Question about NEC ND-3550A DVD RW Dual Layer Burner
Have NEC 3550A DVD/rw. re-installed windows XP professional & all else.. DVD will not recognize most dvd discs.Got drivers from NEC.. still problem
Go to:
1. start > run > devmgmt.msc
2. Under DVD/CD Rom drives make sure it's installed (Uninstalled = Yellow icon)
If all drivers are applied correctly this could be a problem with the DVD Region Settings.
Go to:
2. expand
3. find the device
4. right click > properties
5. go to dvd region tab
6. select the desired region
Warning: some drives only allow you to change it up to 5 or 4 times so be careful!
Posted on Jun 24, 2009
Nec nd-3550a won't recognize dvd discs. will see and play cd discs. Have checked all registry entries mentioned on multiple web sites. Tried to take it apart to clean the lens. Got the bottom off but...
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or the drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall hope this helps
Mar 31, 2011 | NEC ND-3550A-KIT DVD±RW Burner
I got a message said your nec dvd_rw nd 3550a is corrupted (code 39)
Try re-installing the drivers.
or You can try this automated fix from microsoft.
http://support.microsoft.com/gp/cd_dvd_drive_problems
Read and follow the instructions.
Good Luck
Nov 10, 2010 | NEC ND-3550A DVD RW Dual Layer Burner
My NEC doesn't read DVD's, DVD-RW and CD read good. Please help! Firmware 1.07 Windows XP
I assume that you are talking about movie DVD's; you need a 3rd party program that can play DVD's, or you need to install the proper codec's to play DVD's; because of fear of "monopoly" lawsuits, Windows Media Player in XP does not natively support DVD playback. You can either look for and install the necessary codec's, or you can download and install VLC player (among others) that have the necessary functionality built in. Try this link:
http://download.cnet.com/VLC-Media-Player/3000-13632_4-10267151.html
It is from download.com, and is tested to be malware free. Load the DVD in your drive, open "My Computer", right click the DVD drive, choose "Open With" and select VLC player.
Feb 11, 2010 | NEC ND-3550A DVD RW Dual Layer Burner
My dvd player will play music and movies ,but will not burn dvd's.It always says's the dvd is full,although it is new.what can I do . Gary
Gary,
First, you need to make sure that the disc is empty.
Second, try to re-install the driver of your player/writer. And that should fix the problem.
Jan 23, 2010 | NEC ND-3550A DVD±RW Dual Layer Burner
Just looking for latest driver for nec dvd rw nd 3550a. been on a number of sites and all just offer driver bots to search, all i want is this one driver to get my dvd working again? is there a site i can...
try this your original drivers may be in conflict with your antivirus program in your registory this is a microsoft patch use the xp version even if you run vista as it doesnt work
http://support.microsoft.com/kb/314060
Oct 16, 2009 | NEC ND-3550A DVD RW Dual Layer Burner
My desktop is not playing cd or dvd's.
go to control panel and search for new hardware...or download new firmware fpr your device
Sep 29, 2009 | NEC ND-3550A DVD±RW Dual Layer Burner
My ND 3550a drive stopped working.. Two days ago it worked fine, so I went to the store to pick up some DVD-Rs. The next day, the drive wouldn't recognize the discs at all. My computer said that the drive...
itachihatake --
If your drive was able to recognize a disk before, but now has stopped... POSSIBLE solution... (don't shoot the messenger on this one, lol!)
I'm sure you have tried, but have you cleaned your optics lately?
Using a Q-tip and a small amount of rubbing alcohol, and GENTLY rotate the swab across the lens, rotating it in the opposite direction you are wiping. This should "lift" any dust or grime from the lens. I would also clean the tray with a soft lint-free cloth (using an air-can just moves the dirt around, doesn't solve the problem)
If it is a new drive, try uninstall from Device Manager, reboot2.gif... allow Windows to discover new hardware, allow windows instlal a generic driver, and then update your driver via your install disk...
Hope this helps!
-- RT
PS - Don't forget to vote!
Aug 31, 2009 | NEC ND-3550A DVD±RW Dual Layer Burner
My nec 3550a wont pickup a burnt dual layer disc
It may not be compatible with a dual layer disk, just the regular dvd-r or dvd-rw disks.
Jul 19, 2009 | NEC ND-3550A DVD RW Dual Layer Burner
I have problems with my nec nd-3550A dvd rw
Make sure that your buner supports the type of blank DVD that you are using.
Jan 24, 2009 | NEC ND-3550A DVD RW Dual Layer Burner
NEC ND-3550A DVD RW Dual Layer Burner Logo
429 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
