Question about GE Profile PSC23MGTBB Counter Depth Side by Side Refrigerator w/ Dispenser & Climate Keeper Temperat...
GE Profile water on top bottom freezer door.
I have GE Profile with to bottom freezer doors. water/condensation collects on the top of the bottom freezer drawer multiple times/day.
Also ice maker is very slow.
Any suggestions?
  • 111 Answers
Door gasket its not sealing properly
Posted on Jun 23, 2009
  • Ahmad AlAkoum
    Ahmad AlAkoum Sep 17, 2013
    I checked the door gasket it is sealing properly; i'm guessing it is the heating element that is messed up
Water collecting inside fridge, under meat drawer
Yes most responses are the freezer drain even if it is in the bottom freezer. If the drain is blocked water will build up anywhere inside your refrigerator only because it has no place to go during the defrost. Defective door seals can also can make the problem much worse. See Leaking Refrigerators I am here should you need me, Thanks John Tripp Appliance 911
Apr 21, 2014 | GE Profile 22.2 Cu. Ft. Side-by-Side...
Water is collecting on top shelf (toward the back) of refrigerator. I believe it's related to the defrost mechanism for the freezer which is above refrig, but not sure. Can't see where water is coming...
Most times the water might be from defrost liquid pooling up from a clogged drain hole but it might be from bad door seal OR dirty condenser. Try and clean out the condenser area where the air flow will be at its maximum and raise the legs lightly in front to throw the weight of the doors towards the rear of the box to make them close their seals tighter.
GE bottom Mount Service Manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 04, 2011 | GE Refrigerators
My GE Profile PS123SGPA BS side by side keeps dripping water from the water dipenser
Frigidare Model FRS26H5AS Side by side HELP!!!
Water collects and freezes in the bottom of my Freezer eventually leaking out the freezer door.
Thank you!!! bstrickmaker@neo.rr.com
Feb 15, 2010 | Frigidaire FRS26H5AS Side by Side...
Water build up on inside of fridge door of ge french door fridge
humid air in the house. any time you open the fridge, house air is sucked in. when you close it, the fridge cools the air and moisture from the warm air condenses on any cold surface. also check to see if there is a gap in the seal.
Aug 26, 2009 | GE Profile Bottom-Freezer Refrigerator...
Door condesation
Hi, THere is either a door seal leaking or the moister switch located on the control panel is turned off. Check your door seals to make sure there are no rips.
I hope this helps. Please let me know if I can assist you further.
Vic
Jun 02, 2009 | GE Profile PSC23MGTBB Counter Depth Side...
Water is leaking from somewhere in freezer
Check and see if the door seal is ok any gaps and condensation will build up and freeze ,see how you get on!
Mar 05, 2009 | GE Refrigerators
Ge armoire style condensation on freezer door
the condensation is due to a small amount of cold freezer air getting past the gasket. Warm the entire gasket up for a few minutes with a hair dryer and then close the door and keep it closed for 30 minutes. That will reshape your gasket and solve your problem.
please rate this answer as a fixya!
Mar 04, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ge refrig
I have a ge profile side by side. when it auto defrosts the water runs to the bottom and out the freezer door instead of down the drian??
May 31, 2008 | GE Profile Arctica Stainless Steel Top...
Ge profile leaks from front of freezer
your drain will be plugged under the tray. there is a hose that runs to the drip tray. the back cover comes off you can then get at the hose
Sep 05, 2007 | GE GSS25JEMWW Side by Side
Refrigerators Logo
501 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
