Question about Hitachi 53SWX12B 53" Rear Projection Television
MY 53' HITACHI PROJECTION LOOKS 3-D
I cant get to the convergance menu because i dont have the original remote. where can i get the original remote?
  • Hitachi Master
  • 8,617 Answers
Heres a link to a place that can get any original remotes. Just call or leave a email with your model number and what youre needing.
http://servicemanuals.vstore.ca/
Posted on Jun 23, 2009
I have a 57 inch rear projection t.v. the color looks 3d and the screen looks warped. the t.v is about 10 years old but i would like to fix it myself if i can. please help.
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 15, 2010 | Hitachi 53UDX10B 53" Rear Projection...
Tip
Distorted Video - Convergence Problems - 3D Looking
Your TV may have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
Screen is bowed in or warped.
Using your original remote go-to the tv settings then goto the convergence or magic focus section.
Try to adjust the convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Its a fairly easy fix on the Hitachi sets.
You can get a repair kit that includes all the parts from www.TvRepairKits.com. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc.
Everything you need to fix it yourself.
on Jan 29, 2009 | Hitachi 53SBX59B 53" Rear Projection...
My hitachi tv's picture is distorted red and green like a 3-d pic
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
  • Screen looks 3D
  • TV shuts off after powering on - TV may also make a chirping noise.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Feb 08, 2010 | Hitachi 57F710 TV
Hitachi 53SBX10B-color and horizontal lines issues
with the original Hitachi remote go into the customer menu and select convergence---you should get a cross in the middle of the screen--look to see which color will not move either up and down or left and right---sounds like bad convergence IC and this is not uncommon in most rear projection sets---if this is the problem the set uses two convergence output IC chips that both should be replaced and then the set adjusted in the Technical menu----the convergence mode can be engaged by removing the front grill and an inspection plate behind it and pushing a small micro switch located on the front of the board; when the switch is engaged with the set turned on a grid of lines will appear on the screen and then the set is adjusted with the remote---hope this was helpful---if you need direct assistance you can contact me : etower.766@netzero.net
Aug 11, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Have a 53" Hitachi HDTV that bows at the top and the bottom. I was told one of the transitors or transformes blew. I also do not have the regular magic focus just the static focus now. I tried to alli
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
  • Screen looks 3D
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
May 03, 2009 | Hitachi 53FDX20B 53" Rear Projection...
I have a blue wave on my screen
Solution:
Your TV has a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
Jan 28, 2009 | Hitachi 53SBX59B 53" Rear Projection...
How do i set convergance on my53uwx10B
you can go in through the back of the tv to set the focus you should be able to converge the tv from the remote.if not i would call a service tech and have them come and reset it for you.
Jan 21, 2009 | Hitachi 53UWX10B 53" Rear Projection...
Poor picture quality on Hitachi model # 53fdx01b
Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem. Doing so will only make things worse. The blog does however show you how to fix other common problems with these sets.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
Using your original remote go-to the tv settings then goto the convergence section.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Jan 20, 2009 | Hitachi 53FDX01B 53" Rear Projection...
When i turn on tv the screen is turning green
Solution:
Screen looks 3D
Screen is bowed in but stationary.
They have put together a kit for the Hitachi TV sets.
Everything you need to fix it yourself. Its a fairly easy fix on the Hitachi sets.
Dec 11, 2008 | Hitachi 53FDX20B 53" Rear Projection...
Hitachi Mo# 53uwx10ba double image
Solution:
  • Screen looks 3D
  • Screen is bowed in or warped.
Dec 03, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 53SWX12B 53" Rear Projection Television Logo
114 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
