Question about Indesit 18 in. D41 Slim-Line Free-standing Dishwasher
Indesit Dishwasher Power switch on, but dishwasher not working.
  • 641 Answers
SOURCE: Water filling does not stop
Water supply to the dishwasher is done through an electromagnet valve,loocated at the water pipe's enterance to the machine. A defect in the valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it, and the valve may leak and drip water into the tub.You can easyly open the valve and clean it (from scale or other dirt). Be aware you should disconnect the power cable from the machine before doing it !!!!! and as well to close water main tap to the machine. In case cleaning doesn't help, you should replace the valve. Good luck !!
Posted on Jun 24, 2006
SOURCE: Broken door handle Indesit dishwasher DG 6100
broken door handle solution
Posted on Mar 07, 2008
SOURCE: dishwasher indesit DI62
green light 2 flashing sounds like machines doing something switched of at mains & back on to same flashing green light
Posted on Nov 23, 2008
SOURCE: Indesit IDL40 Dishwasher
from indesit website http://www.indesit.co.uk/indesit/_pdf/manuals/19504287203_UK.pdf
Posted on May 12, 2009
SOURCE: indesit dishwasher
On a D61 I managed to solve this without dismantling the door!
If you look carefully in the hole where the white catch fits you can see the shaft it rocks on. I put a small screwdriver in here and levered it forwards. It didn't want to stay so I put another screwdriver behind the white plastic bit, removed the original screwdriver, and continued to prise the white plastic bit forward until it clicked and stayed. I reckon it is caused by slamming the door. Don
Posted on Apr 04, 2010
Power on but mechine not start
If you are able to select the program but start button is not responding, then the door latch switch is not detecting closure of the dishwasher. Need to check this out.
http://www.indesit.co.uk/_pdf/booklets/02/45/19507195700_UK-USA-AUS.pdf
If the situation detailed on page 12 is not helping then see this diagram.http://www.espares.co.uk/product/es836224/dishwasher-door-lock?ModelId=1124397
Apr 18, 2014 | Indesit DF125 24 in. Built-in Dishwasher
Indesit D41 dishwasher, switch it on to program,
if applaince does not start draining then there is a possible fault with the door locking assembly,and the appliance thinks the door is open and this will not allow the appliance to start
Jun 28, 2009 | Indesit 18 in. D41 Slim-Line Free-standing...
Indesit IDL 530 Dishwasher
Switch off, turn off power, turn off water, disconnect water inlet hose, check for blockages, remove filters, clean filters, refit filters, check water supply, reconnect water supply, reconnect power, turn on - problem solved.
Apr 12, 2008 | Indesit Dishwashers
Dishwasher indesit DI62
Mar 01, 2008 | Indesit 18 in. D41 Slim-Line Free-standing...
Dishwasher
Check to see how fast water is entering the dishwasher.
They work on a timed basis with a float switch being a safety.
You may want to check how the water gets into the dishwasher and  then see if there is plugging somewhere.
Feb 16, 2008 | Indesit 24 in. D61 Free-standing...
Indesit dishwasher.
It sounds like the anti flood switch is activated, lean the dishwasher back at a 45 degree angle. If water comes out the back you have a leak. Stand it up and try it try dishwasher, if it works this comfirms leak, you will need to find where it is coming from.
Dec 03, 2007 | Indesit 18 in. D41 Slim-Line Free-standing...
Indesit 18 in. D41 Slim-Line Free-standing Dishwasher Logo
23 people viewed this question
Top Indesit Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Eric Taylor
Level 1 Expert
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
