Question about Frigidaire Gallery 24 in. Built-In Dishwasher FGHD2433KB
WHY DOESN'T MY FGHD2433KB NOT DRAIN - Frigidaire Gallery 24 in. Built-In Dishwasher FGHD2433KB
  • Official Brand Answer
  • 2,267 Answers
Good Morning Friend,
I understand that your Frigidaire dishwasher, model# FGHD2433KB, is not draining. Here are some suggestions that you can try.
    1)If your appliance is hooked up to a garbage disposal, make sure the disposal is empty.
    2)Check to make sure that the knockout plug has been removed from inside your garbage disposal.
    3)The inside of your dishwasher is self-cleaning with normal use. If needed, clean around the tub gasket area with a damp cloth. The filter is self-cleaning. A glass trap located in the center of the filter is designed to collect pieces of broken glass, straws, bones and pits. To remove items in glass trap, grasp handle, lift out, empty and replace.
    4)The Overfill Protector keeps your dishwasher from overfilling and is located in the left front corner of the tub. Clean this occasionally with household cleaner containing vinegar or bleach to dissolve any buildup. The Overfill Protector should move up and down freely about one inch. If it does not move, lift and clean underneath of it.
    5)Check to see if drain hose is kinked.
    6)Make sure cycle is complete, not in a pause.
    I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dishwasher status has changed successfully. Hope this is helpful.
    -Best Regards-
    WP
Posted on May 17, 2014
How can I replace main control module?
Hello John, thank you for your inquiry!
Based off the information you have provided you need help replacing the main control on your Frigidaire dishwasher, FGHD2433KB. I have located your parts manual which provides a breakdown of all the available parts within your dishwasher. If you still need additional help I would recommend contacting a professional technician for further assistance. This will avoid any improper disassembly or personal harm. I hope that this information is helpful. -Matt
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Kinston/5995551149.pdf
Feb 23, 2016 | Frigidaire FGHD2433KB Gallery 24" Built In...
Will not drain and spin
see this causes:
t spins, but doesn't pump
the drain line is clogged+ some sock remain, remove with pliers,+pump defective.
It doesn't spin or pump
frozen pulley pump defective, replace
It pumps, but the water returns
improve the drain line. If drain hose reach more 4 inche cut of of excess. If lower add air/gap siphon break assembly.
see diagram
God bless you
Jul 03, 2012 | Kenmore Elite 45986 Front Load Washer
Miele honeycomb care w 1712 drain fault comes on every wash
see this possibles causes:
God bless you
attached diagrams
see line clogged and fix it.
frozen pulley
improve the drain laundry, if drain hose reaches more 4 inch cut off the excess
May 16, 2012 | Miele Washing Machines
Drains but drum wont spin
see this probably causes:
see for glogged drain line
see the pump pulley frozen
slow drain, improve the drain see the attachement
May 08, 2012 | Washing Machines
I have a 1776 Asko model & it doesn't finish its cycle-code mesage f-2 keeps appearing. Can you help me out.
Hi
F2 is a drain error and dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Sep 18, 2011 | Asko 1375 Dishwasher
Doesn't drain out all the way water stays in
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 30, 2011 | Maytag Dishwasher
The second led is flashing. Water did nit drain at first. Then drained. Cannot press the start/reset button, nothing happens. Sounds like the pump was working, now doesn't seem to be. Help!!!
Hi
Daniel
Aug 27, 2011 | Dishwashers
The dishwasher is not completing it's cycle and doesn't seem to drain at the end.
Hi
This issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 15, 2011 | Smeg 18 in. DWD409SS Built-in Dishwasher
My dishwasher doesn`t drain. there is water at the bottom at te end of every wash... what`s wrong? how can i fix it?
Hi
Daniel
Aug 06, 2011 | Whirlpool Dishwashers
Water doesn't drain
Hi
Daniel
Aug 03, 2011 | Maytag MDB8851 Built-in Dishwasher
Frigidaire Gallery 24 in. Built-In Dishwasher FGHD2433KB Logo
57 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
