Miele f50 w 3923
Icalled the miele service and the technician said its probably the control board (witch costs 420 euros plus his payment!!!!) but he is not sure, maybe its also the motor (another 400 euros)I m asking you if its worth fixing it or should i buy a new washing mashine. thank you!
aborcass
  • 2651 Answers
SOURCE: Maytag Nepture MAH5500BWW burned control board
ummmm, honestly ive never replaced just the board(im an authorized maytag servicer) so our replacements have always been new, and in this case the repair kit containing both board and motor. that being said, i cant see a reason as to why you couldnt relace just the board itself, ,Ireally never found the reason why the board would burn out, but, as far as repair kit im certain that they were trying to get all circuit boards and motors back to only one model, instead of having 5 or six different boards andmotors, this will bring them all to the most recent board and motor, never was an issue with themotor, jusat that you couldnt wire in the new board without the neew wiring. As long as its the same board i cant see why that wont work. as far as the "wax motor" that was a seperate issue burning out the Top control board, total seperate then your problem,., dont really see an issue with installing your "used board"
Posted on Apr 08, 2008
huuum
  • 750 Answers
SOURCE: piece if **** washing machine and dryer kenmore elite oasis
I called sears recall dept 1 888-548- 1509 told to make a service call about F problem and if that is the cause your charge for service call will be refunded and a new control board installed at known charge.The 27082 is not on the recall list yet but sears is aware of this condition.Don't give up just keep calling and ask that a copy of your call and complaint be forward to your address ,sears receives numerous call's each day about F1 control boards.
Cal them your self now and see if they will do this repair 1 888-548- 1509
Please leave a rating !
Posted on Sep 26, 2008
  • 2920 Answers
SOURCE: miele premiere nova needs new electric panel
i would go for the repair as you still have 6000 hours left on it that you can use up plus if he repairs it the life expectancy could be extended another 2000 hours..i would consider that before buying another machine and let him repair this one
Posted on Jan 30, 2009
  • 3 Answers
SOURCE: kenmore elite oasis washer
Today (4/3/09) I got a letter from Sears. They will replace the electronic control board (you know, the F-51 business) for FREE, in warranty or not. Serial #s for the Bad Board begin: CS48 - CS52 or CT01-CT49. Call Sears at 800-847-9083. The voices of all of us have finally been heard! There is a class action attorney firm in San Francisco looking into a legal remedy.
Posted on Apr 04, 2009
jsrock516
  • 5911 Answers
SOURCE: Kenmore 80 Series Model 110-25862 that won't start wash cycle
Check your lid switch. This is the most common cause of the problem you are experiencing. Symptoms may include, filling and stopping on the intial fill cycle, a wash tub that will not drain, and stopping right after the wash cycle and not advancing to rinse or spin cycles.
The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
On some models, the lid switch is located under the top casing by one of the lid hinges. You will know if you if you have this type of switch, because It does not have a lid strike and the small hole on the right hand side of the wash tub will not be present. This switch is actuated (toggled) by a rod on the lid hinge. With this type of switch, if you locate it and it can be toggled by hand, you may only need to adjust the actuator by bending it slightly.
A replacement lid switch (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
This is a very simple and inexpensive repair that you can do without the assistance of a repairman. The average price is about $20 - $30 if you perform the repair yourself. Prices differ between sites so shop and compare. The part number for a replacement for your washer is 3949238.
NOTE: You DO NOT need to drain the washer to replace the lid switch. Once a defective switch is replaced, the washer will drain.
If you have questions, or need additional assistance, please post back and let me know. I hope this information is helpful.
Posted on Mar 19, 2010
I have a Miele W1215 washer that died during mid cycle with no power and it looks like it is getting power to the machine, but control board doesn't lite up and will not open door.
YouFixit in Europe does a complete overhaul on this board for less than 100 Euros. See Miele Repair ELP150 / ELP152 / ELP153 / EL154. This also prevents some other issues with this board from happening in the future.
Apr 14, 2017 | Miele Washing Machines
We have a maytag refrigerator model msf21d4mde01. We started losing power to the controls on the door, but it would restart after an hour or so. Note that the fridge was working properly during the outage,...
Hello;
My mane is Peter. I am a retired field service refrigeration technician.
In your owners manual it is recommended that you have a surge protector. You can purchase individual wall socket surge protectors for about $22.00.
Any appliance in your home that has a control board should have a surge protector. A power surge can knock out your control boards.
You should have a 12 month warrantee. Get the surge protector before the service technician comes.
The control board on the door P/N W10606407 Cost $115.00 - $150.00.
You also have a power board in the lower back that communicates with the front control board. Since you have power this board is probably good. Cost: $120.00.
If you do not have coverage at this time and also even if you do, contact Sears Home Services and buy a, "Protection Agreement". As for the, "SMART" agreement. It covers you for $500.00 per service call. If you have 3 service calls in one year you are covered for $500.00 on each call. If they can not fixit after 3 calls then they give you $500.00 towards the purchase of a new unit. Do not let them talk you into the more expensive, "Master Protection Agreement". You do not need that.
If you do not have coverage now, then buy the , "SMART Agreement" wait 3 weeks and then call for service. The service technician does not care how new the coverage is. The technician just wants to do the repair and move on to his next 10-13 service calls scheduled for that day.
I have a SMART agreement on my clothes washer, which I can repair, but the service agreement cost less that the control board parts.
Mar 23, 2015 | Maytag Refrigerators
I have dirt in between glass> How can it be cleaned? Last time i called a technician. It cost me $200. Is there anyway I can do it myself?
Wonderful.
Share a website with you ,
( http://www.shoes2.us// )
Believe you will love it.
We accept any form of payment.
http://www.shoes2.us/Michael-Kors-Handbags-n2447/
Sep 01, 2013 | Miele H387B Stainless Steel Oven
Control knob snapped off.... wonderinff if this is an expensive repair. The washing machine is a miele m404 plus.
if it was just the knob no if it was the whole control yes very expensive the control arm cost around $ 300 but it would not damage it there must be more to this story if you simply need the knob - plastic control you can order it from here they cost around $ 30 www.meile.com
best of luck
Dec 28, 2010 | Miele Washing Machines
COST OF CONTROL BOARD MIELE DISHWASHER G841
best to call your local Miele service agent or Miele office as the price will differ depending serial number and the county you live in with the exchange rates etc
Jul 13, 2010 | Miele Premier-Plus Built-in Dishwasher
Hi,i have a washing machine miele w 3000 tech fault f63.what i can do?
Mine is W3844. Miele's technician said the Wather Path Control Unit (part # 6271992) need to be changed.
Total Cost: (HKD)
450 for todays check cost
1100 for the part
250 for the labour to change the part.
Jul 03, 2010 | Miele Washing Machines
Another question
You would be better off to buy locally. Try to find a local astronomy club and attend their meetings and star parties. Sometimes the members sell their older equipment at greatly reduced prices.
Sep 04, 2009 | Meade LX90 12 in. UHTC Telescope
Miele premiere nova needs new electric panel
Jan 30, 2009 | Miele Novotronic Premier 500 Front Load...
Temperature set to 33 but only gets to 40
You have a Sears ref. You didn't state that the service you used was Sears. Why I ask is because if you have a problem with the electronics -- the cost of guessing with these parts is expensive and there is generally no return on those parts. My suggestion is to call Sears and ask for the "Service smart agreemment" it is a pre-pay costing in the in the 200+ dollar area but will give you a repair value of 500 per call for a year. Plus you know it will be fixed and working. startingwith the second trip, if needed, there is a food loss payment with the policy.
Dec 03, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
