Question about Gigabyte KM7580 2.4GHz WIRELESS M/M KB & MOUSE
Gigabyte mouse going back
The mouse clicks back everytime you click on the left button... Please help!!
How do i can et internet on my laptop xp to connect from wireless router it show a lock how can i unlock
Step 2: With the left mouse button, click on 'Control Panel'.
Step 3: With the left mouse button, click on 'Network and Internet Connections' (Network Connections, if in Classic View).
Step 4: With the left mouse button, click on 'Network Connections'.
Step 5: With the right mouse button, click on the 'Wireless Network Connection'.
Step 6: With the left mouse button, click on 'Properties' button.
Step 7: With the left mouse button, click on the 'Wireless Networks' tab.
Step 8: With the left mouse button, click on the name of the wireless network, under 'Preferred networks', that you want to automatically connect to.
Step 9: With the left mouse button, click on the 'Properties' button.
Step 10: With the left mouse button, click on the 'Connection' tab.
Step 11: Ensure there is a checkmark in the checkbox, next to'Connect when this network is in range'.
Step 12: With the left mouse button, click on the 'OK' button.
Step 13: With the left mouse button, click on the 'Advanced' button.
Step 14: With the left mouse button, click to select 'Access point (infrastructure) networks only ' (This will help prevent your connection from bouncing around from one network to another).
Step 15: With the left mouse button, click on the 'Close' button.
Step 16: With the left mouse button, click on the 'OK' button.
Jun 13, 2010 | Computers & Internet
My mouse has stopped working
The mouse buttons may have been swapped from LH to RH or vice versa.
Go to Control panel - Mouse - Buttons tab - in Button configuration click the selection box (Switch primary and secondary buttons) with the right button on the mouse.
If you have used the wrong mouse button then select it again with the correct button.
Then click Apply and then OK.
May 26, 2010 | ASUS F5R-AP038A Notebook
Everytime i click on something my computer opens up a menu how do i get it to stop?
It's possible that your mouse has been configured so that the LEFT mouse button is performing the action that the RIGHT mouse button does on most computers, namely to open the "context-menu".
Access "Control Panel", and then "Mouse", and check the actions that are associated with each click.
Nov 27, 2009 | Compaq Audio Players & Recorders
Left click on mouse pad doesn't work!!!
i think u must have switched the primary and secondary buttons on ur mouse.i assume ur using windows.goto control panel-->mouse-->choose buttons tab-->u'll see a check box which sud read switch primary and secondary buttons.remove the check mark from here.sud solve ur issue...
Jun 22, 2009 | Dell 2 Button Mouse 6u226
Change mouse clicks
Please click on control panel and click on mouse settings. The first tab would help you to swap the right and the left buttons of a mouse.
Thanks
May 27, 2009 | Computers & Internet
Please help me with my mouse problem!!!!
Go to your control panel, if on XP go to Printers and other hardware, then click mouse and the buttons tab should be the first tab to come up, uncheck the box that switches the buttons.
Mar 21, 2009 | Microsoft Wireless Laser Mouse 5000
When ever i turn my laptop on..it boots properly..then ill be typing and it will shut off..or go on standby not sure then i will push the power button...but it doesnt rootboot ...and starts back up where i...
Try this.
Right click on desktop.
Mouse down to properties, & left click.
Left click on screen saver.
Mouse down to Power In monitor power, & left click.
Check your power settings & hibernation settings.
Also some computers are setup to hibernate if mouse is placed in certain parts of the screen (top right or left, Bottom left or right.
Hope it helps.
Mar 11, 2009 | Dell Inspiron 1525 Notebook
Hp 4215-v officejet printer.. scanner functions not installed
For those folks who have Windows 7...
Click start from menu (bottom left of window pane),
Click "Devices and Printers",
Click on the HP printer listed,
Click "scan a document or picture"...
CALL IT DONE!!!! Gotta LOVE Windows 7...EASY!
Feb 12, 2008 | HP Officejet 4215v All-in-One Printer
G7 Wireless Mouse keep double clicking
Same Problem, use canned air to clean it. bash the button a few times. seems to help for a while. Dont bash it to hard or you'll break it. love the mouse but this is a crappy issue within 3 months of use. in a clean environment.
Dec 08, 2007 | Logitech Inc G7 Cordless Laser Gaming...
Open Questions:
Gigabyte KM7580 2.4GHz WIRELESS M/M KB & MOUSE Logo
32 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Gbenga
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
