Question about Amana NTW4700YQ: 3.4 cu. ft. Top Load Washer with a Dual Action Agitator
Why won't my top load washer model NTW4700YQ1 spin?
My washer will fill and drain no problem in any cycle, but will not spin to get water out. The washer is about a year old and not sure what the problem is causing it not to spin.
wagdom
  • 64 Answers
SOURCE: Model LW6501W2
Sounds like the outlet pump has siezed up due to having been stood for so long. You may need to take the pump apart, clean the shaft & reassemble. Or, you could try a spray with WD 40 on the pump. TURN POWER OFF FIRST
Posted on Oct 26, 2007
SOURCE: Amana ALW480DAW Top Load Washer
sometimes the pump becomes stripped where the motor shaft goes into it.
Posted on Jan 30, 2008
  • 156 Answers
SOURCE: washer wont drain or spin just hums and then blows fuse
bad motor
Posted on Feb 25, 2008
SOURCE: won't drain or spin
Sounds like the lid switch which is only about 30.00 to fix if you do it yourself. It's a little difficult but it's much better than replacing or having someone come in and do it
Posted on Mar 11, 2009
smartr10U
  • 1305 Answers
SOURCE: amana nav5800aww water on floor after spin cycle
Sounds very similar to having something such as a sock or small article of clothing that is too large to be sucked down the drain hose into the pump. So what happens is it hangs around between the inner and outer drums and sometimes gets itself lodged over the drum drain hole, and can allow water to be centrifically flung over the top of the drum. Most times when the spin cycle stops, the article of clothing will dislodge and float around inside the drum only to do it again later....
If you can remove the top of the machine, you can usually see the gap between the two drums and use a piece of coathanger wire with a small hook on the end and "go fishing in the area between the two drums and close to the drain hole location... bet you'll find something in there... Let me know how it goes... and if I can help .. ken
Posted on May 10, 2009
The washer fills agitate but won't spin & drain
Possible fault with the program controller unit. You need to check the program cycle outputs using a multimeter connected to measure the output voltage. On start the inlet should open and then close as the water level sensors works and then proceed to wash. So this much seems OK. Now in the next step the drain valve must open to drain off, then fill once again with the inlet working and water level being sensed. If there is no output in this section cycle then the prrogram controller has errors within the memory . You can remove the panel and reset all connectors and connections.
Oct 30, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
Top load washer won't go through cycle
modle problem here its the main board common fault with this model good luck
Mar 26, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
I have a Kenmore top loading washer model #110 and won't agitate
First, see the Sears parts site for your washer.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.23912100
Also see the Whirlpool (Kenmore) Service Manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
The first thing I'd try is using a different cycle. If the washer works as it should, the problem points to the timer.
I'd also check to make sure that when replacing the switch, the connections to the timer haven't come loose.
Since you've replaced the Lid Switch, the motor has power for the drain and spin cycles.
These washers use a reversing motor. The motor turns one way for agitating and reverses for the drain and spin.
Since you cannot hear anything when it is supposed to be agitating, the problem does point to the timer or motor.
Nov 14, 2009 | Kenmore 22422 Top Load Washer
Does washer drain before the spin cycle starts?
Normally yes. There are around 12 to 20 gallons of water in the tub after the wash cycle, which will be anywhere from 63 to 110 pounds of weight in addition to the weight of the clothes. For the machine to start the spin cycle to remove this water would place a heavy load on the motor, gearcase, pullys, belts, gears, ect. With the water drained, the load is lighter, and much easier to start spinning the excess water out of the clothes. The normal cycles are: Fill, Agitate, Drain, Spin, Rinse Fill, Agitate for rinse, Drain, Spin Cycle and off. Imagine trying to spin a 5 gallon bucket of water over your head, full of water, and then empty. Which one do you think would be easier to do? And safer for you.
Sep 26, 2009 | Admiral AW22 Top Load Washer
GE Washer does not drain or spin
Inspect the drain hose for kinks
Test the timer control
Test the lid switch (some models)
Inspect the water pump
Inspect the drive belt (belt drive only)
Inspect the motor coupler
Jul 15, 2009 | GE WDSR2080D Top Load Washer
Washer won;t drain or start spinning
check the lid switch if its ok
you have a problem with the timer
replace it
Jul 05, 2009 | Kenmore 24032\24036 Top Load Washer
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Washer will fill with water but the agitator won't spin.
No agitation or spin in any cycle? If so and the machine will drain check the coupler.
Oct 08, 2008 | Kenmore 24032\24036 Top Load Washer
Amana NTW4700YQ: 3.4 cu. ft. Top Load Washer with a Dual Action Agitator Logo
151 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Terry Schneider
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
