Question about Philips Televison & Video
Disc drawer on dvd2880/05 not opening
Just opened box and tried with remote and finger not opening
avn00b1e
  • 10 Answers
SOURCE: The drawer on the unit won't open.
When the DVD player is plugged into power and switched on, and won't power up (nothing shows up in the front display panel), the power supply unit in the DVD is blown. the noise that player made was probably a capacitor going off. You will have to get the unit repaired.
Posted on Jul 29, 2007
SOURCE: No Response To Open Button on Remote
I had the same problem- the door would not open.
I opened up the unit removed the drive and discovered a lever which allows to manually eject the tray. After playing with this a bit, I discovered that if I hit open on the until and depress this lever, it would open reliably. Not ideal, but at least it gives me ability to open/close.
Unfortunately once I put the unit back together, it no longer recognizes any disks. I must have damaged some disk sensor mechanism in the process. On the bright side however, it open/closes reliably now, doesnt even require the lever to be depressed manually. So if I can just get it to recogize disks, I am in good shape again.
You may not need to open up the unit and remove the CD burner to get to the manual lever, but you have to remove the fancy cover plate for the tray to be able to access the lever. The cover plate on mine is silvered and says "All write". The lever is on the underside of the tray to the left side, a paperclip might be able to poke thru to access it without removing the whole front cover.
Good luck.
Posted on Dec 29, 2007
SOURCE: toshiba sd-3990 Disc-drawer won't open
I was given one of these the other day. I was told the drawer wouldn't open yet the machine seemed to function fine. I removed the six screws holding the top on the box and then removed the four screws holding the drawer assembly in place. As you lift the drawer assembly out of the box, make sure you release the two pieces of black retaining tape holding the data cable to the box floor. Turn the drawer over and you will see that there is a little sideways bar mounted on the front underside of the drawer assembly. This is sticking. As you press the OPEN button, jiggle this bar and the drawer will open. You may have to manually move the drawer cogwheel a little to help free it up. Hope this helps.
Posted on Oct 07, 2008
  • 208 Answers
SOURCE: LG RH1757 (80 GB) DVD Recorder / HDD Recorder
Could be a timing issue with the tray mechanism - possible that somebody has given the tray "a shove" to make it close instead of using the open/close button and has put the timing out.or a worn tray loading belt
Posted on Mar 18, 2010
gopakumarg43
  • 74377 Answers
SOURCE: disc stuck and removed but drawer will not open
Check the loading belt and loading gear wheel assembley.
Posted on Mar 29, 2012
Cant open dvd drawer
Sometimes DVD player drawers get stuck closed because the disc inside isn't seated properly. At other times the player may have another problem. The first step in discovering if it is the disc or another issue is to remove the disc. Most DVD players have a secret eject button. It allows you to open the drawer when a disc gets stuck and cannot be ejected normally.
For this you'll need a standard size paperclip.
  1. Unfold the paperclip and make it as straight as possible.
  2. Look closely at your DVD player . Push the tip the paper clip into the small hole on the tray cover on the front of the Toshiba. The hole is on the right side of the cover.
  3. Press inward gently with the paperclip until you feel a slight resistance, then continue pushing to engage the internal eject button. The tray should pop open partway.
  4. Gently pull the drawer until it's fully retracted. Be careful not to pull too far.
  5. Remove your disc from the drive.
  6. Before you reinsert another disc, use the remote and/or buttons on the player to close the door, and reopen it. You can also press carefully with your fingers. If you cannot open/close the drawer normally at this point, do not put in a new disc until you have repaired the problem.
What You Need
Dec 09, 2013 | Toshiba SD Computers & Internet
Unlock Toshiba DVD player SDP93S bought in America to play Australian DVD's
Thanks for understanding. Please let me know if you require any clarifications.
Jul 09, 2011 | Toshiba SDP93S Portable DVD Player
Not reading any DVD's.
First check if your DVD is compatible with the disc, if it is compatible and is not playing, then it means your lens is either weak or bad.
Try to use a lens cleaner on it and if it does not work, then you replace the lens with a new one.
Replacing the lens is easy, all you have to do is get a replacement lens, then you open up your DVD player, with the appropriate screwdriver, locate the lens and replace it with the new one you got for it.
Take care and good luck
Oct 15, 2010 | Samsung BD-P1200 Blu-Ray Disc Player
Cant read the discs,dvd,cd or blu ray, "no disc"
You need to purchase a dvd disc cleaner or buy a can of air from wal-mart and spray out the drawer and the inside of the player with the drawer open,the eye of the dvd player is probably dusty and can't read the disc...and make sure the dvd is clean with no finger prints on it.
Feb 26, 2010 | Sony BDP-S300 Blu-Ray Player
Disc drawer will not open with either the button on the set or the remote control. Display shows "open" the changes to "no disc"
Jan 19, 2010 | Televison & Video
Disc drawer won't open and sometimes doesn't power off
The disc drawer is broken, there are motors that open the drawer (what you hear when turned on and off) and it must of got damaged by a cd or some other way. If you want to open it, pry it open with your fingers or screwdriver. I had to take the 5 cd holders out to see the problem and there was a cd that jammed everything. But you might not have that, take a look. And the "bye bye" thing is normal but not if it wont go off at all.
Oct 06, 2009 | RCA RTD207 System
LG HT503PH Disc drawer will not open and displays "locked"
there should be a key synbol on the remote. press pwr off, then press the pwr on and the key button at the same time. The usual fault is the child lock has been activated.
Jan 05, 2009 | LG Televison & Video
Need region code for wharfidale L1911W-C
Try this
* Open the drawer
Press 0, 1, 2, 3, Play in sequence on the remote control
Play a region 1, 2 ,3 ,4 or any other region to see if the hack has worked!
The disc drawer can obscure the Infra-Red sensor when open, so ensure that you compensate for this when entereing the hack.
You can also return the player to Region 2 only mode using the following sequence:
* Open the drawer
* Press ZOOM
* Press RETURN
* Press POWER
Oct 06, 2008 | Wharfedale Televison & Video
Unit will not acknowledge presence of disc.
checkout hifiengine for service manual...free manuals when you join ( free too )
May 05, 2008 | Teac CD-P1440 CD Player
Televison & Video Logo
12 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
