Question about FoodSaver Smartseal V3485 Brushed Stainless Steel and Black
Foodsaver model v3485 will not vacuum air out of bag but will seal, what is not working?
Motor runs and accessory hose vacuums out container but unit will not **** the air out of bags. Unit will seal but won't **** air out of bags.
4 Suggested Answers
  • 9639 Answers
SOURCE: foodsaver vacuum sealer tray full light
Clean the two little contacts on the tray. Make absolutely sure there isn't anything across the two wires that run the length of the tray. It doesn't take much to trigger the light.
Posted on Jun 07, 2014
  • 44381 Answers
SOURCE: Trying to vacuum and seal the broccoli after blanching, cooling and letting it drain. It won't seal the bags. It vacuums the liquid til the tray fills, then shuts off. I start over. How to fix this?
I usually freeze the bag before sealing that way the food is not dry when wanting to use it. pour as much water off as you can tho hope it works for U also I freeze many pounds of fresh fish that way also
Posted on Jul 28, 2015
Tried the recommendation above, even have let it air dry for more than an hour, there is nothing moist around the three contacts. I, of course am in the middle of a huge project!
Posted on May 28, 2016
Cannot get it to vacuum.
Does it try to vacuum but never flattens the bag? Make sure the bag you are using is completely sealed on the opposite end. Otherwise, the seal on the sealer is probably allowing air to leak into the sealer. If it has a foam sealer, I've found it sometimes helps to run the foam sealer under water, squeeze out the excess water, reinsert the foam sealer (make sure it is seated all the way) and then try again to seal the bag.
Mar 07, 2016 | FoodSaver Food Saver Vacuum Sealer...
Foodsaver V3460 vacuum runs and sounds like it has reached the end of the cycle then seals bag.
then you do not have the bag in proper place in the sealer , mine has never failed .
Aug 05, 2015 | FoodSaver V3460 Vertical Vacuum Sealer,...
Foodsaver V3840 Won't vacuum air out and wont go to seal. A label states the seals are not removable. Do you know how to fix?
you are not using a "good" bag. Make sure there are no holes and that the bottom and sides of the bag are properly sealed. It will run all day and not pull the air out if the seal is broken anywhere.
Sep 11, 2014 | FoodSaver V3840 Vacuum Packaging System
V3420 foodsaver will not suck out the air
Is the motor still running?
If so it sounds like a blocked pipe
Aug 09, 2014 | FoodSaver V3420 Smart Seal Vacuum Sealer...
FOODSAVER V3880 DOESNT GET GOOD VACUUM IN BAG
Sounds like the foam seals are leaking. Go to their website to get replacement parts.
Mar 11, 2014 | FoodSaver V3880 Vacuum Sealer - The Master...
It won't seal it doesn't get hot it vacuums ok
There is a heating element in your unit that seals the bags. Most of the units you cannot replace the heating element. The company is pretty good about warrantying the units. They go by the number on the plug to tell if the unit is still in warranty. Give them a call. 877-777-8042
Jan 19, 2014 | FoodSaver V2222 Vacuum Food Sealer
Why there say tray full red light
The tape trick didn't work for me. Had to cut the wires. Works for now.
Sep 27, 2012 | FoodSaver Smart Seal Vacuum Sealer V3825
No suction to seal bag
is a hose unplugged? Unplug the devise and see if you can find anything that looks like it's not connected OR it has a hole in the hose.
Sep 07, 2012 | FoodSaver Vac 800 Vacuum-Sealing Kit,...
Model UH60010, Series X12.0, Mfg code K09A. While attempting to use the hose and the extensions to clean shelves, my wife reported no suction. I removed the brush roller and the plastic piece just below...
There are six different reasons a vacuum can lose suction, a plugged vacuum hose, bad motor, full vacuum bag, or cracked or damage hoses. Purchasing a vacuum cleaner can be a costly expense while repairing the suction on the unit can be virtually free. Most suction loss problems on a vacuum can be easily fixed or remedied with common house hold tools and very little technical expertise.
If your vacuum cleaner losses suction, the first and easiest solution is to check the bag. If the vacuum cleaner bag is full suction will be greatly reduced and the unit will become ineffective. A vacuum cleaner works by passing air through the bag fibers leaving dirt and debris behind inside the bag. If the refuse bag becomes full, airflow is restricted, limiting the amount of air passing through the vacuum bag resulting in loss of suction. When replacing the vacuum bag always consult your owners manual to insure that the vacuum bag seals with the vacuum inlet hose. If your vacuum cleaner bag is not tightly sealed to the vacuum inlet hose you will decrease the air flow through the bag resulting in loss of suction.
The second and sometimes most common reason for loss of suction on a vacuum cleaner is a plugged vacuum hose. If the hose becomes plugged, air flow will become restricted. To unplug a vacuum hose detach it from the machine and inspect the inside. If there is a restriction in the hose, remove it with your fingers and replace the hose onto the unit. If the hose is long and the debris is hard to get too, a broom handle or other long object can be passed through the hose to dislodge the debris. Most vacuum cleaners contain more that one suction hose, so make sure to check each one by process of elimination. Another area that can become easily plugged on a vacuum cleaner is under the lower base of the unit by the roller brush. Large debris can get caught in this area and restrict air flow to the hose.
If your vacuum refuse bag is not full and the suction hoses are not plugged the next thing to check is the condition of the hoses. Many hoses are made from plastic which can easily tear or crack. If your vacuum cleaner shows signs of wear or are cracked they need to be replaced. Even the smallest hole in a vacuum hose can leak enough air to greatly diminish the suction potential of your unit. Replace your vacuum cleaner parts with OEM parts from the original manufacturer to ensure the tightest fit.
Most vacuum cleaners contain filters. Filters are used as a last line of defense to remove dust and smaller debris particles before the air is recycled back into the environment. If vacuum cleaner filters become dirty or plugged they also can decrease the amount of air traveling through the unit. Some filters can be easily rinsed with water whereas others need to be replaced. It is important to check your owners manual before rinsing a vacuum filter.
The last and probably least common problem for a vacuum cleaner to loose suction is a bad or failing vacuum motor. Over time vacuum motors lose power due to worn carbon brushes or long term damage. A vacuum cleaners worst enemy is moisture. If water or moisture is sucked into the vacuum motor it will greatly diminish the amount of suction the unit has. Replacing a vac motor can be a costly and time consuming ordeal. In some cases, replacing a vacuum motor can outweigh the cost of buying a new vacuum. Vacuum suction is measured in water lift which can easily be measured by using a water lift gauge. If the water lift measured in inches, falls below half the original water lift specifications for the unit, it is time to replace your motor. Most vacuum cleaner repair shops carry this type of equipment and can easily tell you if it is time for a new vac motor.
Jul 25, 2010 | Vacuums
Dirt devil mvp not sucking
Could be bad filters, is there suction at the end of the hose. That will tell you which direction to start looking. If no suction at hose end, then filters could be the problem. If you have suction, then the problem is down lower, dirt inlet is clogged, if belt has never been changed, then I am sure it has stretch to the point that under load it doesn't turn like it should. Could even be that although the motor is running, it may be running at a slower speed, in which case it would have to be replaced.
Oct 14, 2007 | Dirt Devil 12 Amp HEPA Filter Vacuum...
FoodSaver Smartseal V3485 Brushed Stainless Steel and Black Logo
457 people viewed this question
Top FoodSaver Vacuums Experts
Lawrence Oravetz
J.D. Browning
J.D. Browning
ray gallant
Are you a FoodSaver Vacuum Expert? Answer questions, earn points and help others
