Question about Panasonic PT-DW640US WXGA 1-chip DLP Projector in Silver, 6000 L[...]
Panasonic PT-DW640. Why would all the status lights be lit and steady and it won't turn on?
All status lights are on and steady, standby is orange, filter is orange, all others are red.
SOURCE: panasonic pt ae900 wont fire up
First , start over and unplug it. Wait a few minutes. Turn on AV system that is connected to it but not video or dvd player. With remote, point at is corectly and push power 1 sec or as soon as you see green light come on. Be quick.
If this fails you can wait 4 hours and repeat. OR try only projector with out any feed.
Let me know if this worked.
Posted on Dec 27, 2008
Motobias
  • 6 Answers
SOURCE: Faulty Panasonic Projector
90% that this is a bad psu !
had mine fixed today with used psu from ebay.
try to find a faulty pt-ae900 for a exchange psu !
60€ faulty projector + 60€ psu = 120€ for pt-ae900
hooray :)
cheers,
tobias
Posted on May 04, 2009
SOURCE: Projector Panasonic PT-LC50U
MI PROYECTOR PANASONIC PT-LC50U ,SOLO ENCIENDE DE 2 , 10 NINUTOS LUEGO SE APAGA Y SE ENCIENDE LA LUZ O SALE LA LETRA L-n QUE DEBO DE HACER POR AQUI NO HAY CENTRO TECNICO ..
MI CORREO ES : jcasaperalta@hotmail.com
gracias por darme solucion.
Posted on May 18, 2009
SOURCE: My PT-AX100u will not turn on.
My PT-AX200U does the exact same thing. I installed a new lamp it worked great for the first week or two. Now and then when I want to turn it on, the green light blinks then the yellow light comes on and blinks and then it shuts itself off.
Posted on Dec 27, 2009
SOURCE: Panasonic PT-LB10SVU green light flashing,then orange,lamp light
i just replace the lamp, and don't have any light coming from lens,starting green (after a few seconds,green become to flash2_bing.gif), then turning on orange and lamp light flashing...please i need help, fan working perfect...i don't have a remote,is a problem, or not
Posted on May 03, 2010
NEC lt240 lamp light stays off and power light is orange, no Image
COULD HAVE HOUR COUNT LAMP LOCKUP YOU WILL NEED TO RESET HOUR COUNTER BY USING BUTTON CONFIG AND MAINS.
john
www.jvsvisual.com
Apr 15, 2013 | NEC LT 240 Multimedia Projector
I have a pansonic pt-ax220u, When I start it up it turns on perfectly fine and runs for about 2 minutes. After that the screen shuts off but the projector is still on.... Instead of the light being green...
The main board of the projector needs replacement! not worth getting it replaced as it would cost very high! look out for a old working board that would cost lower!
Jan 11, 2013 | Panasonic PT-AX200U Projector
I have a panasonic projection TV, PT-60C13 that will not turn on. Upon pressing the power on button, the button flashes green many times, then flashes red five time then one orange flash. This red/orange...
The most common cause of Panasonic Rear Projection LCD TVs not starting is bulb failure. The PT-60LC13 users manual gives some help in translating the LEDs on the front of the TV.
If the TV worked normally for a period of time (months or years) and won't start, the most likely cause is bulb failure. There is no way to measure the bulb, sometimes the bulb is visibly damaged when it fails. Remove the Lamp Assembly and look at the bulb.
If there was an On-Screen Lamp Replace warning and TV won't start, bulb has failed.
The first step with all Panasonic Rear Projection TV "No Picture" problems is bulb replacement. If that does not remedy the problem, get a technician, there are no user serviceable parts. Guessing if the ballast, power supply, controller board or optical engine is faulty is not practical.
The Panasonic Lamp Gallery shows all Panasonic models and Lamp Numbers. There is also a link to Panasonic DIY bulb and lamp replacement.
easyab
May 05, 2011 | Panasonic PT-60LC13 60" Rear Projection...
How can I reset a VT540 without a remote it has steady orange and red lights on so is in standby after bulb change
Simple.
Press the Help button on the remote control for a minimum of 10 seconds while in standby mode. When the lamp time clock is reset to zero, the STATUS indicator goes out.
Apr 04, 2011 | NEC MultiSync VT540 Multimedia Projector
I have a NEC VT470 Projector. The power light is steady orange and the status light blinks red 6 times.
steady orange means projector in standby mode
red light 6 times is a lamp error.
either the lamp is old and wont start up or the ballast power pcb is not working.
can you hear the sparking of the high voltage trying to strike the lamp.
if you can then the lamp may be dodgy.
can you borrow one to test it out
Mar 02, 2011 | NEC VT470 Multimedia Projector
THe pc gives a steady orange light when power
Sounds like its in either standby or hibernate. Try unplugging it if it wont power on, press the power button, wait for 2 minutes then plugging it back in then turn it on. Afterwards, go into power managment, and find where it asks what do when you press your power button change from hibernate/standby to ask what to do.
Mar 07, 2010 | Dell OptiPlex GX520 PC Desktop
Computer won't turn on after being placed on standby.
Try remove the battery, then wait 20 min, put back it and try again.If this not help your computer may need service.
Oct 27, 2009 | Sony Computers & Internet
I have a Panasonic 50" LCD TV PT-50LC13 and the power botton blinks orange 2 time and there is no pic but i can here the fn runing what can i do???
if the tv keps trying to turn on three times and later the lamp led stays steady red. (see owner's manual to replace the lamp process) the lamp is damaged. ones you open the lamp door and take the lamp out you can see the lamp damaged even before to buy it.
Apr 08, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic PT-51HX41 51 inch
Can you post how many blinks the power indicator is blinking as that is an error code such as 3 blinks means Convergence circuits.
Mar 02, 2009 | Panasonic PT-51HX41 51" Rear Projection...
Panasonic PT-DW640US WXGA 1-chip DLP Projector in Silver, 6000 L[...] Logo
280 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
