Question about LG 37LC7D 37 in. LCD HDTV
Have a 37" lg tv screen flashes and the audio is fine
Put in a new power board now the screen flashes but the audio is fine. Picture is good when is flashes on. About 3-5 seconds.
SOURCE: frozen picture on LG LCD 37"
Try One of your working TVS and connect it to your cable outlet of the TV that is having problems. If that TV Does not work then there may be a degraded fitting or the Leg coming of the splitter to that outlet could have a Low Signal Problem
Next Take the First TV that was not working properly and put it on the cable outlet of one of the TVs that is working properly and if the TV set works on that Channel then you know it is not your TV that it must be the cable
Posted on Feb 28, 2009
  • 945 Answers
SOURCE: 37'' LG lcd tv, no power
I just want to clear things here.
The stand by light will remain on whenever the tv set is turned on by a button on the side of the tv.
Then use your remote to turn on the tv, but wait as it can take 10secs before you get a picture.
Posted on Nov 04, 2009
SOURCE: TV has no display -- Need advice on Z Sustain Assembly Board
Send your board for repair / exchange - we service those by truckload :-)
http://www.coppelltvrepair.com .
Posted on Apr 05, 2010
  • 26 Answers
SOURCE: A simple question - My new 42" LG tv is fine -
You should be able to change the aspect ratio to fit the size of your screen. This will be the 16:9 4:3 16:10 settings.
You can access these by going to MENU---> PICTURE -----> Select ratio that works----> exit out and watch TV.
IF this will not fix it you need to look into the signals being fed to the TV as sometimes they can have a funny effect on the output picture. Some cable boxes will alter the picture and then it won't come out right on the TV. If it is all inputs doing this tho then changing just the Aspect ratio on the TV should solve the problem.
Posted on Jun 07, 2011
SOURCE: LG 42LC7D-UB, Bad LCD Controller Board????
Steve, that was awesome. Thanks a bunch. I already have the tools and I can get the solder easy enough. Thanks a again. I went to Best Buy this weekend and all they could say is that the entire board would need to be replace and that they really recommended a new tv as the cost for the new board would be as much as a new TV.... :( typical of them!
Posted on Nov 22, 2011
Replaced the power supply/backlight inverter board and T-con boards on my Samsung 37" TV Seems worse than before
hi this is usually is a tcon board fault, but it can also be a bad panel, if it's flashing could a mainboard fault thanks
shaun
Feb 27, 2017 | Samsung Televison & Video
Lg 42" tv not displaying screen image
The t-con board controls the picture. To test it shine a flash light on the screen abd see if you can see an image when the TV is on. If you do then the T-con board is OK. Look at the back light ballast board (sometimes is part of the power supply board) If you see no movement or a dim picture with the flash light, then the T-con board is gone. You can get parts here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Aug 11, 2016 | LG Televison & Video
Audio is fine. Why did picture suddenly go black?
The board that controls the back light for the screen is called an inverter board. Sometimes, depending on the model , the inverter is combined with the power supply board. Go here to find the parts :www.shopjimmy.com
Feb 02, 2016 | LG 47LN5400 47" LED TV 1920x1080, 120 Hz....
LG TV 60PZ550 black screen no pic or sound green lit flashing it has back lite
LG 60PZ550 Plasma - No Sound, No Picture - Badcaps Forums ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
Sep 15, 2013 - 20 posts - ‎4 authors
LG 60PZ550 Plasma - No Sound, No Picture Troubleshooting TVs and Video Sources. ... I see no change in the screen at any point (no glow). With the rear cover ... I've worked with some electronics in the past, but am new to TV's. I'm sure .... Multimeter on DC 1000V, red on (+) marked, black on (-) marked. Lg 3d plasma 60pz550 i've got sound but no picture
Jul 18, 2014
LG 60PZ550 color issue - Badcaps Forums
Jun 9, 2014
Purple/Pink Lines / Postering on plasma LG 60PZ550
May 29, 2014
LG Plasma 60pz550 has strange greenish rainbow ...
Jan 20, 2014
More results from www.badcaps.net
Jan 10, 2016 | LG 60PZ550 3D Plasma TV
My LG 37LG50 TV wont turn on ?
Are you certain the replacement power supply is good? A defective main board or power supply can cause this problem.
May 04, 2013 | LG 37LG50 37 in. LCD HDTV
I have an lg 42pq30 plasma tv the main input board went bad causing no audio.. i replaced the board with same part number .. it now has sound but the picture at the right is off the screen good 20% of...
You must use a usb memory stick to copy data values from the old board to the new board. First you have to put the old board back in, insert the stick then follow prompts to copy register values to the memory stick. Then put the new one back in and load the values back onto the new. I would definitely have a certified tech do this process. You don't want to make a mistake with the old board values.
Feb 18, 2011 | LG 42PQ30 42 in. Plasma TV
JVC LT-37X688 37 in. LCD TV. When powered on there is a brief flash of light on the screen and then the screen is black and stays black. Audio is fine and I can still use all of the remote controlled...
No lamp on LCD tv.The LCD backlight inverter board it dead,that board needed replaced to get picture back.Tries Shopjimmy.com,Ebay.com to buy the LCD backlight inverter board.It usally a long board.The refurbish LCD backlight inverter board about $100-$120.
Feb 14, 2010 | JVC LT-37X688 37 in. LCD HDTV
LG 37" lcd tv weird noise using hdmi ports bought new main board still does the same thing! Need solution! Lg says "i don't know never heard of this problem", BS!!!!! Ok remote for the tv worked before...
Use an other HDMI cable. Still the problem persists, Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. http://electronicshelponline.blogspot.com/
Mar 09, 2017 | Televison & Video
TV's on. No Picture...No Sound
Have a problem with Zenith 37 HDTV. Medel number: Z37LZ5D As wathcing TV, along with 'pop' sound, TV went dead. LG service center gave an advice to unplug the power cord and press ON/OFF power switch about 1 min. Then plug power back and turn on the TV. Well, the green light blink for a while and solid green, but still no screen, no audio. Search the Web and someone suggested to replace Power Supply Board which will fix the problem. Again, search the Web and came out with Power Supply Board. LG Electronics/Zenith 'Power Supply Assembl' with $124.95 from PartStore.com. Is it the right solution? Do I have to replace entire Assembly Board? not just replacing some fuse? Any cheaper way to do? If I have to replce PSA board, any suggestion to how? Comment posted on Apr 22, 2009 I have a basic knowledge of electric and electronics, such as rewiring entire house for renovation and assemble entire computer from scratch.
Actually, the TV belongs to my father and the problem that I stated was based on what he told me.
So the question is based on the symptom that I posted, how sure are you that the problem is the Power Supply Board?
Is it good to order PSB? Comment posted on Apr 23, 2009 Purchased 2 and half years ago. Expired one year warranty. Comment posted on Apr 23, 2009 Zohail,
This is LCD TV.
There is no problem with the wall socket nor current.
I put other appliances on same wall socket and worked.
It has to be internal problem.
As I mentioned on the main post, there was a 'pop' sound while watching and TV went dead.
Turn on remote control, there is blink green light and then green stays on, but no sound, no screen.
Turn off remote control, light turns red. Comment posted on May 14, 2009 I fixed the TV.
Orderd power supply board which cost me $136.51 total.
Replacing was simple.
Just removed the rear panel cover then electronic board housing cover.
Took power supply board with all the connector cables and replaced with new one.
Problem was a transformer connector which got burned and blow up the plastic cover.
But no problem with fuse and capacitors.
Thanks all for advises.
Jan 01, 2008 | Zenith Z37LZ5D 37 in. LCD TV
Philips 37 flat screen
U better have it checked by a qaulified tech
Sep 09, 2007 | Initial HDTV-322 32 in. LCD Television
LG 37LC7D 37 in. LCD HDTV Logo
Computer Repairing
Computer Repairing
