may be something stuck in there preventing the brush roll from spinning freely.
Oct 24, 2013 | Panasonic Vacuums
Bissell 6591 operating twice as loud as before.
Hey Mike! Excessive noise can be contributed to dirty filters or clogs. Here's a quick link to troubleshooting steps to assist you.
http://www.bissell.com/FAQDetail.aspx?id=1421&cid=ccsocial
Feb 03, 2013 | Bissell 6591 Power Trak Revolution Bagless...
Hi, i have a panasonic eco max, the brush has stopped going round, the belt is as new and brushes clean.suction good from hose. Any ideas please? thank you
The brush on this model is controlled by the on/carpet/floor switch and will only work in the carpet position. If the suction motor is running then it could be the roller brush motor, but it's more likely to be the microswitch which stops the brush motor when the handle is returned to the upright position.
Dec 03, 2012 | Panasonic Mc-Ul594 Eco Max - Bagless...
MOTOR RUNS WITH NO VACUUM PRESSURE
Sounds like the belt should be replaced. It maybe turning the brush, but if you smell burning rubber, its slipping and not turning the brush with as much force as it should. Changed the belt. Check the air suction path. If the suction is reduced, something is blocking it. Check the bag (if it has one) and all filters. If the machine picks up any liquid, it will reduce the air flow through the filters and bag. Change the bag and filters. If this is an upright, you may find caked on dirt under or in the area of the brush.
Nov 28, 2011 | Hoover Vacuums
Model #3760-2 Bissell upright vacuum- making very loud noise when running. Cleaned all filters- no difference
Is the noise coming from the belt area, ie. beater bar, or does it sound like it is coming from the motor itself? It is possible there is something caught in the brush roller.
When you turn the roller off, does the noise go away?
Dec 20, 2010 | Bissell Vacuums
Motor runs, but noisey, smells hot, brushes don't turn
First you need to check why the brushes are not turning, this could be due to a lack of suction, which means the smell of heat and excess noise is due to a faulty motor, this can also be tested simply by testing the units suction power.
A faulty motor is the most comon problem when it comes to smells of heat or 'ozone' as well as excessive noise. Good Luck.
Apr 12, 2010 | Hoover H3030 FloorMate SpinScrub 500...
I have a panasonic mc-ul975 vacuum that works great when working properly. the airflow through the canister seems to stops once the aero blast technology is done running which causes the vacuum to not...
Hi there. In Panasonic vacuums2.gif, there is a thermostat protection on the motor. It will automatically shut off the motor if there is no airflow through the motor. This is typically caused by a clogged hose. Typically, if your dust container is that full, there could be backup in the hose. Or the dust container being too full could also or otherwise be the problem. Check your hose for blockage, let the machine cool off, it should start up again
Aug 30, 2009 | Panasonic MC-UL975 Upright Vacuum
Loss of suction in my Hoover Windtunnel bagless selfpropelled upright
Did you check the dirt inlet by the brush roll, filters ok, they should be replaced once a year. Belts can look fine, but if they are a few months old, I am sure they have stretched and the brush roll will not turn like it should under load. It is possible that the motor isn't running up to speed, thereby reducing suction.
Mar 11, 2008 | Hoover Self-Propelled WindTunnel Bagless...
Panasonic MC-V5716 Upright Vacuum Logo
222 people viewed this question
Top Panasonic Vacuums Experts
Jim Parker
Jim Parker
Joseph Hoffmann
Are you a Panasonic Vacuum Expert? Answer questions, earn points and help others
