Question about Blitzz Technology (BWA611) Router
Laptop will not connect to internet/router
I was using it this morning and it went off the net and I cannot get back on. It now says "This computer does not have a wireless network adapter installed and configured" What happened and how can I fix this problem?
  • berry_linda Jun 24, 2009
    Thank you. I cannot even find the wireless network adapter. When I click on wireless assistant there nothing happens.
  • 390 Answers
This issue is more connected to your system than with the router
seems that somehow the network adapter has been uninstalled ple reinstall the network driver and then try connecting to the router
also just a check before all that have you checked if the wireless lan on the laptop is activated first
cheers
Posted on Jun 23, 2009
  • Pavan Ponangi
    Pavan Ponangi Jun 25, 2009
    are you able to see that your network adapter is present on the Device manager if the answer is no then i think there might be hardware issue if its a desktop then remove and reattach the N/W card and pls reinstall the required drivers
    but if you are able to see that the network adapter is present on the device manager then you might want to check on the services like Wireless Zero Configuration are started
    most laptops have a shortcut key to activate and deactive the wireless conection check to see its position also
    also just as a test case try turning off the windows firewall and check to see if you can connect to the internet
    on the other hand pls mention your computer make and model
    hope this helps
    cheers
Hello, I do not know much about troubleshooting internet connections. I just rely on Microsoft's "Diagnose Problem" option and most often than not, it works. But when I replaced our old...
Thank you for using fixya.
Being that your other computers in the network are working properly, you should switch the ip settings on your comnputer to automatically detect. That way your computer does all the routing and ip setting,
After you have set that back. Remove the power of your router, remove the power of your modem, and restart your computer.
Once your computer is back up, turn on modem, then the router.
It sounds very simple, but in most cases, it solves the problem.
Hope this information is helpful
Jul 18, 2011 | Belkin Basic Wireless Router
I have a Belkin Surf Wireless Router Model F7D2302 v1. It was working great at 4am this morning. I logged off and all was well. When my wife went to log on this morning about 8am there was no...
1. check the power to the router unit.
2. check with you ISP ( Internet Service Provider) to see if connectivity to your router was interrupted. You may have to reset the router.
3. here are some instructions to follow:
1.Log into router. Using either 192.168.0.1 to 192.168.1.1 in a browser window that is ( internet Explorer or Firefox)
2. Verify wireless router name( on the computer) >>> ( on/off) ( router status window)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP addresses.
5. Set the laptop up in the router by WEP KEY or MAC address. This set up in the "security tab" in the router. using 192.168.0.1 or 192.168.1.1 to access through a browser.
6.Note router name you are connecting to.
7. Move the laptop about 20ft away and try to log on to the internet.
This is for all routers to set up wirelessly.
8. check for firmware update at the manufacturers site for your model router
Apr 05, 2011 | Belkin Computers & Internet
Lost internet,
Are you on vista? This sounds a lot like a problem I had on windows vista. Instead of trying to fix windows vista, how about you uninstall it, throw it away, then buy either windows xp or windows 7 and be much happier.
Jul 18, 2010 | Dell Computers & Internet
I went from a ATT dsl modem to a net gear modem and i cannot get the net ger mode and linksys mode to talk to the computer
Most DSL providers use PPPoE (Point-to-Point Protocol over Ethernet) to establish Internet connections for end-users. To set up a Linksys router, you need to enable PPPoE on the router’s web-based setup page.
To setup a Linksys router with a DSL connection you need to perform four steps:
  1. Verifying Internet Connection
  2. Connecting the Devices Together
  3. Checking the LEDs
  4. Setting-up a DSL ISP on a Linksys Router
Connect the Broadband modem to the computer using an Ethernet cable without the router installed and make sure that the Internet connection is active. If not, contact your Internet Service Provider.
Aug 01, 2009 | Linksys Wireless-G Broadband Router
Can only connect 1 computer to 'net on router
rourke, you shouldn't be entering the same settings on both router and desktop. I should only be on the router. It seems like something with DHCP is misconfigured on your router. Make sure it (DHCP) is enabled.
Feb 07, 2009 | NetGear DG834 Router
Belkin G Wireless router not connecting to net
Did you save the IP addresses ?You may have to configure the router manualy go to your network ,settings or type in run box IP config and see whats going on
Dec 27, 2008 | Belkin (F5D7230-4) Router (587009)
Router Suddenly stopped working...?
try power cycling your network (turn off all of the hardware)
First turn off the computer,
second, the router;
lastly the router (wgr614).
Now, turn the hardware in this order:
  1. Turn on Modem. Wait 2 minutes.
  2. Turn on Router (wgr614). wait 1 minute.
  3. Now turn on the Computer(s).
this should refresh your internet connection. If not, check your routers settings for any wrong info.
to access your router's homepage, type this (http://www.routerlogin.net) into Internet Explorer.
Aug 11, 2008 | NetGear WGR614 Wireless Router
Wireless router, laptop problems
Try to delete all the prefered networks. Right-Click Wireless Network Connection, View Available Wireless Networks. Click on Change the Order of Prefered Networks. Remove all prefered networks there and click OK. Now try to View the available wireless networks again, reconnect to your own wireless network and see if it connects fine. Post your feedback.
Jul 12, 2008 | Linksys Wireless-G WRT54G Router
Blitzz Technology (BWA611) Router Logo
147 people viewed this question
Top Blitzz Technology Computers & Internet Experts
Michael Galve
Michael Galve
didi2005
JP Services
JP Services
Are you a Blitzz Technology Computer and Internet Expert? Answer questions, earn points and help others
