Question about Mtd Yard - Man 160cc, 21" Self - Propelled Lawn Mower
How do you replace a belt to a riding lawn mower?
My belt the moves my blades to the riding lawn mower has broken. I would like to repair it myself. How do I do this?
  • old fart58 May 11, 2010
    What kind of mower is it? Some models can be involved.
  • Dwain Pippen May 11, 2010
    You have to post the model number under the seat. There are too many different configurations on decks.
    Problem Solver:
  • 10 Answers
Basically, it is not a big job.
First thing to do is take the key out of the ignition Switch.
Secondly, Lower the deck to it's lowest position. Look for a belt that runs from the motor pulley to the deck. Now have someone move the lever that engages the blades.
A set of pullets should move when the lever is moved.
You need to get these pulleys unhooked from the cable or lever or both. Now you should be able to remove the worn belt.
Installation is the reverse of this. With the belt removed you should check the pulleys for wear on the bearings, especially the ones that the blades mount to.
You can also go to You Tube and search for lawnmower belt remove. There are about 1,000 or so there.
BE SAFE!
Paul
Posted on Jul 03, 2013
  • 496 Answers
You will need to get some information from your mower. Click on this link to get started:
http://www.outdoordistributors.com/MTD/MTDpartslists.html
Posted on Aug 25, 2009
Blades will not engage
when you actuate the "engage blade" lever, two things may occur,
First, a mechanical action, a spring moves to put tension onto the belt.
Second; at the end of its run, actuate a switch (PTF switch) to engage the clutch that moves the pulleys that consequentially move the blades.
if the tensioner is not moving , check if spring has come lose, undone or broken, (more likely in your case) or check the PTF switch.
any other assistance, contact me, good luck.
If you need further help, reach me via phone at https://www.6ya.com/expert/gerardo_79638d1eac6a0a1f
Apr 20, 2014 | Husqvarna Riding Lawn Mower 46 Cut Kohler...
Was mowing and mower quit moving.could this be clutch
Its possible but check drive belt as well. If it comes off or broken mower will not move.
Mar 29, 2014 | Snapper RE110 28 inch 11.5 HP Rear Engine...
Dont know wheter to get primary mower belt or secondary mower belt for craftsman gt3000 48 inch deck mower...?
primary belt goes from the engine to the deck the secondary goes on the deck and connects the blades together
Aug 24, 2012 | Craftsman 48" Cut Riding Lawn Mower Deck...
Slow moving belt for the mower blades on Craftsman riding mower
craftsman belts are not the same as automotive belts. check with sears for the new belt and how it is routed .
May 21, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
If the belt comes off a riding lawn mower...will it still cut grass
Probably not.
I would expect to find two belts on a riding mower; one to drive the riding lawn mower (lets call this the DRIVER) and one to drive the actual mower part (lets call this the MOWER).
To answer your question one way, if the driver belt is off, it will still cut grass, but you cant move the mower. If the mower belt is off, it will move but not cut the grass.
If your belt is broken, take it to an automotive parts store or garden equipment place for replacement. You might also support a FixYa.com advertiser.
I hope this answers your question. Thanks for posting at FixYa.com and please vote.
thanks
a
Nov 14, 2009 | Garden
Put new belt on riding lawn mower now blade wont engage
Check to make sure that the inline fuze is not blown on your switch to your deck. also make sure that the belt is free moving and not binding
Jul 14, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Will not move runs great mower blades ingage but does not respond to forward or reverse.
the belt running to the back tires has either slipped off r broken off. to get to it you simply go to the back and remove the plate in between rear wheels.
Jun 14, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Blade belt diagram for John Deere LX178 Riding
Remember the belt rule, V of the belt goes in V pulleys.Flat pulleys that are stationary or move get the back of the belt. You can figure it out. Its not rocket science. Remember at some point there has to be a tensioner,usually gets the back of the belt if its a flat pulley. U may have to remove the spring and then reattach the spring after the belt is routed.
Jun 07, 2009 | Garden
Owners manual
Maintaining Riding Mowers Regular maintenance can reduce repairs. pagetools_04a.gif spacer.gif spacer.gif
Components of a typical riding lawn mower. (click to enlarge)
It's fun to ride around the yard on the mower, watching scrubby grass (and weeds) turn into trimmed lawn. However, when the grass looks as bad after you mow as it did before, or the mower doesn't want to start, riding mowers aren't as much fun. That's when it's time to put on your Fix-It Club hat and have some more fun.
A riding lawn mower is a gas-powered machine for cutting grass. The engine turns a rotating blade that cuts the top off the grass blades to a specified height. The operator sits atop the mower on a tractor-type seat with speed and height controls nearby. Riding mowers also can be used to pull small utility carts for other yard jobs.
To remove the mower deck:
  1. Make sure that the parking brake is locked.
  2. Place scrap lumber under the front and rear of the deck.
  3. Use the deck lever to lower the deck.
  4. Remove attachments from the deck.
  5. Remove the blade drive belt from the front pulley.
  6. Remove the front and rear deck fasteners, following instructions in your owner's manual.
  7. Use the deck lever to raise the deck.
  8. Remove the scrap lumber.
  9. Remove the deck from under the mower.
To adjust the drive belt:
  1. Remove the belt from the large idler pulley.
  2. Remove the belt from the adjustable idler pulley.
  3. Carefully remove the spring-loaded large idler pulley.
  4. Loosen the adjustable idler pulley and move it slightly toward the rear of the mower to tighten it[md]or move it toward the front to loosen it—and retighten the pulley.
  5. Replace the belt.
  6. Check belt tension and readjust as needed.
Apr 12, 2009 | Garden
Mtd Yard - Man 160cc, 21" Self - Propelled Lawn Mower Logo
333 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
