After printing my document it empties the paper tray and prints jibberish at the bottom of each page
SOURCE: HP IIIp prints extra blank pages
HI there make sure that the paper tray guides are fully against the paper also try sending the job through the manual feed to see if you get the same problem. If you do not then it maybe that the paper cassette separation pad is worn and will need replacing. If your model has no rubber pad at the front of the cassette then you will have a metal hold over one corner of the paper make sure that when the paper lifts that the paper sits under the silver (Dog Ear) as this acts as a separator.
Hope this helps
Thanks J
SOURCE: Extra blank sheet of paper between printed pages
Check your print settings, it is possible that you enable page seporator in the settings.
SOURCE: Paper wrinkles at bottom of page when it prints
This is most likely cased by a dirty paper feed path so it will need cleaning and blowing out. Make sure that all the internal paper guides and separators are free of obstruction. Make sure that the fuser area is clean that the internal paper guides are ll in place and operate freely. Also clean it with a vacuum with a soft haired brush tool to avoid any damage. Also fan the paper before using it and do not overload the print paper tray. Also check that the pick up rollers are not work or contaminated with dirt / debris etc. Also make sure that the print tray is not overloaded and make sure that the paper is not to tightly held by the tray side guide.
Also check the rear panel and make sure that all the guides and rollers are moveable and not distorted in any way.
Also check the paper pick up for wear as this will cause additional pages to be collected and fed through the printer. Make sure that you fan the paper before use ant it is of suitable quality and weight.
