Question about Opti -UPS BackUp-Time 525BT (UPS-525BT) UPS System
Red light is coming with beep in numeric 600ex
How do setup so I can fire only main 580 using 600ex-rt as master. the camera is 5D Mark lll. Also if want 2-1 ratio what camera and flash modes should I use. I don't understand the instructio
This video on youtube explains how to setup and use the 600 RT as a master. I do a lot of shooting with master slave, but my equipment is Nikon. Your gear is an excellent choice making it possible to shoot with remote flash. Canon 600ex rt Step by Step Setup Guide
Jan 10, 2015 | Canon Cameras
My ups is nu meric digital 600ex.my problem is whenever i on my ups a orange light is burning continuously and ups is not working what is problem in that i cant understand pls tell me solution
Hi Lokesh,
Orange lights on most UPS systems we've come across indicate that the unit is overloaded - you have too many things drawing too much power plugged into it.
Hope that helps.
If you need UPS, Surge, or Power Related help contact:
Daniel with Power & Systems Innovations 800.260.2259 or go to our website: http://psihq.com/
•• If this helped - click YES :) ••
May 26, 2014 | Computers & Internet
Numeric 600 ex redlight indication problem
i m the service technician of computer, cctv, printer ,monitor, ups etc.. numeric ups 600 ex problem red light and long beep .......
the problem is ups transformer ,, change or rewinding the transformer problem will be solve
Mar 02, 2014 | QVS NetStar (UPS650A) UPS System
Canon 600ex-rt speedlite won't turn on with new batteries
I was having exactly the same issue with my 600EX-RT. This is what solved the problem for me. With the power turned off. Hold down the 2 clear buttons for approximately 5 seconds, then turn the power on and hopefully, you should have a fully operational Flash.
Apr 14, 2013 | Canon Speedlite 600EX-RT 5296B002 Norman...
Car started beeping when driving down road
the beep beep is telling you that your parking brake is still on.
if the abs red light is on get it fixed, like, yesterday.
what price safety........
May 20, 2010 | 1997 Buick Riviera
Numeric UPS not working
when i on my ups it is indicating to fault showing a red light and giving a long beep sound and no output voltage is coming from it do i need to configure?please help me
May 10, 2010 | Opti -UPS BackUp-Time 525BT (UPS-525BT)...
My ps3 it goes green beeps twice then goes red and flashes on/off
you might be holding the power on button to long. you hold the power on button until it beeps to reset the video output. try turning it on by using your controller. just press the ps3 button and if the red light is on then it should come on.
Oct 14, 2009 | Sony Playstation 3 (PS3) Console
When just wblue wire is connected red light comes on
This sounds normal. The light comes on when there is 12v supplied to the blue wire (remote input). Need more details. brian.small@bobstgroup.com
Sep 13, 2009 | Pioneer GM-5200T Car Audio Amplifier
Red sensor
If your Roomba's red "check robot" light comes on, the Roomba should also give a hi-lo warning tone, then a number of beeps. Check the number of beeps with the chart toward the end of your manual-- it should tell you what to do.
May 29, 2009 | iRobot Roomba 560 Robotic Vacuum
Numeric ups with fault indication
Please Change Battery or Check the PCB Masfecter
Oct 14, 2008 | QVS NetStar (UPS650A) UPS System
Open Questions:
Opti -UPS BackUp-Time 525BT (UPS-525BT) UPS System Logo
67 people viewed this question
Top Opti Computers & Internet Experts
Jerry Greenberg
Jerry Greenberg
Rabbit Brains
Rabbit Brains
Power & Systems...
Power & Systems...
Are you an Opti Computer and Internet Expert? Answer questions, earn points and help others
