Question about Jessica Carlyle Carlyle Rhinestone Detailed Watch
How do I reset the time on my Jessica Carlyle Rhinestone Flower watch
How to switch between 24hour to 12hour on the Armitron 165 45/7042?
Jessica, 1. From Time Telling Mode, press and hold 'D'. Press 'B' simultaneously to select either 12 Hour or 24 Hour (Military) Time. NOTE: 'A' indicates 12 Hour Time is selected. 2. Release 'D' to return to Time Telling Mode.
Try the links for manual on this watch.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://fitness.manualsonline.com/manuals/mfg/armitron/wr_165.html
http://www.angelar.com/~jeremy/ArmitronLadiesDigital.pdf
Apr 12, 2016 | Armitron Watches
I cant figure out how to set my new watchs' date i tried to see if there is a difference with how far you pull the stem out to try and set it that way and i also tried spinning it around in a 24 hour cycle...
There is probably a screw that is lose on the watch. Someone will need to pop open the caseback and make sure the screws are in place. If you or someone can't figure it out I suggest taking it to a watch repair person, do not go to a high end place they will charge more then what the watch is worth. Go to watch repair shop , and if they charge more then $10.00 then it's better just to buy a new watch on ebay.
Oct 26, 2013 | Geneva Platinum Metal Link Rhinestone...
The hands on my Citizen watch (movement caliber number C320) don't reset properly. I have followed the factory instruction several times with the same result: the minute hand moves to a position 5 - 10...
This is normal. The watch begins timing when you reset it. That 5 to 10 minutes is the time that it took you to do the all reset procedure and you can see that the same time is shown in the digital display - so everything is aligned. It is actually pretty cool that it does that. Source: just did the all reset having dropped my watch. Love this watch!
Apr 13, 2011 | Citizen Watches
Rhinestone fell out
No, this will not be covered on the warranty. You have to visit your nearest watch repair shop or jeweller and ask to fit a new stone. It is easy job and shouldn't cost too much.
Jan 08, 2009 | Relic watch
Jessica Carlyle Carlyle Rhinestone Detailed Watch Logo
Top Jessica Carlyle Watches Experts
Jimmy Accardi
Are you a Jessica Carlyle Watch Expert? Answer questions, earn points and help others
