Question about Konica Minolta bizhub 350 All-In-One Laser Printer
Comment resoudre ce probleme youtube c2557 - Konica Minolta bizhub 350 All-In-One Laser Printer
  • Konica Minolta Master
  • 6,161 Answers
Might want to have the developer replaced and drum/cleaning blade normally done all together, then run the F8 procedure and make sure the counters where cleared. Did you recently replace the drum and the developer if so did you clear the counters for the drum and developer, FIRST? IF not then the copier thinks the new drum and new developer are old. The copier works on the counters that is how it knows it got a new drum and developer. Get new developer and a new drum and have it installed correctly. Counters are clear before the unit is yanked out of the machine, then you remove the image unit/drum unit replace the developer/drum and cleaning blade. (DO NOT USE A VACUUM CLEANER WHEN REPLACING THE DEVELOPER static electricity can destroy the sensor located below the developer unit. Then reinstall and RUN F8. Make sure the fax line and Ethernet cable is removed can't print anything until the F8 is run. Or you will start all over again with new developer and a new drum.
Posted on Dec 29, 2015
Comment resoudre le probleme suivant:121.07 service engine error
Consult le manuel de ton imprimante. Il doit contenir une section intitul?e En cas de probl?mes.
Oct 10, 2015 | Lexmark Office Equipment & Supplies
COMMENT RESOUDRE MON PROBLEME DE COULEUR SUR MA TV
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Translation option can be pulled out from its right side gadget bar.
Jul 03, 2014 | Samsung Ps43d490 43" 3d Plasma Tv Pal/ntsc...
Comment resoudre l'erreur 03130031-2618
Here's a troubleshooting guide. The error has something to do with the voltage to the carriage unit. http://www.tdo.se/pdf/Scania/iPF-Troubleshooting-Guide-Level-2.pdf Don't know if this will help, but this PDF is pretty detailed in troubleshooting.
Jun 19, 2014 | Canon imagePROGRAF iPF755 Large Format...
How we play flv video in samsung b3410 mobile?
Ok, I would love to help,
Please respond to this using COMMENT or REPLY
Have you tried to use windows CE media player yet?
Jan 13, 2011 | Samsung B3410 Cell Phone
My NEC IT 2530 copier machine is coming up with an malfunction detected call for service C2557. I need to get the copier machine working.
C2557= ATDC sensor failure.
Did you run the machine out of toner? Or if you or a service tech recently replaced the developer then you need to perform the F8 adjustment in the service mode. Either way you will need a service technician.
Oct 20, 2009 | Office Equipment & Supplies
Error code E4 for riso ks800
riso ks 800 error code c-7
Dec 06, 2008 | Riso RZ390 Duplicator
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
