Question about Minolta Maxxum 300si 35mm SLR Camera
Minolta 70-210 af lens on alpha 100 dslr chatters for 15 secs when I turn camera on. Anyone know what's wrong?
And the auto focus function doesn't work. It focuses well in manual mode, but still chatters for 15 seconds when I turn camera on
  • 531 Answers
Communication contacts needs to be checked.
Posted on Jul 31, 2014
5 Suggested Answers
SOURCE: Minolta Maxxum 7000i
Is there a micro focus switch on the lens
On my lens if switch to Micro Mode the Auto focus is disabled, Also it is a stupid question but you are using a AF lens and not a xi series or manual focus lens.
Posted on Dec 14, 2007
cammedic
  • 667 Answers
SOURCE: lens
Sorry, the mounts of Minolta manual focus lenses are different than their auto focus series. Sigma, Tokina and Tamron all make compatible zoom lenses to fit the Maxxum series cameras
Posted on Dec 30, 2007
SOURCE: Turn auto focus off?
On the left side of the lens right below the silver lens release button there should be a grey switch with the initials "AF" and "M". Switch it to "M" for manual.
Posted on Mar 11, 2009
cammedic
  • 667 Answers
SOURCE: i have a minolta, 35 mm camera with automati
Check the switch on the side of the mirror box/mount. It is located below the release button to remove the lens.
Posted on Jan 04, 2010
I have a sony a 230 camera the halfway focus won't work anymore, any fixes?
Check that the camera or lens AF/MF switch hasn't moved to MF.
This will turn off the auto focus on the camera.
You can see them both in this photo.
Jan 11, 2015 | Sony Alpha DSLR-A230 Digital Camera
I love my Minolta camera. I want to get a digital. I would like the same kind of camera. Can I get one and use my zoom lens that I already have. I need a camera that is update to use a USB cord to...
if you want to use your current lens, then your only new choice is any of the Sony Alpha dSLR's as they use the Minolta AF mount.
However... your lens will not operate correctly. You may have to manually focus and the auto iris stop down might not work. The only way to find out in advance to to take your lens along to a Sony stockist to try it out, but phone them in advance to ensure that they have a display model with a freshly charged battery.
You will definitely find that your 35mm film lens will have a different angle of view; the smaller sensor on the dSLR means that your lens will appear to have a 1.5x teleconverter fitted. You'll also likely find that your lens will be optically inferior to the modern offerings simply due to greater advances in computer aided design and materials technology, although the actual build quality of your lens may well be better.
On balance, I'd suggest that you continue to use your Minolta 35mm camera and if you buy a digital SLR system just make a clean break and pick whichever system suits your needs best. Unless you already own late model 35mm AF Nikon or Canon gear there's really very little to be gained by trying to use your old equipment on the new dSLR body and potentially a lot of handling issues to interfere with taking photos.
Jan 05, 2010 | Minolta Maxxum 300si 35mm SLR Camera
When the camera is turned on, the lens vibrates briefly for 4 sec.It doesnt matter if its in Auto or manual focus. It happens while turning off the camera as well. I have sent the camera to the Sony...
It is likely to be an issue with the auto focus in the lens. You will get the grinding noise even if you switch the camera on in manual focus, but not if you take pictures in manual focus.
Oct 02, 2009 | Sony Alpha DSLR-A200K Digital Camera
Sony a100 match ups
Yes, when Sony took over Konica Minolta they inherited the Maxxum lens mount (Minolta's AF lens mount system). the only Minolta lenses which don't work are the earlier manual focus type.
Sony have finally launched three new models which are the first to be clearly Sony designed, but they have still retained the Maxxum lens mounting.
Jul 03, 2009 | Sony Alpha DSLR-A100 Digital Camera
Cameras compatible with Quantaray AF 70-300mm lens
Depending on how new your Minolta SLR film camera was, the lens may or may not work on a Minolta Digital SLR. In many cases, a lens with the correct mount (in this case, a Minolta mount) can be used on the same brand of camera in the digital format.
One thing you should know is that DSLR sensors are, generally speaking, smaller than the size of a 35mm film negative. Long story short, that means that your lens will have a magnification factor on the DSLR. Usually, it is in the range of 150%, so a 70-300 lens from a film camera would cover 105 to 450 on a Digital SLR.
To be sure about the mount, you'll need to seek advice specific to Minoltas -- probably best to take your lens to a local camera shop and see for sure if it fits and what features will work (aperature, auto-focus, etc) and which won't work on the DSLR.
May 31, 2009 | Quantaray AF 70-300mm f/4.0-5.6 High Speed...
Minolta SLR Lens on Sony - Does it work.
As I understand it, Sony bought Minolta, lock, stock, and barrel. Theoretically the lenses should fit and may work on manual, but I'm very sure they will not totally work on sony digital cameras. I wouldn't even try to fit them as the autofocus system on the camera may be damaged.
Mar 22, 2009 | Tokina AF 100-300mm f/4.0 II APO Telephoto...
I have a Quantaray 70-300 f1:4-5.6 LDOMacro. I have been using it with Minolta QTsi Maxxum SLR. I am looking into getting a Digital SLR that I can use my lens with. Is there one out there.
http://shop.ebay.com/items/_W0QQ_nkwZminoltaQ20canonQ20
adapterQQ_armrsZ1QQ_fromZR40QQ_mdoZ
here is a link to an ebay search for minolta to canon eos adapter, they sell for just about every camera. i know it sucks, buying a new camera that wont work with your favorite lens, but i think you might be better served focusing (couldnt help myself) on camera features and pricing. i own a canon dslr and love it. sigma has a cool dslr. it has a three layer image sensor, with a removable on sensor ir filter. the ir filter thing is really cool.
Dec 16, 2008 | Quantaray AF 70-300mm f/4.0-5.6 High Speed...
Interchangability of camera lenses
rtjohnson1,
the minolta 7000 was the first auto focus slr. you can still buy a good working 7000 on e-bay for around $40.00 to $50.00, or take a 7000 lens to a camera store and try it on a newer model.
Dec 06, 2008 | Minolta Maxxum 7000 35mm SLR Camera
Using sony alpha 100 with cosina 28-300
That lens was made for minolta cameras. and it would need to be whats called. "Re-chiped"
if you get a hold of the company that made it then they usually do it for free. If they still have parts.
So what happens is. even though it is an auto focus lens. It wasnt set up to work with sony.So you jsut need the lens and camera to speek the same language in theory.
If you took it to a camera store they should beable to help you get in contact with the company.
Hop that helps,
Caleb
Jun 27, 2008 | Cosina AF 28-300mm f/4-6.3 MC for Nikon...
Sony A100 compatibility
It would help if you actually gave details of the lens!
All the old Minolta AF and MF lenses will fit the Sony A100, but only the AF are auto-focus compatible.
Since the Maxxum 7000 was an AF camera, I would image that that is an AF lens pictured on the front.
Check out this site for more details:
http://www.mhohner.de/sony-minolta/lenses.php
Matt
Feb 29, 2008 | Sony Alpha DSLR-A100 Digital Camera
Minolta Maxxum 300si 35mm SLR Camera Logo
Top Minolta Photography Experts
Greg Cann
Greg Cann
TC CAMERA REPAIR.Com...
Are you a Minolta Photography Expert? Answer questions, earn points and help others
