Question about Eureka Mighty Mite 3670 Bagged Canister Vacuum
Where/how to turn on the. Mighty might..Im a a friends house, cant find switch
Eureka!
2 Suggested Answers
  • 1493 Answers
SOURCE: Eureka Mighty Mite 3670 Bagged Canister Vacuum just stopped working
Should be under warranty. Take it to a warranty center for repair
Posted on Jan 05, 2014
Jan 05, 2014 | Eureka Mighty Mite 3670 Bagged Canister...
Need to replace belt in eureka envirovac model 4470
You must remove the screws that hold the top cover onto get to the belt. Remove top cover then remove brush roll to install new belt. Replace belt at least twice per year for proper cleaning.
Oct 26, 2013 | Eureka High Filtration s Mighty Mite...
Replacing the power switch of the Eureka The Boss 4870 vacuum
its actually just held in place with two small plastic clips. so just gently start pulling the plastic housing up. it will pop off with some force. not so much that you break anything however. but there are no screws or anything. to get it back on you will need something to pry away the plastic section where the slots are for the clips. that way the clips can fit back in the slots instead of just dead ending into the handle. im sure there is a more proper way, but sometimes you have to get it done. my vacuum just stopped working one day. when I opened it up, I pushed the little connectors pretty hard back onto the switch. one of them clicked a bit. as it turns out it was just loose and therefore not making a proper electrical connection. so I pushed it snugly back together, jammed the housing back on, replaced the screws, and had it running again. just make sure to unplug it while you do this.
Sep 20, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
How to change the belt on a Eureka Mighty Mite II.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=700499
Generic problem for all Vacuums
Posted by Sawpit1 on Jun 23, 2008
How do I change the belt on a Eureka Mighty Mite II.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Normally the Mighty Mite II does not have a belt unless you have the model with the turbo head and then I believe it is a geared belt and then you can pup the belt from your local vacuum cleaner dealer or the Eureka factory parts dept. there are 2 to 4 screws on the bottom of the turbo head and then I believe the top will come up and then you can get to the belt. The average belt change is every year if it is a geared belt for the best cleaning or if you have a flat belt it is every 4 to 6 months. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.eureka.com Customer Service 1-800-282-2886
Customer Service Dept
Electrolux Home Care Products
P.O. Box 3900
Peoria. IL 61612
Hours of Operation
Monday thru Friday 8:00am to 7:30pm CST
Saturday and Sunday 10:00am to 6:30pm CST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 23, 2008 | Vacuums
Won't work
http://geeksquad.fixya.com/ThreadView.aspx?prdid=12151&thid=646957
Won't work (by 2 users)
Posted by AndiR on Jun 04, 2008
My Eureka Mighty Mite 3670 Bagged, was working fine, and we unplugged it to switch to another outlet in another room and it just stopped. We tried several other outlets and it just won't turn on. We thought maybe it got hot because we had been using it for a while and we let it rest for a while and then changed the bag just to be sure, although it was not full. But it still will not turn on. Any ideas……X
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
OK
1 Other User Has the Same Problem Comment by Guest, posted on Jun 06, 2008 I had the same problem today. Have a 9 amp model I bought 10 years ago which I never use. It has been sitting for years. Today put in new bag and ran it continuously for 45 minutes. After I turned it of it wouldn't restart. Tried another outlet and wouldn't restart. Felt canister at back and motor housing was hot so I thought I might need to let it cool down. After letting vacuum cool off for 10 minutes it restarted. All I can assume is that the vacuum has a built in overheat sensor on the motor. Hello,
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Eureka Mighty Mite #3670 Bagged Canister. I have the same type Mighty Mite Canister and from what you are saying the must be some type of heat sensor that is shutting off the motor to protect it from excessive heat. Al of the old ones have had lower amps and did not needs the heat sensor but once the bag is full and the filter clogged; they will shut down as well. They all use a plastic hose to clean with and that even gets hot sometimes. So I suggest that you get an owner’s manual from the manufacturer on you particular model so that id if happens again, you will be prepared. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Customer Service Dept for U.S.
P.O. Box 3900
Peoria. IL 61612
5855 Terry Fox Way
Mississauga, Ontario L5V 3E4
Hours of Operation
Go Ahead. Use Us.
Jun 04, 2008 | Eureka Mighty Mite 3670 Bagged Canister...
My eureka
The belt may look ok, but am sure it is stretched and when this happens, the brush roll won't turn like it should. Did you check the brush roll ends to see if they turn freely, if not replace it.
Mar 10, 2008 | Vacuums
Eureka Mighty Mite 3670 Bagged Canister Vacuum Logo
52 people viewed this question
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
charlesjo336
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
