Question about Lexmark T644 Laser Printer
What does "flushing buffer" mean for Lexmark CS310n
3 Suggested Answers
  • 13 Answers
SOURCE: posted by rhung33 on Jan
The printer can't handle the data it received and flush it out of its buffer. Goto Menu->Settings->Postscript Settings and turn "Print PostScript Erro" on. When the same print job prints, you should get a page printed out telling you what the printer doesn't like. You may also want to try forcing the printer into Postscript mode. Your PS file probably contains a PJL to set the device to PS mode before it prints. When the printer expects PCL data and received PS data(or vise versa), you can get this behaviour
Posted on Feb 06, 2009
don_farr
  • 1018 Answers
SOURCE: What does "flushing buffer" mean
No response from the original poster as of 6/6/09. Normally, a "Flushing Buffer" message is pointing at a Postscript problem. A quick easy test would be to set the printer for PCL and retry the job. If it works, then you really need to look at the PS print file to find the error. Don
Posted on Jun 06, 2009
My lexmark X658de mfp says insufficient resources.try again when printer idle. i need solution.
Hi, did you mean:
Insufficient memory to support Resource Save feature?
(This means the MFP lacks the memory needed to enable Resource Save. This message usually indicates too much memory is allocated for one or more of the MFP link buffers)
You can rectify this by:- touch Continue to disable Resource Save and continue printing. Install additional memory
You can get additional memory from Amazon or Ebay.
Just put into your search engine, Memory for Lexmark X658de.
Hope this helps
regards
David
Dec 07, 2017 | Lexmark Office Equipment & Supplies
Lexmark printer CS310N error code replace unsupported black cartridge
Are you using a Lexmark cartridge? If not what is the make and part number of the cartridge you are using.
Alex
Mar 12, 2015 | Lexmark 28C0000 cs310n color laser printer
How do you get into the diagnostic mode
For CS310 models, turn the printer on, press and hold Down and Right, and release the buttons when the installed memory and processor speed displays.
For CS410 and CS510 models, turn the printer on, press and hold 3 and 6, and release the buttons when the installed memory and processor speed displays.
Aug 28, 2014 | Lexmark CS310N Inkjet Printers
I've got a Lexmark T520 and it's not printing anything from photoshop - it says 'flushing buffer' and then just doesn't print. It will print from other sources i.e. web pages...
to large a data being sent for memory on printer photoshop will be hungry data and its has to small a memory to cope ok for normal printing but not this type of work
Aug 14, 2011 | Lexmark T644 Laser Printer
Lexmark E 250 dn printer. Keeps turning off. Switching from blue bulb indicator to exclamation point indiator. Difficult to turn back on by pressing blue arrow button
The problem could be several things, the first one could be a Flushing buffer error. That means that the printer did not understand the print job sent to it and has to be reset in order to continue printing. Second could be a memory full error where the print job sent to the printer is too big and the printer memory is not enough. The third could be the printer front door is not closing properly, make sure the toner cartridge is installed correctly and that the front door is closed. That's all I can think of right now.
Jan 12, 2010 | Lexmark E250dn Laser Printer
I have been printing chapters in a book. One chapter will not print. The message on the Lexmark screen is "flushing buffer". does anyone know what this means or why it will not print?
The 'flushing buffer' is most likely due to a corrupt file or file to large for the printer memory. You can check the file size and reduce it. Also you might want to upgrade your memory for the printer. Also might want to check your printer settings if the page you are having trouble printing is different from the other pages printed, such as text & graphics, etc. There is also a possibly of print program incompatibility or Windows OS Patch required but I doubt this since you have printed other pages without any problem. If you need to re-install Lexmark driver: http://downloads.lexmark.com/perl/downloads/downloads.cgi Or, if you need the Lexmark user's guide & reference guide: http://www.lexmark.com/publications/eng/optras/index.html
May 17, 2009 | Lexmark Optra S 1255 Laser Printer
Jan 20, 2009 | Lexmark T644 Laser Printer
Posted by rhung33 on Jan 16, 2009 Under Window DOS prompt and Unix Sun Solaris 8 Station , using LPR -p command to print txt file to cause Lexmark T644 printer '' Flushing buffer '' and...
Jan 16, 2009 | Lexmark T644 Laser Printer
Lexmark c530dn wont print
disconnect this printer from your gigabit switch and try running it by itself. this printer should have its own on board memory. you may have uncompatible memories.
Apr 09, 2008 | Lexmark C530dn Laser Printer
Lexmark T644 Laser Printer Logo
218 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
