Question about Ovens
Voltas tower ac showing error code F3 what's the problem
2 Suggested Answers
SOURCE: GE Model JTP15 oven shows F3 error code
I have the same problem. I noticed that the oven gets to the selected temp ok. Then when the pilot attempts to RELIGHT, it gets the error F3. Did you get a solution? After other posts, I will see if the temp sensor is around 1100 ohm as suggested by others. Ken
Posted on Sep 24, 2007
F3 error code
Bad oven temp sensor. If you know how to do so you can disconnect the power and remove the temp sensor. The two white wires to the sensor, ohm it. it must read ~1080 ohms. If not really close to that at room temp then replace sensor.
Dec 11, 2013 | GE Profile JT955 Electric Double Oven
Whirlpool GR396LXGQ oven comes on by itself & goes into clean cycle, code reads E2 -F3-
Whirlpool F3 faults relate to temperature problems in the oven. In the case of the error E2-F3, F3 is the general fault code and E2 is the specific error code. An E0-F3 error indicates that the oven's temperature sensor is open; E1-F3, that the temperature sensor is shorted; E2-F3, that the oven temperature has exceeded the maximum rated 575 degrees Fahrenheit in "Cook" mode; and E3-F3, that the oven temperature has exceeded the maximum rated 950 degrees Fahrenheit in the clean mode. Here is the probe to order.
The part comes with a 365 day, any part, any reason return policy.
Nov 07, 2012 | Whirlpool Ovens
Service Code F-3
The error code's F3&F4 are codes that mean their is a problem with the oven tempature sensor and that sensor is uncappable of telling the control board what the temp. is in the oven. This is what the sensor looks like,oldtech2332_20.jpgTo check the sensor,unplug it and place meter leads into the white plastic plug at the end and check for between 1060-1100 ohms of resistiance when its good.
The F3 error code means that the sensor is shorted so if it indeed is shorted the meter reading will show ZERO ohms resistiance instead of the 1060-1100 of a good one.
The F4 error code is for sensor that has a open circuit,so instead of the 1060-1100 of a good it the display on the meter will show infinate resistiance ( the meter display will not change)
If on either the F3/F4 error code if at room tempature when checking the oven sensor if the display shows anything other that 1060-1100 ohms the sensor is going to be the problem and needs to be replaced.
Nov 30, 2011 | Magic Chef Ovens
Kitchen aid wall oven Model YKEBS2780B1 SHOWS
Hello,4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock(ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock(ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock(ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3
Thanks
May 26, 2010 | Ovens
Onen display shows f3
The F3 error code relates to the oven temperature sensor and usually means this has failed and needs to be replaced.
It is a reasonably straightforward job, details of which you can find here; www.fixitnow.com/2003/02/appliance-tip-of-the-day-oven-temperature.htm
Jan 18, 2010 | Ovens
Error code shows E1 -F3- on a
F3 E1 IS THE OVEN SENSOR IT IS ON THE BACK WALL HELD IN BY TWO SCREWS IT LOOKS LIKE A ROD,MOST OF THE TIME YOU CAN PULL ITHE WIRES THROUGH OR YOU MAY HAVE TO DISCONECT FROM BEHIND
Jan 12, 2010 | Kenmore Ovens
Kenmore wall oven keeps showing error codes f5 and f3. Unit will not say on.
oven went into E2 F3 oven code while cooking a chicken and broil burner came on turned off oven but broil burner stayed lit, then had to unplug
Nov 13, 2009 | Kenmore 47702 / 47704 / 47709 Electric...
Error codes
Hello raco1
Welcome
I need your model number to look up the fault code !!!!
You said , you see fault codes, FD F3 and E2 F3 is showing up on display pane
Looks like this may be your problem
F3 - E2 - Oven to hot -Replace oven temperature sensor
Waiting for your response.
When responding send me this whole communication . Not just your answer!
Thank you Huuum.
Oct 03, 2008 | Whirlpool RBD305PD Electric Double Oven
Jun 14, 2007 | GE JTP15 Electric Single Oven
Ovens Logo
238 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
