Question about McCulloch Fuel Gas Cap With Gasket 600 605 610 650 300 3.7 Timber Bear
What year is a McCulloch MS1635 chain saw - McCulloch Fuel Gas Cap With Gasket 600 605 610 650 300 3.7 Timber Bear
    Top Expert:
  • McCulloch Master
  • 2,931 Answers
There is no way we can possibly know that. You'll need the serial number, and then contact the manufacturer.
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
User manuals McCulloch Service
I trust this information proves beneficial.
what year is a McCulloch MS1635 chain saw - helpful-rwwceix4simen0bu2pand4lt-4-0.png
Posted on Feb 19, 2018
4 Suggested Answers
dontbother10
  • 2220 Answers
SOURCE: I have Mcculloch Mac 10 10 chain saw year unknown
Put a small amount of fuel mix in the carburator. If it sputters investagate fuel system.
Lou
Posted on Oct 08, 2009
dontbother10
  • 2220 Answers
SOURCE: set the carb for a mcculloch 3516 chain saw
Carburetor Adjustment
There are no hard and fast settings.
A good initial starting point for the "H" and "L" needle valves are 1.5 turns CCW from lightly seated.
The "T" adjustment enters here (idle speed) and there is no initial setting without a tachometer, depending on age of your saw there may not be any initial "T" setting.
The "L" needle is primarily idle performance (not speed) and acceleration to full throttle.
The "H" is mostly performance at speed, but all are interconnected.
Start with a fresh mix of fuel. Put ALL of the old mix in any 4 cycle engine and start new. I suggest 50:1 regardless of what your manual says.
CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; once marred adjustments are difficult to impossible to set properly.
Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
Clean the spark arrestor and muffler; if the saw cannot exhale it cannot inhale.
Now we adjust for performance. The best performance adjustment procedure I have found follows.
Madsens Shop & Supply, Inc. Carburetor adjustment (All saws homeowner and professional are the same)
http://www.madsens1.com/saw%20carb%20tune.htm Read step 4 (allow it warm before making adjustments).
There are 2 wav (sound - idle & full - may not be highlighted) files that I find most helpful, I think you will too.
I am going to inject a little philosophy here. Undetected air leaks and defective fuel delivery systems account for most chainsaw failures. Constant adjustment of needle valves can easily camouflage more serious problems that result in burning up your saw. A sudden need for an adjustment is often indicative of a larger problem.
If push comes to shove a local saw shop (I prefer Stihl mechanics and do not own a Stihl) should be considered.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on Jul 09, 2010
conveyician
  • 110 Answers
SOURCE: what is the proper fuel mix for a mcculloch ms1635
between 32:1 and 40:1 - Manufacturer recommends 40:1 Ratio - EXAMPLE: "Mix 3.2 ounces of Poulan 2-cycle air cooled engine oil to one gallon of fresh unleaded gasoline to obtain the recommended 40:1 fuel to oil ratio."
Posted on Sep 02, 2010
Mcculloch chain saw 35cc ms1635 full line digarm
I don't know what a full line digarm is, but you can download service manuals using the links below:
I recommend contacting your local authorized service center for assistance.
Contact us
User manuals
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
Sep 09, 2012 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
What is the proper fuel mix for a mcculloch ms1635 chain saw?
Sep 02, 2010 | McCulloch Garden
Does not idle
A link to a MCC 1635 OM follows:
http://ipl.ordertree.com/ipl/845/MCC1435A(311023).pdf
From page 11
IMPORTANT IDLING INFORMATION
In some cases due to operating conditions (altitude, temperature
etc.) your chain saw may need a slight adjustment
to the idle speed.
After warm up - See the User's Manual section 5-2, step 7
- If unit does not Idle after restarting 2 times, follow these
steps to adjust idle.
1. Idle adjustment access (G). (Figure 5-2H)
2. Using a Phillips or slotted screwdriver - turn screw 1/4
to 1/2 turn clockwise (to the right). Unit should then
idle properly. (Figure 5-2H)
NOTE: If chain turns while idling - turn screw back to the
left until chain stops and unit continues to idle.
Anything beyond this the OM recommends to a authorized dealer. Not bad advice, I suggest a local Stihl dealer.
Lou
Jul 28, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Need help finding chain tension screw/adjustment on mcculloch 16'' chain saw or a good link to a free manual for this model ms1635.
You can find an OM here:
http://www.ordertree.com/modelinfo/MCC/MCC1635A---OM/139.MCC1635A---OM.1.59.1.html
Lou
Jun 20, 2010 | Garden
I need a mamual for McCuloch chain saw CS 38EM
A more common model number is MS1838AV. Your IPL follows:
Chainsaws 32cc-35cc-38cc Anti-Vibe
Operators Manuals: are much more difficult. I have dialed this number many times (Contact Us - All McCulloch Products 1 (800) 521-8559) and have yet to get a satisfactory response. Please try this! If enough of us try they will fix it! If unsuccessful with McCulloch try here:
Beg for manuals thread (ArboristSite - free to join). Please use the search function first, it has probably been asked and answered (I did not get any hits).
http://www.arboristsite.com/showthread.php?t=72322 HTH
Lou
Feb 17, 2010 | McCulloch Garden
Lou
Oct 08, 2009 | McCulloch Garden
Can not remove chain easily model ms1635
There is a tension adjustment screw. Look at section C of this sample manual for McCulloch. It's not the same model, but it should be close enough. =>
http://www.scribd.com/doc/3097717/CHAINSAW-McCulloch-Manual
Jan 02, 2009 | Garden
McCulloch Fuel Gas Cap With Gasket 600 605 610 650 300 3.7 Timber Bear Logo
Top McCulloch Garden Experts
Jim Parker
Jim Parker
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
