Question about Dell Inspiron 4100/8100 Notebook
Point restoration missing - Dell Inspiron 4100/8100 Notebook
File is missing
The Error Code 0Xc004e003 error may be caused by windows system files damage. The corrupted system files entries can be a real threat to the well being of your computer.
To fix Error Code 0Xc004e003 Windows 7 Error:
Advanced Computer User Solution:
1) Start your computer and log on as an administrator.
2) Click the Start button then select All Programs, Accessories, System Tools, and then click System Restore.
3) In the new window, select "Restore my computer to an earlier time" option and then click Next.
4) Select the most recent system restore point from the "On this list, click a restore point" list, and then click Next.
5) Click Next on the confirmation window.
6) Restarts the computer when the restoration is finished.
Jan 25, 2014 | Microsoft Windows 7 Ultimate, Full Version...
System restore for Acer Aspire one
Try going back in time. Win7? Press Start, type "restore point" in the search box and select restore to an earlier time.
This will not affect your data just your registry..
Nov 28, 2013 | Acer Aspire One PC Notebook
Missing bdfdll.sys
Hi! Welcome to FixYA!
File bdfdll.sys is located in a subfolder of "C:\Program Files". Known file sizes on Windows XP are 8,704 bytes (61% of all occurrence), 7,808 bytes. However, some malware camouflage themselves as bdfdll.sys, particularly if they are located in c:\windows or c:\windows\system32 folder.So I suggest you run a full scan.If that doesn't work , you may try doing a system retore to bring the computer back in time when the issue is not yet present. For Windows XP:
1. Click Start, point to All Programs, point to Accessories, point to System Tools, and then click System Restore.
2. On the Welcome to System Restore page, click to select the Restore my computer to an earlier time option, and then click Next.
3. On the Select a Restore Point page, click the most recent system restore point in the On this list, click a restore point list, and then click Next.
Note A System Restore message may appear that lists configuration changes that System Restore will make. Click OK.
4. On the Confirm Restore Point Selection page, click Next. System Restore restores the previous Windows XP configuration, and then restarts the computer.
5. Log on to the computer as an Administrator. Then click OK on the System Restore Restoration Complete page.
For Vista or 7:
1. From within Windows, you can just type restore into the Start menu search box, and you'll immediately see System Restore at the top of the start menu:
2. Then please follow the on-screen instructions.
Hope this helps.
Jun 23, 2011 | Computers & Internet
Missing plug-inn?i want to restore
Title:missing plug-inn?i want to restore
If you set a restore point then do as --
To set a System Restore Point...
  • Open the Start menu
  • Open the Programs menu
  • Open the Accessories menu
  • Open the System Tools menu
  • Finally, start System Restore
  • Pick the option for setting a System Restore Point and click on the Next button
  • Fill in a name for the restore point so you can find it and click on the Create button
  • Click on the Close button when done
Recovery---
In Windows XP, Windows Vista and Windows 7, if booting all the way into normal mode causes problems, such as features that don't work, freezes, etc., it is possible to backdate Windows itself to an earlier state when it was working properly by restoring a restore point created automatically or manually by or in System Restore.
You should know that System Restore does not back up and restore non-system files or third-party software or any changes made by such software. It also does not involve restoring the data files on the computer. Only the essential files required to get Windows running are involved in the creation of its dated restore points that take the system files back to the date on which a particular restore point was created. Nor does System Restore clean up files left over by a botched software installation, which is a common cause of corrupted system files, and it can't be used to restore selectively files that have been accidentally erased. In other words, System Restore is a very handy tool that has saved my PCs on numerous occasions, but it is not a substitute for a full system backup, such as the creation of a disk image of the system, and should never be relied upon as such.
May 07, 2011 | Microsoft Windows XP Professional
Missing <Windows
you need to do a restore form a restore point or full restore
Apr 26, 2010 | Dell Latitude D610 Notebook
When trying to back date my computer through system restore, it will only let me go back 4 days. I want to go back 2 weeks. what's happening ?
Hai,
This happens when the restore point was successfull created or it could be a problem with missing files in restore point, however you can restore the computer upto 14 days back, it could not restore if you trying to restore more that 14 days.
It's purely corruption of the restore point files, however let us try to restore the computer using safe mode options.
Restart the computer and keepon tapping F8 key and you will see advanced boot options, please select safe mode and press enter, from safe mode try to restore you computer.
This should fix the issue.
Feb 03, 2010 | Computers & Internet
When i turn on my pc, it showing one message every time"script file windows/system32/virus cleaner vbe. is missing.
To use System Restore to restore Windows XP to a previous state, follow these steps:
  1. Log on to Windows as Administrator.
  2. Click Start, point to All Programs, point to Accessories, point to System Tools, and then click System Restore. System Restore starts.
  3. On the Welcome to System Restore page, click Restore my computer to an earlier time (if it is not already selected), and then click Next.
  4. On the Select a Restore Point page, click the most recent system restore point in theOn this list, click a restore point list, and then click Next.
  5. On the Confirm Restore Point Selection page, click Next. System Restore restores the previous Windows XP configuration, and then restarts the computer.
  6. Log on to the computer as Administrator. The System Restore Restoration Completepage is displayed.
  7. Click OK.
If you successfully restored your computer to a previous state, and the computer is performing as it should be, you are finished.
Thanks, PREM
Mar 31, 2009 | Microsoft Windows XP Professional
Missing files and photos, settings ect
Log in as Administrator and undo the system restore.
How to undo a system restoration after you perform a System Restore loadTOCNode(2, 'moreinformation'); You may have unintentionally restored Windows XP to a previous configuration that you do not want. To undo the restoration, follow these steps:
  3. On the Welcome to System Restore page, click Undo my last restoration, and then click Next.
  4. On the Confirm Restoration Undo page, click Next. System Restore restores the original Windows XP configuration, and then restarts the computer.
  5. Log on to the computer as Administrator. The System Restore Undo Complete page appears.
  6. Click OK. You can now run System Restore again from a different restore point.
Dec 16, 2008 | Dell Inspiron 1501 Notebook
How to get more restore point fron corrupted windows 98 registry. my friends move all directory to d: drive. how to bring back to C :
Hey there
The first thing that you should aware of is you cannot move the system file that are currently being used by another program to any of the directory. If it is so then you wont be able to log on to ur computer. because it will give you a lot error of missing system files.
For restoring your system do the following:
1. Go to Start -> All Programs -> Accessories ->System Tools
and select System Restore
2. Go to next window, Choose the restore point that is available remembering ur system was exactly what you wanted for.
3. Select that restore point by reading the description.
4. Click next to restore.
Note: Your system will restart after choosing the restore point and clicking next. It takes some time to restore.
for creating the restore point, follow the same step specified above except the second one. you need to select create new restore point insted of choosing restore point to restore.
Type a restore name and click next to create.
Gimme ur acknowledge by rating me
thanx
Romy
Jul 05, 2008 | Microsoft Windows 98 for PC
Restore point
Did you want to revert to a previous Restore Point or create a new one?
Comment back rather than create a new post please.
Thanks,
Worldvet
May 21, 2008 | Computers & Internet
Computers & Internet Logo
11 people viewed this question
Alun Cox
