Question about Plumbing
Wire colored coated meaning
Need to know the colors
  • Tim Hofstetter
    Tim Hofstetter Jul 26, 2014
    Could you be more specific? What wiring? For what? Different applications use different color codes.
  • 17 Answers
SOURCE: wiring colors
You will need a voltmeter. Normally red is power, black i ground, yellow is memory power. the best way to know for sure is to use a voltmeter to test what each wire is recieving in power and when. If the key is off then the wire that has 12volts dc is for memory and the main power wire should be at 0volts dc. When the key is on that wire should have power now. the ground will be black on that car. Good luck.
Posted on Feb 20, 2008
merle840
  • 113 Answers
SOURCE: avh-p6600
similar but not exactly the same - for a dvd you must also connect a line to the parking brake wire that shows ground when engaged
Posted on Mar 28, 2008
  • 94 Answers
SOURCE: wiring color meaning
did you buy a factory radio connector to connect the old harness to the new radio wiring if not you can get one at wall mart for 20 dollars and it will be color coded
Posted on Mar 08, 2009
etirbynnor
  • 655 Answers
SOURCE: color codes for my jvc arsenal kd-ar560 wire harness
Hello jlj2382,
Here's the wire colors for your KD-AR560:
Black = Ground (to vehicle chassis)
Yellow = Constant 12V (power)
Red = Accessory (to vehicle accessory terminal)
Blue/White = Remote turn-on lead (to remote amp)
Orange/White = Illumination (to vehicle light control switch)
Brown = Cell Phone terminal
White = Left Front Speaker positive (+)
White/Black = Left Front Speaker negative (-)
Gray = Right Front Speaker positive (+)
Gray/Black = Right Front Speaker negative (-)
Green = Left Rear Speaker positive (+)
Green/Black = Left Rear Speaker negative (-)
Violet = Right Rear Speaker positive (+)
Violet/Black = Right Rear Speaker negative (-)
Hope this helps.
Posted on Apr 24, 2009
SOURCE: speaker wire colors
1991 Ford Explorer XLT Radio and Speaker Wire Colors
Pulled out the stock radio and found two plugs on the back of it. One plug had 7 wires (Power, Dimmer, Amp etc.) and one had 8 (Speakers).
7 wire plug (I could see these wires immediately from the plug):
Car Radio Battery Constant 12v+ wire = Light Green w/ Yellow Stripe
Car Radio Ground Wire = Black
Car Radio Accessory Switched 12v+ wire = Yellow w/ Black Stripe
Car Radio Dimmer Wire = Light Blue w/ Red Stripe
Car Radio Illumination Wire = Orange w/ Black Stripe
?? Don't know ?? Red Wire (No power to wire Constant or Accessory)
Car Radio Amp Wire = Blue
8 Wire Plug (Wires were wrapped in a grey outer sleeve, had to cut sleeve to get to wires.):
Right Front:
White w/ Green Stripe (+)
Brown (no stripe) (-)
Right Rear:
Purple w/ White Stripe (+)
Light Blue (no stripe) (-)
Left Front:
Light Green (no stripe) (+)
White w/ Orange Stripe (-)
Left Rear:
Light Blue w/ Black Stripe (+)
Yellow (no stripe) (-)
Speaker Wires (found at the individual speakers in the doors)
Right Front:
Green w/ Orange Stripe (-)
Right Rear:
Orange w/ Red Stripe (+)
Black w/ White Stripe (-)
Left Front:
Orange w/ Green Stripe (+)
Blue w/ White Stripe (-)
Left Rear:
Red w/ Green Stripe (+)
Red w/ Blue Stripe (-)
Posted on Nov 11, 2010
What to consider while wearing a winter coat?
Winter coats are available in different styles and colors. Right from pastels to bold colors, you need to decide what will flatter you the most. Just looking at chelse walker collection will allow you to get rough idea of different winter coats. Those women who have dark hair and complexions would appear beautiful in bright colored winter coat.You need toconsider the coat's silhouette as well as length, and the way that is going to work with the prevailing clothes in the winter wardrobe. The chelsea clothing company by chelsea walker attempts its best to provide winter coat that are trendy.
Mar 07, 2018 | Cars & Trucks
Where do the color numbers for coats and clark come from because i can't find these numbers to purchase the thread
Hello, Jenia -
Coats & Clark creates the thread colors and the numbers to identify each thread color.
However, I don't think "where do the color numbers for coats and clark come from" is REALLY your question.
Apparently, Coats & Clark made major changes with their thread colors and numbering in 2009. See the information here:
http://sewing.craftgossip.com/new-coats-clark-thread-colors-plus-new-numbering/2009/06/23/
and read this Coats & Clark blog article:
http://www.makeitcoats.com/us/new-thread-colors-numbers-2/
This is a link to a Coats & Clark thread color number cross reference chart, listing the pre-2009 thread numbers and the corresponding new thread numbers:
http://ep.yimg.com/ty/cdn/sewingwarehouse/sewingsupplywarehouse-com-coats-200-to-s900-color-conversion-chart.pdf
The chart was created by SewingSupplyWarehouse.com .
In the blog (link given above), author Lynn Browne writes, "If you find yourself running out of thread in the middle of buttonholes or topstitching with a color that was retired, or that isn't an exact match-contact us through the website and we will try to help."
This is the link to the Make It Coats Contact Us web page:
http://www.makeitcoats.com/us/contact-us/
The Click Here to Contact "button" in the lower left corner will lead you to a form you can complete to send an email.
Best wishes.
Feb 20, 2018 | Sewing Machines
2000 monte carlo took radio out with securtiy cut plug off now car wont start what wires to reconnect?
Reconnect all cut wires should be color coated match them back should be fine. Make sure wire color connection match same color.
Sep 28, 2014 | 2000 Chevrolet Monte Carlo
I need to re wire the fan clutch the wires were cut on accident. a diagram of how to do it would be great.
Look at the wires that were cut.The plastic coating on the outside of each wire has different colors on them.Just rejoin each wire to match the colors.Hope this helps
Mar 27, 2011 | Dodge Ram 2500 Cars & Trucks
Need to know what the wire color corresponds to
red doesn't necasarraly mean anything check with peterbilt service or parts dept
Mar 12, 2010 | Car Audio & Video
I need to know the wiring dia
all your wiring is color coated. if you have your harness from the the new reciever and you have purchased an adaptor harness which plugs into the vehicles existing harness enableling you to wire every thing as it is color coated you have red wire a yellow wire a black wire. your red and yellow are power and your black is your ground wire .your red should be be your acc or ignition wire which gives you power to the unit when the ignition is on should tie directly to the red wire on your adaptor harness, the yellow is your constant 12 volts which is for memory and keep your presest along with your time and features such as that it will tie with the yellow on the harness as well then the black is your ground the unit and will tie with the black wire on the harness. that takes care with powering the unit next you have a set of wires that you will be using to tie your sound to they are color coated as well and will tie to the new harness your front left and front right channels are white/white and black and usually gray/w a gray and white for the right channel thats your front. your rear is green/w green and purple and purple/w purple and white stripe for the rear speakers i hope that helps you out a bit
Oct 28, 2009 | Pioneer DEH-P2900MP CD Receiver...
I NEED TO KNOW ARE THE COLORS MEANING FOR PIONEER AVIC N2 WIRING
Red = power Organ = battery Blue with a strip =remote
Blue antener ( the rest are speakers )
Aug 16, 2009 | Pioneer Car Audio & Video
Anybody know what the colour code is for the 94' Cadillac Concours , i can't find it anywhere? It's the pearl white colour. where is it located on the car?
White Diamond Pri Metallic Tri-coat 93/WA8933
 Paint codes can be confusing! For example, the color code 93/WA8933 listed on our site can be shown on your vehicle as 93U or 93L or8833 or WA8933 Often there will be a BC CC before the color code. This stands for Basecoat/Clearcoat. The U in the paint code means theUpper Color and the L means the Lower Color. Two tone vehicles will have each color coded, i.e. 93U and say 93L. Also, it could be 8933L or8933U.
Good luck and hope this helps.
Jul 02, 2009 | 1994 Cadillac DeVille
I need to know the color code of my 2000 ford f150 radio
Look in the driver's side door jamb. There should me a sticker with the details of your truck.
At the bottom you'll see EXT PNT:
Mine says EXT PNT: SU
I believe SU is the the color code. You can probably order the paint from the dealer, or any good paint supplier can get you the equivalent.
Remember that paint can fade and change color over time, so if you're not a pro painter, blending the bright, new color will be very hard to do; you might as well just paint the entire panel or the whole truck if you're not already going to.
Feb 27, 2009 | 2000 Ford F150 Flareside SuperCab
I have a 98 ford f150i need to put new raido dont know the colors are for
If you have a wiring harness, its alot eaiser to hook up cuz all you do is match the colors there all color coated, if interested go to this website---- http://us.nine.ebid.net/perl/auction.cgi?auction=1220395592-29367-2711&mo=auction&from=froogle Or go to any electronics store, bestbuy or circuit city all carries wirring harness's you could have it hooked up less then 5 mins and you wount blow a fuse
Oct 19, 2008 | Car Audio & Video
Plumbing Logo
44 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
