Question about Health & Beauty
Is alendronate cause stroke symptoms - Health & Beauty
Out of nowhere got dizzy, weak, cold clammy skin, cold sweats, pale. within 30 minutes felt fine, color back
Sounds like heat stroke.But I would be unprofessional to try to diagnose you sight unseen just based on this information. Ah, I just spied your question was posted in the Health and Beauty section. It could be hormonal. See how quickly guesses can change! Information is king. You might get a clue from one of these symptom checker sites:
Symptom Checker from WebMD Check Your Medical Symptoms
http://www.mayoclinic.org/symptom-checker/select-symptom/itt-20009075
Jun 03, 2017 | Health & Beauty
What is the symptoms of high blood pressure?
High blood pressure is often associated with few or no symptoms. Many people have it for years without knowing it. However, just because high blood pressure is often symptom-less doesn't mean it is harmless.
In fact, uncontrolled high blood pressure, or hypertension, causes damage to your arteries. High blood pressure is also a risk factor for stroke, heart attack, and other cardiovascular problems.
Some of the rare symptoms of high blood pressure are:
Rarely, people with chronic high blood pressure might have symptoms such as:
1. dull headaches
2. dizzy spells
3. frequent nosebleeds
Other symptoms of a hypertensive crisis may include:
1.severe headache
2. severe anxiety
3. shortness of breath
4. nosebleed
Mar 20, 2017 | The Health & Beauty
What are the effects if you stop taking the alendronic tablets
Sorry but we recommend asking your DOCTOR .or check the website listed WebMD Better information Better health
Oct 13, 2016 | Tablets & eReaders
What are the side effects of alendronic acid
Type the name of the acid into your search engine on your computer. You will find the answer.
May 17, 2016 | Computers & Internet
What is dementia
Dementia is a loss of brain function that occurs with certain diseases. It affects memory, thinking, language, judgment, and behavior.
Jun 17, 2014 | Measuring Tools & Sensors
Whats code po 343
Possible symptoms
- Engine Light ON (or Service Engine Soon Warning Light)
- Lack/Loss of Power
- Engine Stall
P0343 Chevrolet Description
The Camshaft Position (CMP) Sensor sensor works in conjunction with a 1X reluctor wheel on the camshaft. The Powertrain Control Module (PCM) provides a 12 volt power supply to the CMP sensor as well as a ground and a signal circuit.
The CMP sensor determines whether a cylinder is on a firing stroke or on an exhaust stroke. As the camshaft rotates, the reluctor wheel interrupts a magnetic field produced by a magnet within the sensor. The sensors internal circuitry detects this and produces a signal which the PCM reads. The PCM uses this 1X signal in combination with the Crankshaft Position sensor 24X signal in order to determine crankshaft position and stroke. This diagnostic for the Camshaft Position sensor tests for a loss of Camshaft Position sensor signal.
Observe that as long as the Crankshaft Position sensor 24X signal is available, the engine will start. The PCM can determine top dead center for all cylinders by using the Crankshaft Position sensor 24X signal alone. The Camshaft Position sensor 1X signal is used by the PCM to determine if the cylinder at top dead center is on the firing stroke, or the exhaust stroke. The system attempts synchronization and looks for an increase in engine speed indicating the engine started. If the PCM does not detect an increase in engine speed, the PCM incorrectly synchronized to the exhaust stroke and will re-sync to the opposite cam position. A slightly longer cranking time may be a symptom of this condition.
Read more: http://engine-codes.com/p0343_chevrolet.html#ixzz31FPYjyRM
Mar 26, 2014 | 2002 Chevrolet Suburban
Valve not working on left side what signs should i look out for?
I'm no medical doctor, but my dad just had a heart attack and had similar symptoms. Also, a stroke can cause symptoms like this. Is this for a human and not a car? Go to emergency room if you think you have suffered a heart attack or stroke.
Dec 06, 2011 | Cars & Trucks
Health & Beauty Logo
27 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
