Question about Lands Phones
How to remove cover of a wIndow air conditioner?
5 Suggested Answers
  • 1122 Answers
SOURCE: air conditioner won' start
does the power cord have a reset button on it? if so reset it,if that does not work cut that off and go to lowes and buy a reg. 110 volt male plug,that should do the trick,let me know what's up-mike
Posted on Jun 12, 2008
  • 46 Answers
SOURCE: heater and air conditioner blower switch.
Check the resistor first. It may be bad. Should be under pass. side of the dash close to blower motor mounted in bottom of evap case. Remove it and try known good one first before going at the switch. If it works on high then the switch may be okay. Good luck.
Posted on Jun 06, 2010
  • 1796 Answers
SOURCE: I turned on the air conditioner and forgot to
Hi!!
It probably trip the breaker, or blew a fuse. if these to are OK, open the return grill and inspect wiring.
Don't forget to rate this post!!! Good luck!!
Posted on Jul 26, 2010
MOTORWIZJ
  • 1358 Answers
SOURCE: How do I remove the front cover of my old Kenmore
THE FILTER SHOULD SLIDE OUT FROM THE SIDES OR THE TOP, AND SOMETIMES THE BOTTOM. JUST HUNT AROUND AND WITH THE TIP OF YOUR FINGER , DO THE WIGGLE TEST
Posted on Jul 28, 2011
How to remove face cover for cleaning
The front covers are usually snapped into place. Grab at top and bottom and pull. It should pop right off. GOOD LUCK FRIEND.
Sep 15, 2014 | Whirlpool ACC184PS Thru-Wall/Window Air...
Window air conditioner
I have neve done this my self but I have seen it friends expert in the ac field doin it the condenser with the lines are removable true the front of the unit just look for the screws attached to the outside cover and unscrew them all about 6 of them and just pull the inside of it and you can work with it as you please.
Aug 03, 2012 | LG LWHD1200FR Wall/Window Air Conditioner
How do I remove the front cover of my old Kenmore 5200 BTU window air conditioner to access and change the filter?
Jul 28, 2011 | Kenmore 75051 Wall/Window Air Conditioner
How can i remove the outside cover on a 71055 window airconditiner
there should be a cuopule of screws on each side and on the top and first unscrew the front cover and it may slip in on the top part but remove the side screws first and one in the filter compment
May 09, 2011 | Kenmore 71055 Air Conditioner
How to remove front cover for cleaning
I don't know too much about your particular make / model but most window units have a 1 piece front cover which is usually held on to the main cabinet with 1 or 2 screws at the sides and 1 or 2 behind the filter panel. You will need to remove the front panel to remove the vents as they are usually fitted from behind the panel.
May 31, 2010 | Friedrich QuietMaster SM18J30BR Air...
How do i clean my window type aircon?do i need a technician or can i do it myself?
Yes you can do this . Remove this out the window, remove all the screws around the outside cover and lift off the 1-piece cover sides /top and start to clean .Also remove the cover on top of the back coil and clean this real good..
Dec 05, 2009 | LG Heat cool Window Air Conditioner
Need to access inside of Carrier air conditioner.
After removing the cover and filter, you should be able to see the fins for cleaning. If there is styrofoam in front of the coil, it should not be there for proper operation.
Aug 20, 2009 | Carrier 52FE312-3 Air Conditioner
Why isn't my Sunbeam Window A/C blowing hard on high?
If the air doesn't seem cool enough it is necessary to use a thermometer to check the difference in temperature between the air going into the unit and the air being blown into the room. Ideally, the temperature difference should be more than 15 degrees. For example, if the temperature going into the air conditioner is 80 degrees, the temperature coming out of the unit should be at least 65 degrees or less. If the difference is 15 degrees or more there is probably no cause for concern. If the temperature difference is less than 15 degrees you should check the following:
  • Air damper
Check to make sure the air damper is closed. If it's open, it will bring in outside air and reduce the efficiency of the unit.
  • Back cover
During the winter season many people cover their air conditioners to protect the unit from the weather. In the spring or summer they will sometimes forget to remove the cover. If your unit has a cover on the outside portion of the air conditioner remove the cover first.
  • Condensing coils
The condensing coils will always be on the "warm" side of the air conditioner. That is, on the side that faces outside of the room to be cooled. Air is drawn into the back of the air conditioner on the sides through vent slots and is blown directly out through the condenser coils. If the coils get clogged with lint, dust and dirt the cooling system cannot provide the cooling necessary. To clean the coils it will be necessary to remove the entire cover of the air conditioner or pull it out of the wall to gain access to the coils. They can be cleaned by blowing compressed air at them or by using a soft bristle brush to wipe the dirt off. It is important to also clean any dirt or lint build-up in the bottom of the air conditioner so the condensate water will be picked up by the condensing fan slinger properly.
Aug 16, 2009 | Sunbeam SCA052MWB1 Thru-Wall/Window Air...
My Haier 5,200-BTU Window Air Conditioner keeps freezing up. how do I remedied this?
You need to clean the unit outside(take it out of the window) with a water hose because it is dirty inside( you have to remove screws on cover and take cover off), be sure to cover the electronic control board with plastic so you don't get it wet.Clean fins on front and back with water hose and inside .
Sep 02, 2008 | Haier hwr10xc6 Air Conditioner
Frigidaire air conditioner
remove cover .It might have two screws on the side or just pops off. Pull unit out from cover. if it does't move remove screws in back of unit near condensor
Dec 20, 2007 | Frigidaire FAC124 wall/Window Air...
Lands Phones Logo
12 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
