Heating & Cooling Logo
Posted on Jun 23, 2009
No cold air from unit #aqv36jan turbo light flashes. light flashes with no breaks to detect problem code
1 Related Answer
Anonymous
  • 11 Answers
  • Posted on Jun 12, 2010
SOURCE: I have two indoor condensores, one with both
You need a new pc board. You can buy one from http://paylessminisplit.com
1helpful
Glow plug light flashing
did you use the interface to cancel limp mode
you know its in limp mode
what was the printout of the diag
its aok to post i have a problem and this is the issues
but in limp mode you have no choice but too use software too fix the ecu etc to reset the mode fault etc
i think its the cold start system with air has an issue
if the glow plug light is flashing and the glow plugs are ok then its a sensor problem and a needed reset of the mcu to clear the error and retest...
from cold...!!
warm engine is prob aok
something air related
Why my unit keep shutting off after few seconds and then turbo light keep on flashing?
Operation =
Flashing Display Timer = Yes
Turbo =
LED Display = E1
Explanation and Checking points = Indoor unit room thermistor error - Open or Closed Circuit - Check and replace if required
Operation = Yes
Turbo =
LED Display = E2
Explanation and Checking points = Indoor unit pipe thermistor error - - Open or Closed Circuit - Check and replace if required
Operation =
Turbo = Yes
LED Display = E3
Explanation and Checking points = Indoor unit fan motor malfunction - Check and replace if required
Operation =
Turbo = Yes
LED Display = E6
Explanation and Checking points = EPROM error - Check and replace PCB if required
Operation = Yes
Turbo = Yes
LED Display = Flashing
Explanation and Checking points = Option code error - Check and input new option code if required via wireless remote controller
Operation = Yes
Turbo = Yes
LED Display =
Explanation and Checking points = Outdoor unit temperature sensor - Open or Closed Circuit - Check and replace if required
Green light flashing on wall unit - no cold air?
Compressor should switch on after 3 minutes.And if it does and still no cold air coming out of the inverter.Then unit needs to be gased.
1helpful
Cold start valve
while you are at the garage , have then read the fault codes
what there is on the turbo is a set of vanes in the turbine shell that redirect the exhaust gas onto the turbine wheel to give quicker response on acceleration at low rpms
when running at rpms these vanes move to allow unrestricted gas flow to the turbine and to the exhaust system
those vanes operate in very high temperatures and do become stuck and so don't move freely
there is a vacuum operated actuator on the turbo housing that moves the lever for those vanes and that hose to the actuator gets hard and cracks or fails
there is a sensor that controls that vacuum to that actuator
people call different things by different names so one persons cold start is another person actuator or sensor
the turbo can be repaired in an accredited turbo shop if that is the problem and that would be the only thing that could cost up to and around the price of a new turbo
Cold start valve
use a code reader to reset the computer. As to the cold start valve have the subaru mechanic point it out just to see if he is telling tales or not.
1helpful
2answers
Engine warning light came on. Diagnostic
P0411-Secondary Air Injection Incorrect Upstream Flow Detected. Could be the vacuum hose, combi-valve, and/or the pump http://www.passatworld.com/forums/showthread.php?t=170246. Read that thread and see if you think you or maybe somebody you know can tackle the problem.
1helpful
Genie Aire PACR12-GE - Warning light flashes 3 times-No cold air
Turn the unit off, check the bottom rear of the unit and place a shallow pan under the drain outlet and remove the rubber plug to drain the condensate out of the unit then replace the plug and turn the unit back on.
5helpful
2answers
Checking the fault codes
Yes.  Next to the ash tray there is a black slide off plate that reveals the OBD I plug.  {1996 and newer can be read with an OBD II reader (read for free at Advance auto or Auto Zone)}  Once you reveal this plug on the 1995, you can plug in a single jumper wire (or even a paper clip) in the #4 and #15 pin hole.  There are two rows of pin holes, count from the upper right to the #4, then on to #15 (which will be the second to last pin hole).  Turn the ignition switch on (motor not running), insert the jumper wire for about 3 to 5 seconds, then remove the wire.  The ENGINE LIGHT will flash a hold, then the code, which will go something like this, flash, flash, PAUSE, flash, flash, PAUSE, flash, PAUSE, flash, flash, flash, flash.  Then it will repeat the codes if you just sit there and observe it.  The code in my example would be a 2214 code.
Below are some code I found on a website.  I hope this helps.  Now I ask that you take the time to answer someone elses question.  Lets all share.  Good luck, "Peace through power and knowledge"
CODE FAULT
0000 End of fault sequence
1111 Bad ground to Electronic Control Unit (ECU) or ECU failure-check grounds or replace
ECU
1119 Transmission Range - Defective wiring. Check for break or short.
1213 Vehicle Speed Sensor (VSS) - Check transmission speed sender wiring and the wiring of
the instrument cluster
1231 Vehicle Speed Sensor (VSS) (G54) - Check transmission speed sender wiring and the
wiring of the instrument cluster
1232 Throttle Position Actuator - Check defective actuator or wiring for break or short.
2111 Engine speed sender. (RPM)
2112 Ignition reference sender
2113 Hall sender - No speed signal from distributor; check Hall sensor and circuits or the
Air-flow sensor plate is not moving freely; adjust potentiometer or lever.
2114 Hall sender not on reference point or distributor out of position.
2121 Idle switch - check switch & circuit.
2122 Hall sender - Check wiring for break or short.
2123 Full throttle switch; check switch & circuit.
2132 Electronic Control Module (ECM) - No ignition to injection signal.
2141 Knock sensor 1 control at maximum ****** - test compression, change octane, adjust
timing, check knock-sensor wires.
2142 Knock sensor 1 signal - Test sensor, check wiring for break or short.
2143 Knock sensor 2 control at maximum ****** - test compression, change octane, adjust
2144 Knock sensor 2 signal; test sensor.
2212 Throttle Potentiometer - Value out of range.
2214 RPM Signal - Idle speed to high or engine over-revved
2221 Vacuum Control - No vacuum to control unit. Check for leaks.
2222 Manifold Vacuum - Check vacuum line and wastegate for leaks.
Pressure sensor - Sensor defective
2223 Altitude Sensor - Check sensor, check wiring for break or short.
2224 Turbo/Manifold pressure - Check turbo control wiring, check for over boost, air leak,
defective wastegate valve, vacuum leak or defective pressure sensor.
2231 Idle-speed stabilizer adjustment limits exceeded; too-fast idle. Adjust throttle for full
closing, check for vacuum leak, check ignition timing.
Or
Air Mass Sensor - Check sensor and wiring.
2232 Air mass/flow sensor - No signal. Check wiring for break or short.
2233 Air mass/flow sensor reference voltage open or short circuit
2234 ECM Supply voltage low.
2242 CO-potentiometer voltage low
2312 Coolant temperature sensor - Check wiring, check resistance.
2314 Transmission to Engine control module circuit. - Check wires for breaks or shorts.
2322 Intake Air Temperature Sensor - Check sensor and wiring.
2323 Mass Airflow Sensor - Check sensor and wiring for breaks.
2324 Mass Airflow Sensor - Check sensor and wiring for breaks or shorts to B+ or ground or
check for air leak.
2331 Oxygen Sensor Control - Out of range. - Check ignition, air intake for leaks and injectors.
2332 Oxygen Sensor - Bank 2 - Check wiring for breaks or shorts.
2341 Oxygen sensor (O2) at control limit; check CO, lambda-sensor wire, lambda-sensor
control, start valve, evaporative system and check for vacuum leaks.
2342 Oxygen Sensor Control - no signal - Check wiring, sensor.
2343 Rich limit; the pressure regulator has exceeded +10 mA for more than 5 minutes,
closed-loop; check for vacuum leaks.
2344 Lean limit; the pressure actuator has exceeded -5mA for more than 5 minutes, closed
loop; check idle.
2411 EGR System Malfunction
2412 Intake Air Temperature Sensor - Check sensor and wiring for breaks or shorts
2413 Mixture Control - Running rich
Fuel pressure too low
3424 Malfunction Indicator Lamp (MIL) failure - Check lamp and wiring.
4311 Secondary Air Injection Pump Relay - Check relay and wiring.
4312 EGR Frequency Valve
4313 Secondary Air Injection Solenoid Valve - Check valve and wiring.
4331 EVAP Carbon Canister Solenoid Purge Valve 2
4332 Ignition Circuit Final Stage - Check for break or short to ground or B+ or bad ECM.
4343 EVAP Carbon Canister Solenoid Purge Valve 1
4411 Fuel Injector Cylinder 1 or 1 & 5
4412 Fuel Injector Cylinder 2 or 2 & 7
4413 Fuel Injector Cylinder 3 or 3 & 6
4414 Fuel Injector Cylinder 4 or 4 & 8
4421 Fuel Injector Cylinder 5
4422 Fuel Injector Cylinder 6
4423 Fuel Injector Cylinder 7
4424 Fuel Injector Cylinder 8
4431 Idle Air Control Valve / Idle Stabilizer - Check valve and wiring.
4433 Fuel Pump Relay
4442 Wastegate - Defective frequency valve or wiring.
Boost pressure circuit - Check for short.
4443 EVAP Canister purge valve.
4444 No fault in system.
The unit does not work on any operation, the power light flashes three times then breaks then continues to flash as so.
try to disconnect power supply at the circuit breaker tor 10 sec. and "on" again to reset the error. But if wont work you need to correct the detect in the unit, like replace the defective thermistors, add refrigerant if the unit is under charge, clean the indoor and outdoor unit if dirty, etc...you need a technician for this problem.
Top Samsung Heating & Cooling Experts
jws1013
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
