Question about SNK Caldera RMT365 36 in. Electric Cooktop
How to fix o button SMT36 on buton will no turn on
My Kitchenaid cooktop is not working, but is beeping. How can I turn it off?
Have u tried unplugging it for about 10 minutes then plugging it back in? Sometimes doing thus can reset it. It is only a quick fix and a qualified serviceman should called to completely fix the problem.
Nov 27, 2014 | KitchenAid KECC607BSS 30" Electric Cooktop...
When I click the "on" button I get "L" in the 4 LED'S and then i get an ERROR, what can i do to fix it
Did you fix the LLLL error on the HOB as i want to know how to fix mine, its giving me the same error..
Thank you
markanthony.schwartz1@gmail.com
Nov 06, 2014 | Cooktops
Oven door is locked
try unplugging it for a few minutes then plug back in
Mar 28, 2014 | Maytag Stove / Oven / Range Cooktop -...
Bosch Ceran Schott hob. Number in top left corner
We have this exact same problem, and I've not managed to track down a manual (we rent and the landlord is on holiday).
I've tried holding down all buttons for a time, combinations of buttons, and turning it off at the mains, but no joy.
Did you ever solve this?
[submitting this as 'post solution' but there is no button for 'say you have the same problem'!]
May 27, 2010 | Bosch Cooktops
GE gas stovetop burner doesn't light
there are sparker modules on each burner behind the button, it may be that yours is failed, if you turn on other knob and you see spark at problem burner and still isn't lighting you have to make sure the black or grey tops are paced on perfectly, just give them a little nudge and you have to make sure area is perfectly clean for spark to take effect, spark will go for cleanest area on metal. so ensure area is clean and check burner top
Feb 05, 2010 | GE 30 in. Profile JGP979 Gas Cooktop
My indesit gas cooker's igniters keep clicking
Hi yes it could be that if it only just done this leave it off you can still use the top the heat while cooking should dry it out.
Oct 10, 2009 | Jenn-Air 36 in. CCG2523 Gas Cooktop
Jammed knob on Gaggenau cooktop
It looks like the gas valve for FR burner has to be replaced. Very unusual for Gaggenau gas cooktops.
Nov 18, 2008 | Gaggenau 23 in. KG 260 Gas Cooktop
Siemens glass stove top - locked mode
you have to hold the powerbutton for a few seconds, and the children security lock should come off
Sep 18, 2008 | Siemens 32 in. EH78754EU Electric Cooktop
Candy sprinter
Great.. finally. i manage find from solution from user guide.. L is Locked. below is the instruction. will check out tonight.
The locking function holds the current settings, or prevents anyone from starting the hob. It is also used for cleaning the control strip as the controls can be locked without the hob being on. To lock the hob : -Press the on/off button     . -Press simultaneously " - " button and " + " button of the front right zone (PVD 633 front left zone), and then press again on the " + " button of this zone. The hob is locked, the locking indicator " L " is displayed on all zones for 20 seconds. To unlock the hob : -Press the on/off button      . The locking indicator " L " is displayed on all zones. -Press simultaneously the " - " button and the " + " button of the front right zone (PVD 633 front left zone), and then press again on the " - " button of this zone. The hob is unlocked.
Jun 24, 2008 | Cooktops
SNK Caldera RMT365 36 in. Electric Cooktop Logo
64 people viewed this question
Top SNK Cooktops Experts
Dan Webster
Dan Webster
paulcarew
Are you a SNK Cooktop Expert? Answer questions, earn points and help others
