Question about IOGear Computers & Internet
Guwav screen resolution
Screen resolution changes when attached
Monitor displays /out of range 15.7hz/ 60hz
This usually happens when the frequency range of the monitor can not handle the refresh rate provided by the system. Did you tried to change the resolution or the refresh rate frequency of the system ? If yes then you have to revert the change. In case you are unable to make the change from with in the OS as message pops-up at the start-up i suggest attach an other screen and choose a lower resolution afterwards you can attach the same screen and hopefully the issue will be resolved.
Sep 21, 2013 | LG Computers & Internet
I am unable to change aspect control on my ASUS ML238 monitor, using monitor controls as they are not highligted on the menu. HDMI is selected however, but the monitor image does not cover the whole...
The resolution controls are on the device that is plugged in on the HDMI cable attached to your ASUS ML238. In other words, if it is a PC or laptop, you will need to go to the resolution settings to find the fitting screen resolution for your monitor.
See the link below for more detailed instructions.
How to Change Screen Resolution in Windows 10
Feb 20, 2018 | Computers & Internet
TOSHIBA REGZA 24" LCD/TV cannot
"JUST PRESS CINEMA MODE ON YOUR REMOTE CONTROL AND SELECT APPROPRATE VIEWING MODE" it might be located under the left of 0 with an image like stretching as indicated on my remote. It is the issue about the overscanning and underscanning of tv using HDMI connection. I have been the same problem as you but I did solved it using this. Hope this would help!
Mar 10, 2011 | Toshiba REGZA 47HL167 TV
The screen has gone small and i need to get it back to big can you help
If you are using XPRight click on your desktop and goto: Properties>Settings>And drag the 'Screen Resolution' Bar all the way to 'Less' If you are using Vista/7 Right click on your desktop and goto: Screen Resolution> And drop the resolution bar a move it to 'High'
Mar 01, 2011 | Computers & Internet
When i go to pc mode on my aquos 42 inch the background and screen is blue not the blue screen of death the set is 2 yrs old
That sounds like a resolution problem. If you have a PC attached to the TV, unplug the monitor cable, and plug a computer monitor to the computer. Change the resolution down to 1024x768, then try plugging back into the TV
Jan 12, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Have blank screen with box in middle Analog out of range 62.9kHz / 120Hz
whatever you are trying to attach to the tv is set to the wrong frequency. If it is a computer you need to change the video settings by attaching a known working monitor and selecting another resolution. You will have to keep trying if the new resolution doesnt work. trial and error is your only option here. it will work when you have a system that displays within that frequency and in a supported resolution.
GOOD LUCK AND PLS RATE THIS POST!!
Feb 21, 2010 | LG L1780U (Black, Silver) 17" LCD Monitor
I do not know how to change the resolution size on the screen
please go to desktop properties. select setting option and now you can change your computer resulation.
Aug 11, 2009 | Computers & Internet
Partial lcd display on laptop
Hi
Sometimes the resolution changes to an unusual setting when an external monitor is attached. make the LCD screen your main monitor and change the resolution to 1024x768 or 600x800 whichever is best.
Happy to help
CBZ
Apr 25, 2009 | Toshiba Tecra A4-S313 Notebook
Screen Resolution stuck at 640 by 480
you first install the audio drivers if the problem persists then attach AGP card then increase resolution and pc will ask question do you want to keep these settings say yes then you can see 1280x1024
Nov 26, 2008 | HP Vs17 17" LCD Flat Panel Monitor
Open Questions:
Computers & Internet Logo
44 people viewed this question
Top IOGear Computers & Internet Experts
Jose Velazquez
Jose Velazquez
Victorman
Victorman
Are you an IOGear Computer and Internet Expert? Answer questions, earn points and help others
